You know you're a die-hard Thinkpad addict when...
dsigma6
Re: You know you're a die-hard Thinkpad addict when...
When you haven't used a ThinkPad in a loooooooooooong time, yet you keep coming back here after periods of inactivity (last here in June!), keep defending ThinkPads against haters, and wonder what Ray is up to. lol...
Harryc wrote:...you plan to get the latest model Thinkpad even though the last model you bought 6 months ago still looks and runs like new, and was way overkill for your needs to begin with .
I like ThinkPads enough that I have them not only in my home and at work, but also in my car! Here's a picture, for those interested.
X230t 3434-CTO
T410s 2912-2DU
T43 2668-71U
T410s 2912-2DU
T43 2668-71U
Agreed, and while having extra batteries around, it's not a good thing to keep them in the fridge. The moisture is not a good thing for modern day batteries like it was for the old kinds of C D and AA models.DomiNick wrote:I have only one Thinkpad but sometimes I feel like an addict. I am a heavy user and I spent hours and hours on my Thinkpad. So I am maybe not one of the really bad addicts but I would consider myself an advanced beginner
There's enough problem with fires without adding to it by storing them inappropriately. I'm betting the OP wouldn't mention the storage method should he return a unit for repair after using one.
As for my You know you're a Thinkpad addict when: You use them at work and at home and your Thinkpad at home is a W700ds.
emeraldgirl08
I've stopped putting batteries in the fridge! I noticed moisture when the batteries came to room temperature and figured that it wasn't a good idea. The condensation also took forever to disappear so... not a good idea!
I'm still loving my two remaining Thinkpads I have and have experimented with AVI transcoding on my R51e. The result wasn't too shabby. The laptop did not get extremely hot and the fan did not come on loud enough to send me in a panic. I think my expertise
in thermal compound application, raising the rear of the laptop, and keeping my fans clean helped with heat dissipation
I did not notice an intake exhaust anywhere on my laptop like previous Thinkpads but figured the more air circulating under the laptop the cooler it would be.
oh and Gburnore...lol I'd like to be referred to as "she." Thanks.
First, very sorry. Shows I don't read well?emeraldgirl08 wrote:I've stopped putting batteries in the fridge! I noticed moisture when the batteries came to room temperature and figured that it wasn't a good idea. The condensation also took forever to disappear so... not a good idea!
Second a tip. If you DO get moisture in/on your battery, buy a bag of rice and stick the battery in it for a day or so. Like putting rice in your salt shaker, the rice attracts the moisture away.
emeraldgirl08
gburnore wrote: First, very sorry. Shows I don't read well?
Thanks for the rice/battery recipe! I would not even have thought of that if you hadn't mentioned it! Have a good nite
proaudioguy
Curious what are you doing with that little X in your car? I understand the law enforcement angle but I can't think of too much else. I have been known to use mine for maps now and then before the GPS investment.
I use it with MS MapPoint 2009 for GPS/navigation (MapPoint also does trip planning, fuel economy, etc). I have an OBDII to USB cable connected to it, so it provides and logs data from a number of sensors in the car. I also use it to listen to music.proaudioguy wrote:Curious what are you doing with that little X in your car? I understand the law enforcement angle but I can't think of too much else. I have been known to use mine for maps now and then before the GPS investment.
X230t 3434-CTO
T410s 2912-2DU
T43 2668-71U
T410s 2912-2DU
T43 2668-71U
I'm extremely well rounded with the T4x series, but I doubt I could do it blindfolded.underclocker wrote:You know you're a die-hard Thinkpad addict when...
...when you can completely disassemble and reassemble a particular model ThinkPad without consulting a Hardware Maintenance Manual or even a pause in your work or a mistake - and with no left over parts. I suppose there were earlier indications, but that's certainly a confirmation. I can practically tear down and rebuild a T4x or R5x machine blindfolded.
ThinkPad X200
Think Different
Think Different
Nigellus
I'm not an addict, I can quit anytime I want... I think...
Actually, I have one 600E, two spare 600Es for parts, and an old working 755Cs that I refuse to get rid of...
And I have struck up conversations with other ThinkPad users about their machines. However, only 1/3 seem to know much about the quality of computer they actually have.
T420 i5-2520M 2.50GHz 4 GB RAM 64-bit OS WIN7pro SP1
T60 1951-46U Intel Core Duo 1.83GHz 1 GB RAM 60 GB XPpro
TP 600E 2645 PII 366MHZ 160MB RAM 37.2GB WIN98SE
Computers do exactly what you tell them at amazing speeds; this can be bad if what you told them wasn't what you had in mind.
When... You obliterate your budget on a 3rd Thinkpad... :sigh:
When you'd rather have a WorkPad C505 than a cheaper Palm m515 with twice the RAM because it looks better with the ThinkPad?
When your wife has a nightmares about Thinkpads. - Just last night.
Some call me...Tim.
Present: T420 | Acer C720 Chromebook
Past: T500 || X61T || X60T || R50 || X30 || T30 || A31p || 3xx || 600E || Intellistation Z Pro
crashnburn
When you diss MacBooks for Thinkpads
When you buy Thinkpad parts because, "I might use that someday" even though you don't currently have a system that it'll work with.
Some call me...Tim.
t140568 wrote:
I gotta give it to both of you - that's a very serious first in my experience when it comes to marriage and/or ThinkPads...When your wife has a nightmares about Thinkpads. - Just last night.
Exactly describes my purchase a couple of months ago of two Ultrabay Enhanced DVD Multi drives and nothing yet to put them intot140568 wrote:When you buy Thinkpad parts because, "I might use that someday" even though you don't currently have a system that it'll work with.
That is a common thing collectors do when they are expanding the collection.t140568 wrote:When you buy Thinkpad parts because, "I might use that someday" even though you don't currently have a system that it'll work with.
Collection: 310ED, 350C, 360C, 365C, 365XD, 380D, 380XD, 380Z, 390E, 390X, 560X, 600, 600E, 701C, 750CS, 755C, 755CD, 760C, 760CD, 760ED, 760EL, 760XD, 760XL, 765L, 765D, 770, 770E, 770Z, T21, T22, T23, T30, A20P, A21P, A22M, A30, A31, A31P, T40, T42, T43P, T60, T61, R32, R40, R52
Thank you guys! I wanna get to know you more!
by Whitieiii » Sun Jan 22, 2017 6:52 am » in Off-Topic Stuff - 2 Replies
- 565 Views
Last post by TPFanatic
Sun Jan 22, 2017 11:51 pm
65W vs 90W power supply: how does it know?
by mvan » Sat Jan 07, 2017 12:27 pm » in ThinkPad X200/201/220 and X300/301 Series - 2 Replies
- 884 Views
Last post by mvan
Sat Jan 07, 2017 12:59 pm
What computer have you had for the longest? When did you get it?
by pianowizard » Tue Jun 27, 2017 6:51 am » in Off-Topic Stuff - 8 Replies
- 178 Views
Last post by TheAuldMan76
Wed Jun 28, 2017 1:37 pm
WTB Ultrabay Hard Hard Drive Adapter
by taichi » Tue Jan 10, 2017 11:12 pm » in Marketplace - Forum Members only - 5 Replies
- 623 Views
Fri Jan 27, 2017 3:02 pm
