Windows 7 on T Series
Re: Windows 7 on T Series
Yeah, LEAP is a Cisco-proprietary thing.
It's very insecure, and not supported by Windows natively. I know Ubuntu Linux supported it for some reason.
A dedicated Cisco client would need to be installed to get LEAP connections working in Windows.
Intel's WiFi application use to support LEAP as well in Windows 2000/XP (but not in Vista/Win7).
Anyway, I run Windows 7 on a T43, which is several generations older than the T400, and it works great.
All IBM/Lenovo software for it has been updated over the past few months to work with Windows 7. Active Protection, power management stuff, HotKey driver, etc, etc.
ThinkPad 560X
ThinkPad T23
ThinkPad T43
ThinkPad T23
ThinkPad T43
Thanks for posting your comments. Now that Windows 7 is no longer just a release candidate, Technet has a couple of new videos on using MDT 2010: Video Part 1 and Video part 2. I am planning an upgrade across 5 laptops (3xT42 Pentium M 1.7 GHz running XP32, 1xT61 T7500 running XP64, 1xT400 T9400 running XP32). I prefer not to have both XP and Windows7 in separate partitions on the same hard drive.
- Can you comment on the best way to take these T series thinkpads from XP PRO to Windows7?
- What are your thoughts on using Microsoft Deployment Toolkit (MDT) 2010?
- Would you recommend using MDT 2010 instead of a clean OS install?
T61-6459 CTO 2.2GHz 4G 320G XP64
T42-2374 JU4 1.7GHz 2G 40G XP-SP2, T42-2373 6VU 1.7GHz 1G 40G XP-SP2
T40-2374 XYZ 1.5GHZ 1G 40G XP-SP2 , T30 & T23 retired
TheStranger2007
I have T60 2007-c4u running Windows 7 RTM.
The one thing I cant get to work ( and I could not get to work with the win7 RC version) is the hotkey feature.
This is what shows on your monitor the volume bars when you hit up/down on your keyboard.
http://www-307.ibm.com/pc/support/site. ... .html#hotf
is what I tried downloading and installing.. no go!
any ideas? anybody have luck with this?
ThinkPad T60 2007-C4U
Windows 7 RTM
T2500(2GHz), 3GB RAM, 300GB 7200rpm HD, 14.1in 1400x1050, 64MB ATI Radeon X1300, CDRW/DVDRW, Intel 802.11abg wireless, Bluetooth/Modem, 1Gb Ethernet, UltraNav, Secure chip, Fingerprint reader, 6c Li-Ion batt, Win7 Pro
Windows 7 RTM
You need to install the system interface drivers also. I believe they need to be installed before the hotkey driver.
For volume keys work. Brigthness does change but there is no OSD.
Mats
Mats
any takers?2think wrote:What are your thoughts on using Microsoft Deployment Toolkit (MDT) 2010 versus performing a clean OS install?
At which series level did this t series start coming with W7 Restore Discs?
by fefrie » Fri Apr 21, 2017 10:35 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 680 Views
Last post by w0qj
Sat Apr 22, 2017 5:18 am
- 1353 Views
Last post by ThinkPad560X
Fri May 19, 2017 1:57 am
x1 4th Generation with Windows 7 or 5th generation with Windows 10 - which to buy?
by mirc » Wed Apr 19, 2017 11:50 am » in ThinkPad X1/X1C - 5 Replies
- 554 Views
Last post by wpyh
Sat Apr 29, 2017 10:32 pm
- 570 Views
Last post by KingBubba
Sat May 13, 2017 11:26 am
