760EL 32 bit USB PCMCIA card will not work under 2000/XP
MrRedPants
MrRedPants
A full install of linux OS?
I am considering and will, however I'd love to know that it will work for sure before I wipe the current win 2000 OS.
Plus, I wasn't sure if I could find an old Linux OS that would run well on a system with these specs. I have some experience with linux installs (distrowatch, etc), but, it's limited.
MrRedPants
I hope we're talking about the same thing altogether.
This is IBM think pad configuration utility 1.19d
When I click on PC Card Slots button, I don't get an option to enable cardbus.
It's the window that displays hardware devices with a title "unplug or eject hardware" (with no devices listed of course). Check boxes for display device compoonents and show unplug/eject icon on the taksbard. I must be missing something.
Yes, it is ThinkPad Configuration Version 1.19, Utility version 1.19d.
When I click the little PC Card Slots icon with the green light next to it up comes a popup window that says PC Card slots at the top. There is a General tab and an Allocated Resources tab. On the General tab there is an option to Enable or Disable Cardbus and a setting for the IRQ you wish to use. Below that is a button that says "PC Card Properties" and another button that says "Device Manager".
My 760EL & 760XD both have this.
MrRedPants
Well, I finally got it to work - and finally saw the PC Card options as you've described. What did it take?
I reinstalled Win98SE with this technique:
1.) First I downloaded all available drivers and instructions from here:
http://www-307.ibm.com/pc/support/site. ... MIGR-59734
2.) flashed the BIOS as instructed by IBM.
3.) Then I installed Win98 SE as desbribed here:
http://stderr.org/pipermail/thinkpad/20 ... 11543.html
4.) I then applied the unofficial win98 service pack from here:
http://exuberant.ms11.net/98sesp.html
5.) Installed the PCMCIA card driver (I was / am using a 32bit wireless card - Netgear WG511) - the card was recognized but wouldn't work (yet) - no IRQ assigned. When I looked at it under device manager, yellow exclamation with no IRQ - it allowed me to enable IRQ steering and reboot but nothing would happen.
6.) Updated video driver
7.) Installed thinkpad utilities - low and behold NOW I could see the options everyone has mentioned before. I clicked PC Card, enabled cardbus and rebooted and HOLY S***, it worked!! Card was recognized, I joined my wireless network and I was off and running.
The only thing I haven't done is installed the audio/modem driver package (MWave) - I don't need either one and am nervous if I install them something will get screwed up and I'll have to start over. It's pretty cool - I am using remote desktop to remote into my xp pro machine and control it from this great old laptop!
I'm quite happy - I hope this works from all other's that have had issues.
MrRedPants
Does the 760ED have a modem?
I notice on the side there is a icon of a phone and beside it there is what looks like a removable flap... yet it doesn't seem to be removable.
Is this where the modem would go if there was one? Or am I just too stupid to pull the socket cover off of it.
760ED All the way.
FEEL THE BURN! From the bottom of that particular laptop... right in the bawsack! eek
Yes, that's where the modem would go if you had one. If the cover is there then you don't have the modem.gearguy wrote:Does the 760ED have a modem?
I notice on the side there is a icon of a phone and beside it there is what looks like a removable flap... yet it doesn't seem to be removable.![]()
MrRedPants
On the page for the SVGA Bios update it tells me that for my Laptop I must use the:
"IBM ThinkPad 760E-760ED XGA System Program Service Diskette"
Now, Where exactly do I get this from?
A quick search of various keywords and that sentence seemed to be fairly fruitless, at most taking me back to the SVGA update page.
Any help?
Thanks in advance
Any help?
Thanks in advance
760ED All the way.
MrRedPants
I think I'm reading your question correctly.
The BIOS update for XGA can be downloaded from here under BIOS:
Insomniac1971
Hi, all I come back after being away for a while and sad to see that the Cardbus issue has not been solved:(
I removed my Win2000 and installed ME instead on my 20GB hdd(working if you install Ontracks diskmanager). ME is not that good to handle memory and freezes up several time, but there is some hacks on the net to get it to work.
Still I wish that I could get Win2000 to work:)
Now I'm looking to buy another IBM laptop, since the 760XL only have 1Mb Video RAM and i want to use a laptop for video as well:) But I will keep my old 760XL and still mess around with it:)
If I ever should find a solution for this probleme then it will be posted here:)
With regards
Jan
With regards
Jan
Live life to to fullest:) I do!
Insomniac1971
farmer kev
The 770 series is selling cheap on evilbay now, some have 4mb video, all have built in USB and most 13.3 or 14.1 inch lcds. They use yet another style hard drive caddy with the connector on the side. They also have the largest ultrabay which can take a 2nd regular 770 battery, there is an adapter piece to help hold it in.Insomniac1971 wrote:
With regards
Jan
Down side is its a heavy (7+lbs) machine. Many came with DVD hardware.
