how to speed up x300
Re: how to speed up x300
I believe those who have such skill don´t even bother with windows
mattbiernat
another way i sped up my x300, at least the boot time.
- msconfig - boot - advenced - enable 2 processors and enable maximum ram.
I´ll try this out, though it´s actually supposed to be like this regardless of the fact it was probably greyed out. Maybe it will work out for me too
Apart from long lasting Welcome screen
, I don´t see any difference in boot time...
mattbiernat
not all the tweaks apply to SSD. me thinks that increasing cache would have negative effect, remember we were trying to disable it in the policies. also, regarding the prefetch and superfetch, I have disabled both services, do you think i still need to disable it in the registry? and i got rid of pagefile altogether, I am not using that many memory intensive applications on x300. what is your boot time by the way?
As of the writing cache I really don´t know. However the other cache hacks like setting the cpu L2 cache had positive impact on my setup. Also, I´m pretty sure you have to disable superfetch and prefetch via the registry as well. Disabling only the corresponding services doesn´t shut them both down completely. My boot times with Hitachi 7K200 were about 50 secs from pressing the power button to usable desktop, I believe it could have been reduced further few seconds if I had known some of the "tweak" I´m now aware of. As of now my primary HD is a Seagate Momentus 7200.3 which boots every OS I tried on it slower than the 7K200 does. Despite the much better throughput of the 7200.3 I believe this difference come from the fact that 7200.3 has worse access times. AFAIK the 7K200 is the second best in access times among all available 7200rpm laptop-capable HDs.
I believe the guy that has written this article on the OCZ forums is not that much interested in the boot performance but much more in the overall OS performance after the boot, probably mostly due to some specific problems Vista tends to make on the OCZ SSDs.mattbiernat wrote:not all the tweaks apply to SSD. me thinks that increasing cache would have negative effect, remember we were trying to disable it in the policies. also, regarding the prefetch and superfetch, I have disabled both services, do you think i still need to disable it in the registry? and i got rid of pagefile altogether, I am not using that many memory intensive applications on x300. what is your boot time by the way?
mattbiernat
windows 7 gave me 35 second boot without tweaking. the system performace seems to be a little bit slower thou. maybe bcause it still does not have as good drivers as vista, for whatever reason it does not feel as snappy as tweaked Vista. oh and 7 did let me disable write cache.
- 0 Replies
- 371 Views
Last post by Whitieiii
Sun Feb 05, 2017 9:20 am
Low Intel X25-M G2 SSD read speed in X60s with AHCI
by dandreye » Wed Feb 08, 2017 5:59 am » in Thinkpad X6x Series incl. X6x Tablet - 19 Replies
- 1950 Views
Last post by dandreye
Mon Mar 06, 2017 7:35 pm
Speed difference W510 i7 720QM vs W520 2720QM
by xsixt » Wed May 03, 2017 11:56 pm » in ThinkPad W500/510/520 and W7x0 Series - 3 Replies
- 664 Views
Last post by RMSMajestic
Mon May 22, 2017 3:40 pm
GONE: ThinkPad X300 (TYPE 6478-1VU) +shipping
by cds.helpdesk » Tue Jan 17, 2017 11:31 pm » in Marketplace - Forum Members only - 3 Replies
- 708 Views
Last post by cds.helpdesk
Mon Jan 30, 2017 2:41 pm
