T43 advice
Marten
Re: T43 advice
#61 Post by Marten » Sat Oct 17, 2009 11:39 am
I may do so, but I found some other issues. The first one is that the screen becomes extremely uncomfortable for my eyes after prolonged use. The other thing is screen response. Watching movies or even watching the cursor floating can be annoying. I'm thinking about replacing it with this LCD screen (30ms, FFS according to ThinkWiki), but the specifications say:
Additional Notes: Non IPS-FLEXVIEW Standard LCD
How can it be?
Any other ideas would be appreciated. Thanks in advance, as usual.
Re: T43 advice
#62 Post by ajkula66 » Sat Oct 17, 2009 11:47 am
LCD from a 15" SXGA+ R52 (which is not IPS) would work perfectly well in a T4x unit. As would non-IPS UXGA from A22p.
Confused yet?
Abused daily: T61p
