Adobe Reader 9 plugin problem in W7b
Windows 7 on ThinkPads
Marin85
Re: Adobe Reader 9 plugin problem in W7b
#31 Post by Marin85 » Mon Feb 09, 2009 4:22 pm
I have AVG installed on my main system, but I don´t have any AV installed on Win 7 beta setup or actually anything else much (but I´m about to install some benchmarking utilities to test it thoroughly :twisted: ). What I reported with the .pfd-s opened in multiple tabs in IE8 happened actually after I had reinstalled Acrobat Reader v9, updated it and uninstalled Adobe AIR and Adobe.com to try out how it would be going with the updates installed. I´ll try it the other way around - installing Reader, removing AIR and .com and installing the updates. But I doubt that this would change anything for me...
BTW, when I close IE8 with a .pdf not opened in one of the tabs and the error message from Adobe, Win 7 gives "IE8 stopped responding" -> sending a report -> details: it´s referring to the Tmp folder... I also checked event log and it is massively full of errors, but that´s probably because of the beta. I found a few referring to DHCPv6 at the same time as Adober Reader acted up, so I "disabled" IPv6 (everything of it) by registry and rebooted, it seemed to have made things better, but not entirely... I´m afraid the problem is probably more complex than apparent. Since Acorbat Pro is reported to be properly working with IE8, I wonder what is missing in Adobe Reader to do so as well...
Marin
Marin85
#32 Post by Marin85 » Mon Feb 09, 2009 11:00 pm
Update: I installed the German language version of Adobe Reader 9 and all problems are now gone :) My Win 7 is in English but has regional settings set to Germany. Maybe it´s also worth mentioning tah the German language version of Adobe Reader v9 doesn´t come with Adobe AIR or Adobe.com. I haven´t tried to update it yet. Since it worked out "out of the box", I guess it´s just some sort of language/regional settings conflict.
Cheers
Marin
GomJabbar
Moderator
Moderator
#33 Post by GomJabbar » Wed Feb 11, 2009 6:35 am
Here is an interesting thread from Adobe's forum.
http://www.adobeforums.com/webx?128@@.59b692e5
DKB
Marin85
#34 Post by Marin85 » Wed Feb 11, 2009 8:04 am
GomJabbar wrote:Here is an interesting thread from Adobe's forum.
Isn´t there anyone to point these misguided souls to our thread? :P
GomJabbar
Moderator
Moderator
#35 Post by GomJabbar » Fri Feb 20, 2009 9:05 am
I haven't tried to view any pdf's in a couple of weeks. Now it's back to the old behavior. PDF's not opening in the browser anymore. :evil:
DKB
Marin85
#36 Post by Marin85 » Fri Feb 20, 2009 11:39 am
workaround: learn German -> install the German version of Adobe Reader -> German things seem to work always :P
Now, seriously, you could try out the UK verison of Adobe Reader (or any other), although that´s not really a solution even if it happens to work out...
BTW, I completely moved to Win 7, installed Adcrobat Pro and I can confirm that it indeed works without problems so far.
GomJabbar
Moderator
Moderator
#37 Post by GomJabbar » Fri Feb 20, 2009 6:47 pm
The UK version includes Adobe Air and Acrobat.com. I unistalled the US English version, rebooted, then installed the Spanish version which does not include Adobe Air or Acrobat.com (and is about a 9Mb smaller download), but it still will not open a PDF in a browser window.
I give up for now. I uninstalled the Spanish version of Adobe Reader 9 and reinstalled the US English version. I have Opera set up to open PDFs with Adobe Reader rather than the Acrobat plug-in. I have the preferences in Adobe Reader unchecked for "Display PDF in browser", so IE opens PDFs in a separate Adobe Reader window (just like Opera now).
DKB
Marin85
#38 Post by Marin85 » Sat Feb 21, 2009 7:39 pm
Actually, the Pro version also happens to produce this error sometimes :( Refreshing the page a few times seems to work around the problem for now...
Marin85
#39 Post by Marin85 » Wed Mar 18, 2009 12:44 am
Just found out: if one has first started an instance of Adobe Reader, then opening a .pdf in the browser doesn´t produce the error.
Return to “Windows 7”
