320GB pata drive?
JHaislet
Re: 320GB pata drive?
#31 Post by JHaislet » Tue Mar 10, 2009 1:59 am
Thanks for the info Johan!
I too am pretty confident it will work, just wanted to ask and see if anyone had any first-hand experience with the T43.
Worse case, if it doesn't want to play nice, I'll just throw it in the PATA Ultrabay and use it that way (it will still save me from carrying around an external USB HDD).
I bet I could probably also boot from it in the Ultrabay & completely remove the primary HDD. Hmm, something to try!
BTW, I assume this is the largest PATA/IDE drive currently made correct?
I checked Hitachi's, Seagate, & WDC's sites and almost all of their drives are now SATA.
Johan wrote:@ JHaislet:
I wish I could reply specificly to your question, but unfortunately I cannot, since I am a "T42'er". However, I just wanted to report here that I received one of these WD3200BEVE HDD's the other day, and installed it in a T42p. Initialized, partitioned, formatted, and then cloned it (using Acronis True Image ver. 9), all under Win XP Pro SP2, everything went with no problems. The T42p'er "sees" all 320 GB (300 GB binary, as usual), so no BIOS limitation with respect to that size.
I have now run with it for a couple of days, and the initial observations is that it is quite fast and cool,although I cannot say for sure whether or not it has a slight amount of periodical "whooosh" (seeking or calibration?) noise; not the clicking noise that some WD HDD's have been known to have... but still something clearly audible, for noise-picky users such as I!
I hope to return later with some more feedback. But, the message for now: This drive works OK ina T42 w/Win XP Pro SP2.
Johan
Johan
Moderator1
Moderator1
#32 Post by Johan » Fri Mar 13, 2009 11:44 am
- just a quick update: This 320 GB WD PATA HDD will give the "2010" error in T43's - see the thread T43 320GB 2010 error... :-(
- but fortunately I'm a T42'er... :-)
Johan
McLuvin
#33 Post by McLuvin » Sat Mar 21, 2009 12:58 pm
I'm getting my 320 on monday and also getting a usb case so I can clone the original 80 gig, we'll see how it goes :D
IBM Thinkpad T42 - 2374-R89 w/ 755 Dothan, 1.5gb, wd 320gig, ati 9600 w/64mb, wireless bg, bluetooth
IBM Thinkpad 390 w/ PII 233, 256mb, hitachi 60gig, linksys wireless pcmcia card
Trixie
#34 Post by Trixie » Thu Mar 26, 2009 5:23 pm
For anyone who's interested, B&H has the retail version of the Western Digital WD3200BEVE. This has a 3-year warranty. Picked mine up today.
T42 2373-B09
McLuvin
#35 Post by McLuvin » Thu Mar 26, 2009 6:47 pm
Well I've cloned the 80 to the 320 and all went well. I got an ultra 2.5" usb enclosure from tiger direct and put the 80 in it and the 320 inside as the primary drive. I had left my drive clone cd at my mom's when I replaced her hard drive so I downloaded a program called easeus disk clone mainly because my friend reccommended it, and it worked great but I also had to download their disk partition software which btw was also free to resize it all together because it just cloned the 80 gig partition and the cd that I have will do it automatically for you whether you are upsizing or downsizing. The wd 320 is great you can hardly even hear the drive at all and the t42 seems to be faster as well.
Trixie
#36 Post by Trixie » Sun Mar 29, 2009 12:22 am
I can't say if I'm hearing the same noise from the WD3200BEVE that Johan is, but I would describe it as sounding like the ticking of a quartz clock; it occurs every couple of minutes. I guess we'll just have to wait until there's more user feedback to see if this is something to be concerned about.
T42 2373-B09
McLuvin
#37 Post by McLuvin » Sun Mar 29, 2009 12:48 am
I haven't noticed anything out of the ordinary with mine but it is a lot quieter than the hitachi 80 I replaced it with.
Trixie
#38 Post by Trixie » Wed Apr 01, 2009 9:28 am
OK, after several days of using the WD3200BEVE I am reasonably sure that the laptop is running a lot hotter than with the Samsung HM160HC.
T42 2373-B09
Trixie
#39 Post by Trixie » Mon Apr 20, 2009 12:02 pm
To update, I asked WD about the clicking/ticking noise in the WD3200BEVE; they said this was not normal and it should be replaced. I'm waiting for the new one to arrive.
T42 2373-B09
madhu
#40 Post by madhu » Fri May 08, 2009 8:51 am
Trixie wrote:OK, after several days of using the WD3200BEVE I am reasonably sure that the laptop is running a lot hotter than with the Samsung HM160HC.
I am also planning to Upgrade my T42 with WD3200BEVE , is you laptop still running hot ?
Thanks and Rgds
TKuser
#41 Post by TKuser » Sat May 16, 2009 5:06 pm
I just got this drive running on my T41: see http://forum.thinkpads.com/viewtopic.ph ... 32#p508332
The drive is definitely quieter than the 7200rpm 60gb Hitachi drive I pulled out. I no longer hear clicking every time the heads move.
