T6x EDID database
Re: T6x EDID database
I just got a Sharp model #SHP139A SXGA+ for my T60 14.1".
In windows 7 it's perfect. However I need to turn off HV Expansion for me to be able to see the BIOS without an external CRT.
With HV Expansion off the BIOS is centered in the middle and not edge to edge. Outside of this there is a slight screen 'glitch' when switching from the IBM Thinkpad start screen to when it starts windows...it's only at the bottom 1/4 of the screen and only for a second or two.
Can I flash this to another type and get the BIOS working and no screen glitches?
phoenix didnt see the edid. Powerstrip won't let me save it in the unreg'd version.
This is from MonInfo:
Raw data
00,FF,FF,FF,FF,FF,FF,00,4D,10,9A,13,00,00,00,00,00,00,01,03,80,1C,15,78,CA,0D,70,95,53,4E,8C,26,
1D,50,54,00,00,00,90,40,01,01,01,01,01,01,01,01,01,01,01,01,01,01,30,2A,78,20,51,1A,10,40,2C,70,
03,00,1D,D6,10,00,00,18,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,00,0A,20,00,00,00,10,00,00,
00,00,00,00,00,00,00,00,00,00,0A,20,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,00,0A,20,00,EC
Monitor #1 [Real-time 0x0031]
Manufacturer............. Sharp
Plug and Play ID......... SHP139A
Serial number............ n/a
Manufacture date......... 1990, ISO week 0
EDID revision............ 1.3
Input signal type........ Digital
Color bit depth.......... Undefined
Display type............. RGB color
Screen size.............. 280 x 210 mm (13.8 in)
Power management......... Standby, Suspend
Extension blocs.......... None
DDC/CI................... Not supported
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.582 - Ry 0.324
Green chromaticity....... Gx 0.308 - Gy 0.548
Blue chromaticity........ Bx 0.149 - By 0.116
White point (default).... Wx 0.313 - Wy 0.328
Additional descriptors... None
Timing characteristics
Range limits............. Not available
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1400x1050p at 60Hz (4:3)
Modeline............... "1400x1050" 108.000 1400 1444 1556 1688 1050 1050 1053 1066 -hsync -vsync
Standard timings supported
1400 x 1050p at 60Hz - VESA STD
Raw data
It will only work with HW exp. set to off because the EDID doesn't contain standard timings for anything else than 1400x1050. With HW exp. set to off, the monitor will always operate at it's native resolution. I can try making a new and working EDID for you... but you'll need a registered version of powerstrip to be able to flash the monitor with the EDID.
I'd be willing to buy it.Troels wrote:It will only work with HW exp. set to off because the EDID doesn't contain standard timings for anything else than 1400x1050. With HW exp. set to off, the monitor will always operate at it's native resolution. I can try making a new and working EDID for you... but you'll need a registered version of powerstrip to be able to flash the monitor with the EDID.
Thanks, let me know if you need anything from me.
Just a FYI for those looking to buy Powerstrip. It's not an instant purchase as most know, but now they have locked out EDID programming unless you request a PIN (which is another 12-48 hour delay)...
To get the PIN you need to send you pstrip.ini file, to get this easily go to Options->Preferences and then double-click on the Compatibility bar. This will create a shortcut to pstrip.ini on your desktop. Close Powerstrip and then reply to your confirmation email with that file and request a PIN and give the reason why.
Sort of stupid if you ask me, but too many idiots taking it out on Entech for bricking their LCDs trying to do things they don't understand.
tomkrishan1
15.4 WUXGA LG Philips in a T60p
ok, i hope i don`t bother you and i appollogize for posting it in the EDID threat, but i didn`t found any other reference ...
so someone maybe know if the T61p widescreen LG Philips LP154WU1 fits and works also in the T60p widescreen machines? ... or do i need to make changes to the bios or EDID or whatever?
thank you very much for any hints you might return!
