Not yet. The amount of play in the lid is stable, and otherwise, the hinges are firm. I will wait until (1) the hinges get looser, (2) I need other warranty service, or (3) the four-year warranty expires and I want a new machine. ... JDHbautista.ekonomista wrote:<snip>
Jdhurst, have you already had your hinges replaced? I hope you already did.
Thanks a lot!
Hinge Issues
Re: Hinge Issues
Re: Hinge Issues
So what are the part numbers for the hinges that do not wobble for the T60, T60P 14" and 15"?
I can write a note to the tech when I send my T60 14" in to intsall the good hinges I guess.
This space for rent!
Send PM.
IBM (No Lenovo logo on LCD bezel) ThinkPad T60 2623-D6U, Core Duo 1.83 Ghz, 14.1" SXGA+, 4GB RAM, Hitachi 7k320, Windows XP Pro SP3
Lenovo ThinkPad T500 2055-2CU, Core 2 Duo 2.53 Ghz, 15.4" WSXGA+, 8GB RAM, Hitachi 7k750, Windows 7 Ultimate 64 Bit
Send PM.
Re: Hinge Issues
Dream on!ARD wrote: I can write a note to the tech when I send my T60 14" in to intsall the good hinges I guess.
Keith
(Formerly 600E 2645, T30 2366, X31 2673, T40 2373, T41 2379, T42 2373, T42 2379, T60 1952, T61p 8889, T61p 8891
Currently T420 4177-CTO, T430 2347-A54, T430 2347-UN9, T430 2349-L64, T430 2342-CTO, H520S 2561-1LU, Ideapad K1)
Re: Hinge Issues
There is no doubt in my mind that he can write a note.sktn77a wrote: Dream on!
Whether anyone actually looks at the note and does something other than ignore it is a bigger question.
eskimochaos2
Re: Hinge Issues
What do you think happens when you want to test out the accidental warranty protection on a flight of stairs AND its a 4year old model?Not yet. The amount of play in the lid is stable, and otherwise, the hinges are firm. I will wait until (1) the hinges get looser, (2) I need other warranty service, or (3) the four-year warranty expires and I want a new machine. ... JDH
Just saying.....?
bautista.ekonomista
Re: Hinge Issues
I tried doing that when I asked the service depot guys to replace my defective keyboard with a new one having an NMB part number.ARD wrote:So what are the part numbers for the hinges that do not wobble for the T60, T60P 14" and 15"?
When I got my Thinkpad back, they said that they got the old FRU part # for the replacement keyboard. Haha.
I hope they'll grant your wish to have a specific FRU part # to replace the old defective hinge. But it's more likely that they'll install a new one based on the previous FRU part # of the hinge.
Current flame: ThinkPad X230 * i5-3320 2.6Ghz* 320GB HDD * 8GB RAM * Centrino N-6205 * Intel HD4000
Old flames: MBP 13" early 2011 * i5-2415 2.3Ghz * 500GB HDD * 8GB RAM * Intel HD3000 /// ThinkPad T61 * T7500 2.2Ghz * 160GB HDD * 3GB RAM * Intel X3100
carbon_unit
- Moderator Emeritus
Re: Hinge Issues
I had a technician do an on-site repair of the hinges on a T60 yesterday. I was out on a call all day so I have no idea which FRU# hinges he used. I will have to hope for the best. At least they are tight right now.
T60 2623-D7U, 3 GB Ram.
Dual boot XP and Linux Mint.
Registered linux user #160145
Truthfinder
Re: Hinge Issues
Hi gang:
I have had to tighten my hinge screws once since purchasing my T60 three years ago. At this point, I have just about 0% play in my hinges / lid. It may be a result of my not opening and closing the lid very much or the fact that my T60 is from an old pile of plastic with the IBM logo...... So far, so good.... My lid / hinges feel as tight as they were when my system arrived three years ago. Hopefully they will stay tight.
Best to all, Steve
Best to all, Steve
ThinkPad T-60 2623D7U, 4GB Kingston HyperX / ThinkPad T-60P 2008-83U , 4GB Kingston HyperX.
Running Windows 7 on both units. Dedicated ThinkPad user for about 18 years.
Re: Hinge Issues
Just to clarify, we aren't talking about the screws on the bottom that secure the hinges to the T60 case; we are talking about the hinges themselves.Truthfinder wrote:Hi gang:
Best to all, Steve
They can't be adjusted or tightened; only replaced.
Send PM.
Send PM.
Re: Hinge Issues
Is the new part (FRU 45N4181) compatible with 14.1" wide T61's?
Or to ask in a different way, are the hinges of 15.4" and 14.1" widescreen models interchangeable?
I'll ordering some parts soon and I was wondering if the new part would work or if I should just order the standard Reell hinges.
T61 14.1" wide 7664-19G
Re: Hinge Issues
I'm going to post to a thread that hasn't had activity for a year-and-a-half! The right-hand hinge on my wife's 14.1" T61 broke and I just replaced them with these, ordered from seller thinkpad_2007 on Ebay: http://cgi.ebay.com/New-Lenovo-T61-14-1 ... 0659878261.
