Windows 7 on my X31 & my ATI drivers story
Tasurinchi
Re: Windows 7 on my X31 & my ATI drivers story
Thanks for sharing this! Since I don´t have my X31 anymore I haven´t bother much with this topic, but it may come handy for a T42 I got a while ago. Normally I use Linux distros with my TPs, but in case I can grab a cheap Win7 license I will give it a try
grunger106
I used to use the DNA ATi driver set on my X31, Sleep works, OpenGL works
Current Thinkpads - X200s, X61 Tablet (MT+MV), X60 Tablet
Thinkpads Past - T20, T21, T23, X21, X30, T60, X31, X60
Well, it seems I may have another update.
After a bit more investigation, turns out the XP Power Manager was not actually performing as expected in Win7. Namely, the power plans had no effect, and screen blanking for Fn+F3 did not work. Probably the XP software does not sync well with Win7's built-in power management settings.
I finally got everything to work by combining the following:
* XP Legacy Omega Drivers 3.8.421 - available from Omega Drivers Archive. The drivers needed to be unpacked, then installed manually through the Device Manager. I had to uncheck the "Compatible hardware" checkbox and force installation despite the drivers being unsigned, but it worked.
* Vista/Win7 Power Manager 3.62 from Lenovo
After reboot everything works. Sleep is available, screen blanking works, Power Manager loads without BSOD and the power plans work too. The Device Manager shows the correct adapter for the X32 - ATI Mobility Radeon (Omega 3.8.421). Experience Index is 1.0 due to the low-end GPU, but at least it works.
There was one complaint about incompatibilities between Win7 and the ATiPTA application, so I just disabled its startup. It seems to have no effect on the power settings.
Hopefully these instructions will work for anyone wanting to run Win7 on their X31/32.
my T42 now works its VGA output
impressive
Thanks dr_st, I have a X31 working fine with your instructions.
Regards,
Oliver
Regards,
Oliver
http://tinymailto.com/oliversl <-- my email after a captcha
Death of a T400 - a story of an unwanted laptop
by TonyJZX » Sat Feb 11, 2017 7:41 am » in ThinkPad T400/410/420 and T500/510/520 Series - 13 Replies
- 1762 Views
Last post by cadillacmike68
Sun Mar 05, 2017 1:41 am
Story about a x40 msata ssd, pata chinese adapter and southbridge...
by silca80 » Fri Mar 31, 2017 3:06 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 6 Replies
- 588 Views
Last post by silca80
Sat Jun 24, 2017 7:04 pm
Installing windows 98 video driver on t43 with ati video card
by OnionLand » Sat Mar 18, 2017 2:02 pm » in ThinkPad T4x Series - 13 Replies
- 1387 Views
Last post by OnionLand
Wed Mar 22, 2017 1:02 pm
Thinkpad T420 Windows 10 drivers
by suman09 » Tue Jan 03, 2017 11:30 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 926 Views
Wed Jan 04, 2017 12:28 am