T60p | 15.4"| T7600 | V5250 | 3 GB |
T60p | 14.1"| T2600 | V5250 | 2 GB |
history:
T43p | 14.1"| M780 | V3200 | 1 GB |
T42 | 14.1"| M745 | Radeon 9000 | 1 GB |
history:
wild_bill
Model: 2007-DD2 (T60)
Screen: 15'' 1400x1050, LG Philips LP150E05-A2
EDID:
PS - this particular original screen is a POS - they become yellow & dim early in their life, can't wait to get a nice Boe-Hydis UXGA
EDID:
0x 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
00 | 00 FF FF FF FF FF FF 00 30 AE 43 40 00 00 00 00
10 | 00 0F 01 03 80 1E 17 78 EA AF 00 99 58 53 8C 2A
20 | 25 50 54 21 08 00 81 80 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 30 2A 78 20 51 1A 10 40 30 70
40 | 13 00 31 E4 10 00 00 18 28 23 78 20 51 1A 10 40
50 | 30 70 13 00 31 E4 10 00 00 18 00 00 00 0F 00 90
60 | 43 32 90 43 28 14 06 00 32 0C 00 00 00 00 00 FE
70 | 00 4C 50 31 35 30 45 30 35 2D 41 32 0A 20 00 9BPS - this particular original screen is a POS - they become yellow & dim early in their life, can't wait to get a nice Boe-Hydis UXGA
IBM T60 | 15'' BOE·hydis UXGA IPS | T7200 Core2Duo | 4GB CL4 | 320GB Fujitsu 7200 | Echo Indigo studio sound | NMB kb | XP Pro | Linux Mint | Win7 x64
~~~ celebrating my 37th year of working with micro computers - still have my original MITS Altair 8800 and LSI ADM-3 from '75 ~~~
Does anyone have the EDID for a T61 14.1" WXGA+ (1440x900)? I'm attempting to replace a broken WXGA LCD with a spare WXGA+ I have on hand. I get a picture, but it's stretched and distorted. I'm hoping it's an EDID problem, and I would like to see an original Lenovo WXGA+ EDID for comparison.
tomkrishan1
LG Philips 15.4" 1680x1050 @T60p wide
LP154W02-TL06
00 | 00 FF FF FF FF FF FF 00 24 4D 87 28 00 00 00 00
10 | 00 0F 01 03 80 21 15 78 0A BC A5 98 58 55 8B 28
20 | 24 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 A8 2F 90 E0 60 1A 10 40 20 40
40 | 13 00 4B CF 10 00 00 19 B7 27 90 E0 60 1A 10 40
50 | 20 40 13 00 4B CF 10 00 00 19 00 00 00 0F 00 B3
60 | 0A 32 B3 0A 28 14 01 00 32 0C 00 00 00 00 00 FE
70 | 00 4C 50 31 35 34 57 30 32 2D 54 4C 30 36 00 7F
still hoping there might be someone who can tell if a T61p WUXGA 1920x1200 will work with a T60p wide ... or if i need to edit the EDID or change the inverter or whatever
LP154W02-TL06
history:
history:
Totoro-kun
Good day,
I am about to upgrade screen for my T61, so I can post EDID's while I am at it.
My current screen is:
14.1" WXGA 1280x800 panel:
Samsung LTN141W1-L05
P/N: 42T0443
FRU: 42T0410
EDID for this screen:
And I have already ordered used, but genuine 14.1" WXGA+ 1440x900 panel which is:
Samsung: LTN141WD-L05
FRU: 42T0412
But I still have to wait until this screen arrives, then I promise to post EDID for it too.
Hope this will be helpful.
P/N: 42T0443
FRU: 42T0410
00 | 00 FF FF FF FF FF FF 00 30 AE 31 40 00 00 00 00
10 | 00 11 01 03 80 1E 13 78 EA CD 75 91 55 4F 8B 26
20 | 21 50 54 21 08 00 01 01 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 FD 1D 00 20 51 20 10 30 34 40
40 | 33 00 2F BE 10 00 00 19 FE 18 00 20 51 20 10 30
50 | 34 40 33 00 2F BE 10 00 00 19 00 00 00 0F 00 81
60 | 0A 32 81 0A 28 12 01 00 4C A3 57 31 00 00 00 FE
70 | 00 4C 54 4E 31 34 31 57 31 2D 4C 30 35 0A 00 22
FRU: 42T0412
IBM ThinkPad T61 7661-CTO 14,1" WXGA+ LED mod / T9550 / 4GB / 64Gb ssd / 750Gb Ultrabay hdd / Intel x3100 / Intel 5300 / WWAN / Webcam / 4 in 1 Card Reader / 9 cell Panasonic / NMB blank keyboard / Sata2 Mod / 1066FSB Mod
eulers1729
My T61 has the LTN141WD-L05 panel from Samsung, manufactured in 2005.
