what type of trackpoint do you prefer ?
Torque
#31 Post by Torque » Wed Jun 08, 2005 3:51 pm
Navck wrote:Eeww, I hate the soft dome. It feels "too soft" (Not senstive to my movements), thats why I prefer classic still
Do they put the soft dome on every new TP now? I noticed my friend's R52 has one... I'm hoping the T43 I'm getting has one... *Hoping they give us a 3 pack*
My T41P came with the soft dome mounted. Two other caps came with the unit.
IBM T60
Navck
#32 Post by Navck » Wed Jun 08, 2005 5:47 pm
Nice, now how do you remove/add it back on?
Torque
#33 Post by Torque » Thu Jun 09, 2005 12:30 pm
Navck wrote:Nice, now how do you remove/add it back on?
You just grap it with your finger nails, and pull straight up.
IBM T60
Navck
#34 Post by Navck » Fri Jun 10, 2005 1:10 pm
Recived my Thinkpad yesterday, and swapped to classic cats tounge, I might want to try recessed bowl soon... But still love the classic cap the most.
dsigma6
#35 Post by dsigma6 » Thu Jul 12, 2007 7:22 am
Navck- Soft Rim is the man.
My fiancee was using a friends gateway the other day, and she couldn't use it because it lacked a trackpoint. I smiled!
KristianJ
Moderator1
Moderator1
#36 Post by KristianJ » Thu Jul 12, 2007 8:13 am
I've finally got around to buying a set of the 3 caps for $5.95 Australian shipped on eBay, so this time next week I'll be able to respond for certain :lol: The classic dome on my T23 is worn and needs replacing, and the soft dome on the T42 does well, but I'm keen to test the soft rim out.
X220 4291-46M
HP Pavilion dv7-2109tx
#37 Post by dr_st » Fri Jul 13, 2007 9:20 am
I used to love the soft dome, but after playing with the soft rim a bit - I find it much more convenient. You have to apply less pressure, thus your finger doesn't get as tired. Also, it relies on shape rather than on texture, so it might be longer before it is worn out and needs replacement.
#38 Post by pianowizard » Fri Jul 13, 2007 9:44 am
I wonder how many people who participated in this poll have actually tried all three types of Trackpoints. I just can't believe that 37% of the participants voted for the Classic Dome or Cat's Tongue (which I believe are the same thing). Most of these people probably have never used the Soft Dome or Soft Rim, so they are not aware of their advantages.
If many of the participants haven't tried all three kinds, then the result of this poll is meaningless.
dr_st wrote:it relies on shape rather than on texture, so it might be longer before it is worn out and needs replacement.
Excellent point. The Classic Dome gets worn out much faster than the other types.
DavidNY
#39 Post by DavidNY » Fri Jul 13, 2007 3:03 pm
I was all for Classic Cat's Tongue until I worked with the soft dome (preinstalled on my T60, though the three-pack has all three styles)
Incidentally I once bought cat's tongue caps off eBay. One lasted a couple of days, I tossed the rest. Know your source! :wink:
X61t, T60, T23, T21 (all XP), 385XD
Tõnis
Re: Trackpoint Cap Popularity Contest
#40 Post by Tõnis » Wed Jan 28, 2009 3:03 pm
I find that I have the most control with the soft rim, and I prefer it the for that reason; I can move the pointer and press to select with the rim, which is nice. The only disadvantage with it for me is that I have a tendency to hit the rim more while typing.
My least favorite is the soft dome because I find that it takes the most effort to move the thing around, probably because it's so "flat." The classic dome/cat's tongue is a compromise -- some kind of happy medium -- and I'm using it now.
R61, Core 2 Duo T8300 at 2.40GHz, 15.4" WXGA, XP Pro
Radioguy
#41 Post by Radioguy » Wed Feb 04, 2009 1:06 am
Quite a bump. ;)
I liked the cat's tongue in the day, but use the soft dome with studs now. The cat's tongue attracts too much grime, and has to be washed too often.
I would like some more colors, though. (Heresy?)
  • T61 - 6465CTO - T9500 - 15.4" LG WSXGA+ - 8GB OCZ- 120GB EVO 850 SSD - X3100 - Win 8.1 Pro 64-bit
sparta.rising
#42 Post by sparta.rising » Wed Feb 04, 2009 1:16 am
I use the cat's tongue, the soft dome takes too much pressure to use. The rim isn't bad but never used long term, might give it a go again.
