carrying case
Talk about "WhatEVER !"..
tp42card
#31 Post by tp42card » Sun Jun 13, 2004 12:43 am
Nabeel wrote:Yup, it fits it perfectly. Nice and snug
nabeel, thanks. i just gone mine thru ebay. hopefully, the laptop and bag will come around the same time.
Paco
Re: kensington
#32 Post by Paco » Sun Jun 13, 2004 10:48 am
The Kensington Contour Slim fits the 14.1 notebook (including the 9 cell battery) well . There is a velcro strip in the middle of the case that straps down over your notebook to hold it in snug.
The MacTruck case at $199.99 to $299.99 is probably a good investment especially when you need to carry a hardshell case. However, if you want to travel light with a light weight briefcase check out the $40 Kensington Contour Slim Computer Case. I cannot say that the case will work well for others because individual preferences are subjective and will vary. However, I find that this bag to be very comfortable and it works very well for me. BTW, I decided to return the T41p for a T42p 2379DYU which has flexview and a 15 inch screen.
http://www.kensington.com/html/2037.html
Paco
tp42card wrote:nabeel or paco,
do the 15" kensington contour slims fit your 14 inch tps? looking at the measurements, they look tight especially in the height.
thanks.
EnsignRicki
#33 Post by EnsignRicki » Sun Jun 13, 2004 2:50 pm
Wow that's pretty slick.
EnsignRicki
#34 Post by EnsignRicki » Sun Jun 13, 2004 2:54 pm
Whoops double post. Mods please feel free to delete.
Return to “Off-Topic Stuff”