0 1 2 3 4 5 6 7 8 9
_________________________________________
000| 00 FF FF FF FF FF FF 00 30 AE
010| 33 40 00 00 00 00 00 0F 01 03
020| 80 1E 13 78 EA CD 75 91 55 4F
030| 8B 26 21 50 54 21 08 00 01 01
040| 01 01 01 01 01 01 01 01 01 01
050| 01 01 01 01 32 26 A0 40 51 84
060| 1A 30 30 20 36 00 2F BE 10 00
070| 00 19 D5 1F A0 40 51 84 1A 30
080| 30 20 36 00 2F BE 10 00 00 19
090| 00 00 00 0F 00 90 0A 32 90 0A
100| 28 14 01 00 4C A3 57 44 00 00
110| 00 FE 00 4C 54 4E 31 34 31 57
120| 44 2D 4C 30 35 0A 00 A6IBM Thinkpad T61 - vPro T9300 | 2 GB RAM | Intel Extreme Graphics x3100
IBM Thinkpad 701C - Intel 486 | 32MB RAM | CT-65545 1MB | Butterfly Keyboard
I saw that there is this panel already but there is no model or resolution information, so here it is.
Model: T60
Screen: 15", 1024x768, Samsung LTN150XG-L08
Model: T60
EDID BYTES:
00 | 00 FF FF FF FF FF FF 00 30 AE 40 40 00 00 00 00
10 | 00 0F 01 03 80 1F 17 78 EA 2D 05 97 57 51 8A 27
20 | 23 50 54 21 08 00 01 01 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 64 19 00 40 41 00 26 30 18 88
40 | 36 00 30 E4 10 00 00 19 28 15 00 40 41 00 26 30
50 | 18 88 36 00 30 E4 10 00 00 19 00 00 00 0F 00 61
60 | 43 32 61 43 28 14 01 00 4C A3 58 47 00 00 00 FE
70 | 00 4C 54 4E 31 35 30 58 47 2D 4C 30 38 0A 00 6D
kirpeknots
T61p 15.4 WUXGA 1920X1200. Samsung LTN154U2-L05 panel.
I realy hate this panel and I'm about to swap it for a WUXGA LG/Philips.
EDID BYTES:
00 | 00 FF FF FF FF FF FF 00 30 AE 55 40 00 00 00 00
10 | 00 11 01 03 80 21 15 78 EA 87 F5 94 57 4F 8C 27
20 | 27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
30 | 01 01 01 01 01 01 70 41 80 78 71 B0 10 40 30 20
40 | 33 00 4B CF 10 00 00 19 74 34 80 20 71 B0 14 40
50 | 30 20 26 00 4B CF 10 00 00 19 00 00 00 0F 00 D1
60 | 0A 32 D1 0A 28 11 01 00 4C A3 55 32 00 00 00 FE
70 | 00 4C 54 4E 31 35 34 55 32 2D 4C 30 35 0A 00 30T61P, Corsair Force3 128Gb SSD, Hitachi 7K500 ultrabay drive, LG/PHilips WUXGA panel, T7700 2.4Ghz, 4Gb, 9cell batt, 3g
T61, Hitachi 7K500, WSXGA+ T7700 2.4Ghz, 4Gb, 9cell batt
SL300, Hitachi 7K500, T6570 2.1Ghz, 4Gb, 9cell batt, 3g
BitEngineer
Hey, look at this!
