BIOS PROBLEM
kabacinski
BIOS PROBLEM
#1 Post by kabacinski » Sun May 17, 2009 4:17 am
HELLO I HAVE A X300 LENOVO WITH BIOS 1.08 FROM FILE 7TJU07US AN WHEN I TRY TO INSTALL FLASH BIOS WHITH COMMAND FLASH2 /U I HAVE ALL TIME ERROR CHECK FAILLED RETURN CODE 92 SYSTEM DATA FILE DOES NOT SUPPORT THIS SYSTEM CAN YOU HELP ME BECAUSE I WHANT TO INSTALL AN MC8775 INSIDE MY X300
THANK YOU
FREDERIC
defor
Re: BIOS PROBLEM
#2 Post by defor » Sun May 24, 2009 1:44 pm
Indeed, this does seem to be a serious bios issue that your caps lock is stuck...
But in all seriousness, It sounds like you're booted from 64-bit os.
Make a boot floppy, and flash from that.
ThinkPads ... T61p(4x3), X61s, 820
Users browsing this forum: nitrocaster and 4 guests