My latest TP600E 2645-55U
My first TP355 2619-l15
Insomniac1971
Anyone know what kind of RAM it takes there is alot on the market for different prices:) I was thinking that if it can take pc100 that would be nice:) I have my eye on some :
KTM-TP770/128
KVR100X64SC2L/128
KVR100X64SC3/128
KVR66X64SO/128
The cheapest one of course:)
I bought the laptop, Thinkpad 770Z and it has build in 64MB and can be upgraded to max. 320MB.
The Cpu is a PII 366Mhz which for what I can tell is running 66Mhz on the motherboard. And it has USB:):):)
So now I'm shopping for a USB netcard and Bluetooth adapter for 100m:) I want to see if I can set up internet connection sharing by Bluetooth:)
Next thing I will buy is a USB or PCcard TV tuner for it:)
Jan
KTM-TP770/128
KVR100X64SC2L/128
KVR100X64SC3/128
KVR66X64SO/128
Jan
Insomniac1971
Hi All, I'm back with new info that began as I had problems getting my TP 760 XL to work with 2000/XP and ended up with me buying another laptop:) I bought a TP 770z and that I have not regreted, its a wonderfull laptop and now I have set i t up with Bluetooth internet sharing and that works just fine:) I added extra 128MB memory, so total is now 192MB, and now XP pro is running just fine.
Video is great and with the USB 2.0 pccard I can use an external CD-RW/DVD drive just fine, but I would not recommend anyone to add an internal DVD drive because the internal controller is not fast enough. Neither is LPT or PCMCIA controllers, it will work but sound will be distorted. Just a warning.
If you want to use CD-RW or DVD or a combo drive then use a USB 2.0 drive.
The laptop burns cd's just fine but I would not try with a DVD burner, for that the laptop is not fast enough.
If you have a drive already but its not USB then you can buy an enclosure (casing) like I did and add the drive in this. I bought a Delock but there are others on the net. The Delock though has something really great, it comes with an USB and ps/2 power cable so if you are on the move you can use drive just fine, no need to use the power adapter. The power adapter is included in the pakage just in case you want to use it.
Make sure that the casing has a USB 2.0 controller and make sure it fits the controller in the case, most drives has a standard connector in the right side of the drive when looking at the back, but not all.
Here is a picture of the standard connector: http://www.logicsupply.com/images/cddvd ... y_pic2.jpg
If anyone has questions or problems regarding this laptop feel free to contact me or just leave a message in this forum, I'm monitoring this thread.
With kind regards
Jan
With kind regards
Jan
I have a question for the people who have correctly installed windows2k or windowsXP on the TP 760 series.
Where do you find the driver for Audio and Video Devices? I've installed win2k on my TP 760XD but the only device that don't work correctly is Audio And Video (in the "device manager" window)
thx
thx
Insomniac1971
Well do you have the configuration utility loaded? If not then get it here:
http://www-307.ibm.com/pc/support/site. ... SHY-3XZMX3
and this small fix for it:
http://www-307.ibm.com/pc/support/site. ... IGR-4HT3RF
Remember that XL and XD is not that different! Most of the time you can use the same drivers.
Here is a small fix if you want to run WinME instead, after this its not so much a memory hog. http://www.mdgx.com/me2.htm
Here you should be able to find alot of info on you laptop:
http://www-307.ibm.com/pc/support/site. ... idate=true
Here is another important thing you should read:
http://www-307.ibm.com/pc/support/site. ... IGR-4FUQKX
Get Astra32 and find out what kind of video card you have down to the excact chip, then write it here and I shall try to help you find a driver if it exist. Do the same with the Audio.
Jan
Jan
Identify Wifi Card Win 7 64 bit X230 & missing bits device manager
by blink » Tue Feb 28, 2017 8:56 pm » in ThinkPad X230 and later Series - 3 Replies
- 481 Views
Last post by w0qj
Tue Mar 07, 2017 3:55 am
Camera LED does not work? Make sure it's not taped over. :)
by dr_st » Sat Feb 18, 2017 12:00 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 802 Views
T61 pcmcia sd card reader extremely slow
by alisan » Thu May 25, 2017 6:14 am » in ThinkPad T6x Series - 10 Replies
- 553 Views
Last post by Omineca
Thu Jun 01, 2017 4:47 pm
SOLD: PCMCIA Smart Card Reader/writer
by RealBlackStuff » Thu May 25, 2017 10:56 am » in Marketplace - Forum Members only - 0 Replies
- 145 Views