For those who need to flash an EDID, check out this tool available from Lenovo itself (made available July 2012):
Extended Display Identification Data (EDID) Tool - http://support.lenovo.com/en_US/downloa ... D=DS030190
This tool allows you to update the EDID on a ThinkCentre M92z, but it appears to be a 3rd party tool that runs in Windows, so it seems likely it will work for Thinkpads too. The instructions state:
How to update EDID under Windows
1. Run Nuvoton eSIO Utility Ver:0.78 under Windows.
2. Choose DP_EDID option.
3. Choose correct DP bin file from your computer.
4. Click the Execute button to flash the EDID.
5. Use the same method to flash the HDMI EDID.
6. Choose HDMI_DVI_EDID option.
7. Choose correct HDMI bin file from your computer.
8. Click the Execute button to flash the EDID.
9. After finishing both DP_EDID and HDMI_ EDID, shut down the system and remove the power cord for at least 10 seconds.
In case the Lenovo page disappears, here are the links to the tool and instructions pdf:
Nuvoton eSIO Utility - http://download.lenovo.com/ibmdl/pub/pc ... tility.zip
Standard Operating Procedure For EDID Update - http://download.lenovo.com/ibmdl/pub/pc ... update.pdf
I haven't had the need to use this tool to verify that it works, but maybe now there will be no need to buy PowerStrip!
systemBuilder
@BitEngineer, the Lenovo EDID utliity does not work on a T6x, it failed for all 3 menu items, sorry. It might, however, try to flash my external monitor, which is why I disconnected the monitor while trying it out.
I did find a FREE alternative to the PowerStrip utility, called EDID_Writer.exe
http://www.curtpalme.com/forum/viewtopic.php?p=75745
You can actually download it from the first message on the page (on the far right is the Download link).
I converted the file full of hex constants into a C program (each constant is a character in an array of chars), and wrote out the 128 byte binary file using a for(;;) loop, then I used the edid writer tool to flash my T60 screen:
ddcw -f samsung.bin
Which solved my EDID problems
I could tell it was doing something because when I ran the ddcw command, the screen flashed and I was in 24x80 text mode for my command shell. Luckily, exiting the shell revealed windows below ...
An interesting thing I found out about EDID mismatches is that you can boot with an external monitor that the computer recognizes, then you can use the Fn-F7 keypress (switch monitors) to display data properly on the unrecognized screen (in my case, on a 14.1 SXGA+ Samsung LTN141P4-L02. but with a different FRU than 13N7058, 13N7059), perhaps because the BIOS is not involved, only Windows is involved.
ddcw -f samsung.bin
Lots of thinkpads (10+) but I would never be so stupid as to list them all because that would spam everybody's searches and people who *do* try to list them all would be jerks.
Do we know of a free EDID flashing tool that works with a T61?
Not sure if this is of any help, but here is EDID data for BOE Hydis HV150UX1-101
stock without reflash. It did not work in a T61, black screen the entire time, even
in Windows 7:
EDID Bytes BOE Hydis HV150UX1-101 Does NOT work in T61:
00: 00,FF,FF,FF,FF,FF,FF,00,36,7F,06,00,07,00,00,00
10: 00,0C,01,03,80,FF,FF,FF,CF,00,00,A0,57,49,9B,26
20: 10,48,4F,00,00,00,01,01,01,01,01,01,01,01,01,01
30: 01,01,01,01,01,01,48,3F,40,30,62,B0,32,40,40,C0
40: 03,00,00,00,00,00,00,1E,00,00,00,FD,00,00,3C,00
50: F8,11,00,00,00,00,00,00,00,00,00,00,00,00,00,00
60: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
70: 00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,52
Here is the BOE Hydis HV150UX1-100 from earlier in this thread for comparison:
EDID BYTES BOE Hydis HV150UX1-100:
00 | 00 FF FF FF FF FF FF 00 30 AE 46 40 00 00 00 00
10 | 00 0F 01 03 80 1E 16 78 EA BD 30 91 54 4F 8B 26
20 | 21 50 54 21 08 00 81 80 A9 40 01 01 01 01 01 01
30 | 01 01 01 01 01 01 48 3F 40 30 62 B0 32 40 40 C0
40 | 13 00 30 E4 10 00 00 19 BC 34 40 30 62 B0 32 40
50 | 40 C0 13 00 30 E4 10 00 00 19 00 00 00 0F 00 A9
60 | 43 32 A9 43 28 14 02 00 09 E5 00 00 00 00 00 FE
70 | 00 48 56 31 35 30 55 58 31 2D 31 30 30 0A 00 A7
in Windows 7:
Frankenpad 15" TuuS MB X9000, T61 14" doner, T61 15" fixed gave away
X61s L7700 7666-B7U Prefer a T8100 X61t L7500 7762-B48 Price was right
Toughbook CF51 with SSD, Dell: D830, M4400, M6400, E4300
I used Moninfo to get the EDID data and was not aware that these programs
will get data from the registry if there is no EDID. Manufacturer came up as
Microsoft, is that a hint that it is coming from the Registry rather than EDID?