As for other colors, HP has a blue cap that fits, I think the Dell Latitude D series was blue too, but the new Latitude E is grey-ish... looks like an interesting shape.
Edit: Check out http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0324017169
Z61t - C2D 2GHz CPU - 3GB RAM - 320GB HDD - 14.1" WXGA+ - Intel 950 - Travel Bezel
Radioguy
#43 Post by Radioguy » Wed Feb 04, 2009 1:26 am
sparta.rising wrote:I use the cat's tongue, the soft dome takes too much pressure to use. The rim isn't bad but never used long term, might give it a go again.
Hmm, I found it just as responsive once I retweaked the setting.
sparta.rising wrote:As for other colors, HP has a blue cap that fits, I think the Dell Latitude D series was blue too, but the new Latitude E is grey-ish... looks like an interesting shape.
I have some of these cat's tongue ones, but I was more interested in variations of the newer styles. Black, for instance as a more stealthy look. I might go back to cat's tongue if there were even more colors to try too.
vladis
#44 Post by vladis » Tue Jun 02, 2009 5:22 pm
I tryed classic, soft dome, but in my opinion the best is soft rim :-)
is there any others types ?
IBM X200 type 7459 running Windows 7. optional: 4 GB DDR3, 500GB HDD, ThinkPad BT Laser mouse
IBM T61p 15,4" WUXGA type 6458-CTO
past: T23, T60, X30, X31, X41, X60, X61
beGi
Re: what type of trackpoint do you prefer ?
#45 Post by beGi » Tue Jun 02, 2009 6:58 pm
Radioguy
#46 Post by Radioguy » Wed Jun 03, 2009 12:17 am
That thread doesn't seem to exist anymore.
I still would like other colors in the styles other than cat's tongue. A black or purple soft dome would be cool. Especially if it glowed in the dark. :D
beGi
#47 Post by beGi » Wed Jun 03, 2009 5:46 am
Soft rim (i guess that's the name) is my choice, I find it to be easiest on my finger...
OT: that link was in fact this topics link (because vladis opened new thread), I guess mods merged two threads together (but pool is gone, and the sample was pretty good in TPF terms)...
GomJabbar
Moderator
Moderator
#48 Post by GomJabbar » Wed Jun 03, 2009 6:04 am
DKB
Utwig
#49 Post by Utwig » Mon Jun 08, 2009 4:18 pm
My A21p came with classic dome, my T42p with soft dome, I ordered cap collection and put new soft dome on T42p and soft rim on A21p. I prefer soft dome of all three. Of my three thinkpads only T42p has the trackpad which has been disabled all the time. I hardly connect a mouse to any of them.
T540p, T420s (soon to be T420ps :) ), X61t, T60p, T42p, A21p
killer
#50 Post by killer » Mon Jun 08, 2009 5:08 pm
Do you really care provided there is some trackpoint available? Next door they had an HP laptop with a trackpoint (I thought it was unique to IBM/Lenovo) and I used it when trying to sort out a problem for them. It was blue, rather than red, which seemed odd. However, it worked well ... much better than a trackpad, IMO.
My preference is a bluetooth mouse but only when working at a desk.
T540p Win 7 Pro 64
Radioguy
#51 Post by Radioguy » Tue Jun 09, 2009 7:04 pm
Toshiba used them too. I think they called it a "Accupoint". They have been purple as well as blue.
mattbiernat
#52 Post by mattbiernat » Wed Jun 10, 2009 10:03 pm
i tried my friend's hp with a trackpoint. i played with it for maybe 10 seconds or so. seemed okay. if lenovo starts going down the drain in its built quality at least i know where to find alternative.
sqmaster1234
#53 Post by sqmaster1234 » Sun Jul 26, 2009 2:20 pm
Every TP I've owned came with a (What I thought was) standard Cat's tongue cap, and never use anything else. I'm much more partial to any trackpad than to a touchpad, I like being able to drag&drop as far as i want. The touchpad on my Eee is too small, I have to lift my finger to move a file/folder across the desktop, so i have to use the clicker, which is even worse sometimes. My cousin and his family usually use the reverse dome/cup caps, or the slightly wider than the cat's tongue one thats almost flat, with the bumps....
Anywho, I prefer Cat's tongue (I never called it that, but now when my cat licks me, that's all I'll think of XD) over all others. Just IMO.
