IDE HDD CF/SSD storage benchmark in a X30 **PIC**
berlibaer
Re: IDE HDD CF/SSD storage benchmark in a X30 **PIC**
#91 Post by berlibaer » Mon Feb 07, 2011 8:41 am
I recently purchased this IDC to microSATA converter: http://microsatacables.com/catalog/i196.html and a 1.8" OCZ Onyx SSD for my x31.
works flawlessly and very fast:
CrystalDiskMark 3.0.1 (C) 2007-2010 hiyohiyo
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 83.632 MB/s
Sequential Write : 59.570 MB/s
Random Read 512KB : 78.802 MB/s
Random Write 512KB : 59.288 MB/s
Random Read 4KB (QD=1) : 22.689 MB/s [ 5539.3 IOPS]
Random Write 4KB (QD=1) : 6.560 MB/s [ 1601.6 IOPS]
Random Read 4KB (QD=32) : 25.789 MB/s [ 6296.1 IOPS]
Random Write 4KB (QD=32) : 6.647 MB/s [ 1622.8 IOPS]
Test : 100 MB [C: 20.6% (6.1/29.8 GB)] (x5)
Date : 2011/01/31 16:42:48
OS : Windows XP Home Edition SP3 [5.1 Build 2600] (x86)
Regards
sjthinkpader
Re: IDE HDD CF/SSD storage benchmark in X30/X40 **PIC**
#92 Post by sjthinkpader » Sun Apr 08, 2012 5:31 pm
This is a really old thread but I still get questions on this. Looks like all the tables with data had been deleted due to age. I will repost them when I get home.
These are 1.8in HDD/SSD/CF for use in X40/X41/X41t
X32 2673-BU6/32GB SSD
Lockheed
#93 Post by Lockheed » Mon Feb 25, 2013 4:38 am
sjthinkpader wrote:I want to thank virge for contributing the Samsung 32GB SSD data and ricerocket contributing the Kingspec 64GB SSD data. I added the fastest CFs and HDDs from other tables to make a list of fastest devices for the X40/X41/X41t 1.8 inch HDD slots.
The Kingspec is very fast for larger file sizes. The Sandisk SLC SSD remain the fastest for small file sizes.
I know it's an old thread, but it is the only place I found with any factual information about SDU5B-032G.
Does anyone know if this SSD supports TRIM?
And would it be comparable in performance to MMCRE64G8MXP?
T420s - i7, 16GB RAM, Samsung 850 EVO + 1TB Hitachi 9.5mm, Nvidia, Oleh Bios.
W500 - C2D P9500, 8GB RAM, Samsung 830 SSD + 750GB Hitachi HDD, Intel+ATI GPU, bright WUXGA, FP-reader
Arch Linux, BTRFS+ZFS on LUKS
Tasurinchi
#94 Post by Tasurinchi » Mon Feb 25, 2013 5:43 am
Lockheed wrote:...but it is the only place I found with any factual information about SDU5B-032G.
I have it, albeit with a very old firmware. I used it in my X41T and is now moved to a Dell D430. I'm quite sure it does not support TRIM.
Lockheed
#95 Post by Lockheed » Mon Feb 25, 2013 5:47 am
Can one upgrade firmware in a SSD?
Is it worth getting it for around ~30 bucks? It would be my first SSD, run as a main OS drive (I need 20gb for the os), paired with a HDD in Ultrabay.
Tasurinchi
#96 Post by Tasurinchi » Mon Feb 25, 2013 7:27 am
In theory yes, yet I couldn't find any firmware upgrade anywhere on the net :?
Which Thinkpad do you want to use for it? IDE SSDs are not cheap normally. And if the OS alone needs 20GB I would rather go for a 60GB SSD. Generally speaking SSDs tend to loose performance when they're getting full.
Lockheed
#97 Post by Lockheed » Mon Feb 25, 2013 8:00 am
It would be a partition of 20gb, so 12gb left would not be bad.
It is for R61 with SATA interface, but I'd be getting the drive here
http://www.ebay.com/itm/DELL-R342C-Lati ... 1c302407e0
so it looks like it comes with SATA array
Tasurinchi
#98 Post by Tasurinchi » Mon Feb 25, 2013 8:22 am
Don't bother then with the Sandisk!! The table you were checking was for old IDE drives :!:
Since an R61 will take any SATA SSD you will have plenty of choices. I personally would go for an Intel, Samsung 840 or Crucial SSD. Check locally about prices, I think you can get a 120GB model for quite a good price.
Lockheed
#99 Post by Lockheed » Mon Feb 25, 2013 8:43 am
Yes, but I only need like 20gb of space for linux system, so there is no point in getting much more. I do not care for space. I care for performance and price.
My options are
1. This sandisk for 30 USD
+cheap
2. Sansisk 32GB SDSSDRC-032G-G26 for 50 USD
+fast?
http://www.newegg.com/Product/Product.a ... llFullInfo
3. ADATA Premier Pro SP600 ASP600S3-32GM-C 2.5" 32GB (is better/worse than no.2?)
http://www.newegg.com/Product/Product.a ... 6820211717
4. SAMSUNG MMCRE64G8MXP-0VB 1.8" 64GB for ~54USD
+bigger
- need to buy adapter
- short/none warranty
- SATAII only
http://www.newegg.com/Product/Product.a ... 6820147132
I have not found anything else in similar price range.
Tasurinchi
#100 Post by Tasurinchi » Mon Feb 25, 2013 8:55 am
I'll check 2.5" ones, they're normally cheaper...
Edit: I've heard as a rule of thumb that bigger drives are better performancers, I'm with you to buy the correct size, but if a bigger drive offers better price per MB than I'd go for it...
