Power manager, disable "non genuine" battery warning?
Re: Power manager, disable "non genuine" battery warning?
Does anyboby try to modify PM1.99l for XP 32-bit. I've tryed but it doesn't work.
T60p 14", T60p 15"
It worked with my T60, 32-bit PM version 3.20,
Thanks rrtdj, you're really awesome
Rrtdj, you're my idol. Thank you so much!
I've replaced the battery in my T60 today, as the "genuine" Lenovo one genuinely stopped working and would in fact make the laptop freeze randomly (yet another testament to the Lenovo quality: the previous battery was also faulty, of the exploding kind) and suddenly I got this ridiculous, nagging message with the perpetual exclamation mark in the tray because I dared to use an "unauthorized" battery. "Unauthorized" is it really, Lenovo? I paid for this laptop, it is my property, and I authorized myself to do whatever I want with it.
Anyway, all of this is now gone, thanks to your patch. For anyone in need, here's the link to the last patchable version (3.61):
http://download.lenovo.com/ibmdl/pub/pc ... u408ww.exe
The patch does a great job for the tray, but it does not remove the message in the Power Manager window. The message is saved in the file (typically, for US English):
The message is located in String Table 45, and its ID is 709.
The file can be edited with XN Resource Editor, a free utility available from:
http://www.wilsonc.demon.co.uk/d10resourceeditor.htm
I have changed the message in my file to:
Thank you again, Rrtdj!
C:\Program Files\ThinkPad\Utilities\US\pwmrov.dllThe file can be edited with XN Resource Editor, a free utility available from:
"You have made the right choice not purchasing a genuine Lenovo battery. In the recent years, hundreds of thousands of genuine Lenovo batteries have been recalled due to quality issues. Some of them have even been known to ignite spontaneously, which could cause human injury and damage to property."
701C (the Butterfly), 360CSE, 370C, T20, X31, T60
hey guys, any idea for the xp version of the power manager? thx
There may be a simpler way [WIN7 64bit]; try this:
Launch Power Manager
Click on OPTIONS
Uncheck “Periodically show message about battery charge capacity”
Click APPLY
Click OK
For me, the nag stopped and all I gave up was the popup messages about charge capacity, which I can otherwise get if I really need it.
Click on OPTIONS
Click APPLY
Click OK
yup, that solves the pop up, but not the warning triangle
I would like to add that I have sucess with power manager version 1.99a for winXP. The file is still available on Opendrivers.com or search for 8mu705ww.exe on the web.
I find the require string in the PWRMGRTR.DLL after the files unpacked itself into the directory \DRIVERS\WIN\PWRMGR. I actually patched the dll before installation, which went smoothly without complaining the altered file. And then it just worked with my third party batteries, no more complaints
Thanks again to RealBlackStuff for sharing the knowledge!
I have just upgraded to Win7 x64 on my X61 to fully utilize its 4Gb ram, and found that in Power Manager version 3.67 ( http://download.lenovo.com/ibmdl/pub/pc ... u417ww.exe ) the PWMTR64V.DLL still has the required code segment while the PWMTR32V.DLL doesn't. So for 64 bit OS the ver 3.67 is still patchable to get rid of the third party batteries warning.
Hey guys here's offsets for the latest Power Manager v6.61.1
PWMTR32V.dll
File offset 0x995D8 change from 0x74 to 0xEB
File offset 0x995F3 change from 0x74 to 0xEB
PWMTR64V.dll
File offset 0xB79BF change from 0x74 to 0xEB
File offset 0xB79D8 change from 0x74 to 0xEB
Please note I have not tested these yet and I will see about patching any other nags that may have been added.
PWMTR32V.dll
PWMTR64V.dll
What are offsets for the latest version?
I cant find in DLL those offsets from previous post.
Assuming the patch given by Ember was working, the following should be working for version 6.64.4 :
PWMTR32V.DLL :
0x9B4B8 : change 74 to EB
0x9B4D3 : change 74 to EB
PWMTR64V.DLL :
0xB9B6F : change 74 to EB
0xB9B88 : change 74 to EB
Good luck, I cannot test it.
PWMTR32V.DLL :
PWMTR64V.DLL :
Please excuse my bad English.
Thanks, it works!IbmPad wrote:Assuming the patch given by Ember was working, the following should be working for version 6.64.4 :
PWMTR32V.DLL :
PWMTR64V.DLL :
Shame to Lenovo programmers that create those annoying messages.
whateverest
I have version 6.64.4 installed, but could not find these items to change. Tried a hex editor and a dll resource editor, but did not manage to apply the changes. Can somebody help how to do this exactly? Thanks.
whateverest, this is how i got it to work for me. Might not be the best way but it was successful........
I pulled the hd that had power manager installed and edited in another computer (couldn't shut down all the processes)
I used HxD hex editor
Open files
Under search>goto I entered 9B4B8 which takes you to the exact place to change 74 to EB
Repeat with the other entries
save
Open files
save
Hello again guys. I've updated to Power Manager 6.66.3 and need to do the same operation again. But there is no the same values on previous offsets. Please tell me new offsets or teach how to find them by myself.
The general approach in such cases is to find the old version (where it works), find the offset where the patch was applied, and search in the new version for the same sequence of hex values that was present around that offset in the original, unmodified old version.
Usually the same sequence is present, but somewhere else in the file. You may start searching for long sequences, let's say 16 bytes. If you can't find anything, try shorter sequences until you find what looks like the same sequence, and preferably appears only once in the file (so that you are certain it's the right spot).
Thanks. I looked for "FF FF 85 C0 74 0A BF 09 00 00 00 E9", found it, and changed 74 to EB on B5F5C offset (PowerManager 6.66.3). It seems work.
Can somebody please patch 6.67.2 version http://download.lenovo.com/ibmdl/pub/pc ... 4u403w.exe. Have tried it, but can't find a match.
Thank you
Thank you
WTB: Genuine battery for 14-inch widescreen R61/T61/R400/T400
by bakery2k » Sun Mar 26, 2017 8:22 am » in Marketplace - Forum Members only - 2 Replies
- 396 Views
Last post by bakery2k
Tue Apr 04, 2017 7:25 am
Fake or genuine battery?
by umern » Thu Jun 15, 2017 5:48 am » in ThinkPad T430/T530 and later Series - 9 Replies
- 323 Views
Last post by umern
Mon Jun 19, 2017 8:58 am
- 4 Replies
- 440 Views
Last post by BillMorrow
Tue Apr 18, 2017 1:29 am
- 1362 Views
Last post by TonyJZX
Tue Feb 07, 2017 2:44 am
