New Desktop Thread - Show your pics!
Temetka
#121 Post by Temetka » Tue Dec 27, 2005 1:24 am
Thanks. I got some of the nature ones. Since I can't read russian, I cant find anything else.
AndyL
#122 Post by AndyL » Tue Dec 27, 2005 10:06 am
stevezasycho wrote:Nothing.. I HATE icons on my Desktop.. (Which is why I could go back to Windows 3.1 if it were powerful enough lol)
If you go back to Windows 2000 you can still use the Windows 3.1 program manager (start/run progman.exe), you can even make it the shell in place of Windows Explorer :) The Windows 3.1 file manager (winfile.exe) was in NT 4.0 but dropped in Win2000 I think - shame!
eri7154798
#123 Post by eri7154798 » Tue Jan 03, 2006 8:26 am
johnchan
#124 Post by johnchan » Tue Jan 03, 2006 9:06 am
what kind of skin are you using? that isnt really longhorn is it? what about your desktop, on the lower left hand corner, what are you using for that?
T43
2668 A1U
1.86Ghz
1GB RAM
14.1" 1400X1050 SXGA+
ATI X300 64MB
60GB HD 7200RPM
Intel 2200BG 802.11b/g
Fingerprint reader
eri7154798
#125 Post by eri7154798 » Tue Jan 03, 2006 10:03 am
no..it's windows xp that got customized with some stuff from neowin.net
the "skin" that i'm using is really a theme called royal four(with the black graphite(compact) appearance, that i got from benz off this thread. you can find royal four here:
http://www.neowin.net/forum/index.php?s ... =royalfour
to install it follow these directions from benz:
Sure, since several people have been asking, here's a little tutorial for installing the Royal Four theme onto your Thinkpad:
1.) Download and install the UXTheme multi-patcher to safely mod your uxtheme.dll file, so that you can install custom themes such as this one.
2.) Download the Royal Four visual style and unzip the files onto your desktop.
3.) Copy the folder "Royal Four" to the directory "C:\WINDOWS\Resources\Themes" or whatever your main windows directory is.
i used the longhorn transformation pack from windows x off neowin.net...it changed my icons, boot screen, and made my windows transparent(as far as i can tell). that can be found here:
http://www.neowin.net/forum/index.php?showtopic=75768[/img][/quote]
johnchan
#126 Post by johnchan » Tue Jan 17, 2006 1:51 pm
also what kind of resolution is that?
T43
2668 A1U
1.86Ghz
1GB RAM
ATI X300 64MB
60GB HD 7200RPM
Fingerprint reader
eri7154798
#127 Post by eri7154798 » Sat Jan 21, 2006 1:34 am
1600x1200 UXGA from the T42p
mike085
#128 Post by mike085 » Sat Jan 21, 2006 10:36 pm
T42 2378DXU
kjempe
#129 Post by kjempe » Thu Jan 26, 2006 1:38 pm
ok, here comes mine.
1. plain desktop:
http://yotambien.net/images/screenshotone.png
2. in action:
http://yotambien.net/images/screenshottwo.png
it`s basically gnome with clearlooks graphite, opus 3 and dropline neu! icons. i got the wallpaper from deviantart.com
padpad
#130 Post by padpad » Thu Mar 30, 2006 6:25 am
after a fresh install, here is mine...
T42(2373-K5U)/
P-M 735 1.7G/
512MB*2/
40GB/
14.1' SXGA+/
64MB ATI Radeon 9600/
CDRW-DVD/
Intel 802.11bg/
WinXP Pro SP2/
fingerprint reader