The part numbers referenced are 42W3653 (the old Reell number, I think) and 42W2005, which appears no where that I can find on a Lenovo parts list.
Bottom line: Communication was decent and shipping at the intermediate tier really fast from China (maybe 4 business days), but the hinges are quite loose. They don't have wiggle, which the original hinges were exhibiting before the failure, but the screen flops both back and forward when you have it at any appreciable angle. The seller says these are the same parts Lenovo uses, which I'm not sure I buy, but that's that.
Anyway, short of forking out major bucks to Lenovo for similar parts, these are an option, but maybe not the best.
If anyone knows of a trick to make existing hinges tighten up, please post ideas. Seems impossible, but thought I'd ask.
Re: Hinge Issues
I do not think you can tighten the hinges if they are properly installed (tightened to the base and lid properly). That is, the hinge itself cannot be tightened.
After 4 years, the hinges on my T61p are modestly looser in terms of play, but no side to side or twist wiggle. I think my warranty is coming up, so I will leave it the way it is, because (otherwise), the machine is working fine.
.... JDH
.... JDH
Re: Hinge Issues
I'm working on two T61s with loose hinges right now. The issue is fairly simple. The lower part of the hinges have holes that the upper parts pivot in. The design doesn't seem to hold up very well and the holes get worn oversized pretty quickly. Hotdog in a hallway, if you will. There's no fix or tightening to be done.
I just ordered a couple sets from a US seller on eBay for about $12 a pop. We'll see how they hold up.
And I never had this trouble with my X30.
Re: Hinge Issues
My T61p just came out of warranty - I ordered it in March of 2008. During that period of time I sent it in 3 times to have the hinges replaced. I also had to exchange the DVD burner twice as it would read but not burn media. Other than those issues and the fact that I have the Nvidia "flaky crust" GPU that is going to go belly up on me at some point, the T61p has been a good machine.
The last set of hinges went in over a year ago and they are holding up OK. The laptop never leaves the house and I never grab it by the open lid and do this to it:
http://en.wikipedia.org/wiki/Hammer_throw
The hinges in these units are not real good.
2011 MacBook Pro 17" non-glare 2820QM 8GB 256GB SSD
T61P - 6459CTO - T9300 - 15.4 WUXGA ++ E6600 desktop, HP dv6000, P4 desktop w/ RAMBUS
Previous: P3 desktop, P1 desktop, 386-40Mhz desktop, 386-20 Mhz desktop, 10Mhz TURBO XT clone, Commodore Amiga 1000, 128, 64, VIC-20
Re: Hinge Issues
True - the hinges on the T61p are not good. But I am still on the original hinges. I purchased the machine in March, 2008, so it is three years old (not four as I suggested earlier).
The hinges had about 0.25" play at the top almost from new. It about 0.5" three years later. Annoying, but not worth replacing (noting that new hinges do not last very long anyway). ... JDH
scillyisles
Re: Hinge Issues
I had two T61p both model 6457-BQG. The one I gave to my son (an August 2008 build) developed the Nvidia problem and the loose LCD hinges with play in them . It recently went away to be repaired and Lenovo replaced the hinge assembly to cure the loose LCD lid as well as replaceing the main system board to cure the Nvidia problem. My other T61p does not have this loose hinge problem.
2373-Q1U T42p 2.1Ghz P4M 2GB RAM, ATI Firegl , 320Gb,15" LCD,Win 7 Ult
6457-BQG T61p 2.6GHz C2 Duo 4GB RAM, 320GB 15.4in LCD,FX 570M, Win 7 Ult
2758 W700 QX9300 2.53GHz 4GB ram, 200GBx2 BDWriter, 1GB FX3700m,17" Win 7 Pro
4319-4NG W510 i7820QM,8GB,320gb,15.6 FHD,FX880M,Win 7 Pro
Re: Hinge Issues
I'll post this now that I've gotten the hinges. I ordered two sets from this guy:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0601665151
They appear OEM, they have no slop or wiggle, and the action is quite tight. No screens flopping around. I have no clue how long they'll hold up in the long term, but I guess you can keep spares on hand.
hjanzen
Re: Hinge Issues
From the picture at this ebay offer it seems these are hinges with the longer RH arm for T61 14.1 WIDE.
Correct???
Correct???
- 0 Replies
- 774 Views
Sun Mar 26, 2017 8:50 am
- 2 Replies
- 489 Views
Last post by Sudevan
Sat Jan 28, 2017 8:21 pm
- 0 Replies
- 1122 Views
Last post by pdrachman
Wed Mar 01, 2017 2:34 am
Lots of issues w/ X61s drivers
by wujstefan » Thu Mar 30, 2017 3:16 pm » in Thinkpad X6x Series incl. X6x Tablet - 9 Replies
- 1629 Views
Last post by wujstefan
Mon Jun 26, 2017 8:16 am
