How hot should a normal palmrest (under) of a T61 feel like?
Re: How hot should a normal palmrest (under) of a T61 feel like?
#31 Post by RealBlackStuff » Mon Oct 19, 2009 6:50 am
Unless you work in a dirty environment, there will hardly be any dust in the HD cavity.
But if you have nothing better to do, it won't hurt at all to remove the HD and blow the cavity out.
Shouldn't take more than a few minutes.
bautista.ekonomista
#32 Post by bautista.ekonomista » Mon Oct 19, 2009 7:49 am
RealBlackStuff wrote:Unless you work in a dirty environment, there will hardly be any dust in the HD cavity.
I posted something just a few hours ago asking if there's a need to disable/deactivate the security chip in the bios prior to removing the HD. Do you think it's necessary to deactivate/disable the security chip?
I'm afraid that if I remove the HD with the security chip activated, the BIOS/laptop may go kaput.
Current flame: ThinkPad X230 * i5-3320 2.6Ghz* 320GB HDD * 8GB RAM * Centrino N-6205 * Intel HD4000
Old flames: MBP 13" early 2011 * i5-2415 2.3Ghz * 500GB HDD * 8GB RAM * Intel HD3000 /// ThinkPad T61 * T7500 2.2Ghz * 160GB HDD * 3GB RAM * Intel X3100
#33 Post by RealBlackStuff » Mon Oct 19, 2009 8:08 am
If the TP is switched off and AC/battery disconnected, you can remove anything you like without causing damage.
bautista.ekonomista
#34 Post by bautista.ekonomista » Mon Oct 19, 2009 8:23 am
RealBlackStuff wrote:If the TP is switched off and AC/battery disconnected, you can remove anything you like without causing damage.
Apologies for me being too stubborn and too OC, but does your statement mean that I can remove the HD without deactivating/disabling the security chip as long as I have my TP switched off and the battery removed?
(I hope you answer in the affirmative...hahaha :D)
THanks a lot! ^_^
#35 Post by RealBlackStuff » Mon Oct 19, 2009 9:59 am
Yep.
