T40 died, T43 from ebay to replace. No HDD recognition
branflake12
Re: T40 died, T43 from ebay to replace. No HDD recognition
#61 Post by branflake12 » Wed Sep 30, 2009 9:47 am
Will a single 2GB stick of pc 5300 work if i empty the stock ram out of the first (keyboard) bay? 2GB sticks are only like $2 more than 1GB sticks im finding. I know it would work on any of the towers i've built, but laptops arent my "domain" so to speak.
killer
#62 Post by killer » Wed Sep 30, 2009 11:14 am
I use Crucial's website to do the configuration of RAM. It will tell you exactly what you need.
http://www.crucial.com/
T540p Win 7 Pro 64
#63 Post by RealBlackStuff » Wed Sep 30, 2009 12:11 pm
No it will NOT work.
Those T43s have a limit of 2x 1GB RAM.
branflake12
#64 Post by branflake12 » Wed Sep 30, 2009 1:07 pm
Thats what i needed, twin 1GB sticks of 5300 on the way. Thanks guys.
#65 Post by rkawakami » Wed Sep 30, 2009 6:48 pm
killer wrote:I use Crucial's website to do the configuration of RAM. It will tell you exactly what you need.
Yes it will, but in some cases they are still using old information. For example, if you select an A31p (2653), Crucial says that the maximum memory is 1GB. I think you'll find a lot of people here that are using 2GB in those systems.