I have a feeling that this display has no EDID.
When I tried reading out the data in Powerstrip this error message came up:
"DDC communication from the monitor failed or is
not supported" Reverting to EDID data provided by Windows.
Hydis -101 most certainly does have an EDID chip. Flashing it properly is a whole another matter.Pete B wrote: I have a feeling that this display has no EDID.
Are you using the paid version of Powerstrip?When I tried reading out the data in Powerstrip this error message came up:
I'll take your word for it on having EDID.
Yes, the paid version. I've read that it doesn't work with Intel graphics but I
find this hard to believe. I am using a system with Intel graphics.
I have one sitting in a T4x 15" lid, originally used in my T50. I haven't tried to flash it - no need for that in a T4x setup - but other people on this forum have done it.Pete B wrote:I'll take your word for it on having EDID.
Honestly, I can't say. My recollection is that you need XP to flash it. As for Intel vs. ATi/nVidia...I don't know.Yes, the paid version. I've read that it doesn't work with Intel graphics but I
I did see the XP comment also, and it just so happens that I have a drive
with XP on it for that system, so I'll try it.
Thanks again!
Thanks again!
Running XP now, same thing. When I try to open the option to write EDID
the error is "An EDID EEPROM was not detected on the selected monitor."
Ran XP on laptops with both Intel and X1300 graphics, same thing.
Thanks RBS, I have seen that not looking forward to that mod, but I do
know how to solder - no problem just don't have the EEPROM.
About having to use XP with Powerstrip, I'd be willing to bet that what is
actually needed is a 32 bit OS such as Win 7 32 bit. Just tried Powerstrip
on a T60 and it was able to read and found the EEPROM to write the EDID.
This was to the display panel that was already in it, not the one in question
here but I was just testing that the program worked under Win 7 32 bit in a T60.
danikayser84
I put a Quanta QD14FL07 SXGA+ in my 14.1" Intel T61 (replacing its original LG XGA), appears to be a drop-in replacement although no T6x ever shipped with that panel (haven't had any issues or complications arise from its use); will the same panel work in T60/p 14.1"? (I'd assume if it works properly in T61s it'd probably also work in T60s, I do know however that it's not compatible with T4x and will damage the motherboard if used on one)
Current: W701 2544-W1C (Win7), T61 6460-DWU (Win7), T61 8892-01U (Win7), Semi-Retired: T43 2668-4DU (WinXP)
Museum/Retired: T60, Z60m, T42, T30, T23, A31, A31p, 600X, 600E, 570, 380ED, 380Z, 560E, 560Z, 760XD, 765D, 755CX, 755C
Apples: PowerBook 1400cs, G3 Wallstreet, G3 Pismo, MacBook 2008
cirthix wrote:Pete B wrote:I used Moninfo to get the EDID data and was not aware that these programs
"It's sealed. I get the same DDC communcation failure error when attempting to READ the edid, but it finds the chip without error when attempting to UPDATE the edid.
You do not need to be displaying anything to the laptop's panel to be able to write the edid, just select any attached display click update edid, and note the name on the confirmation dialog box. If the name is your external, skip that one and the next should be the QXGA."
From: http://forum.thinkpads.com/viewtopic.ph ... 91#p513072
Just found this, so I should try writting even though I get the "DDC communication from the monitor failed" message.
EDID for T61p SGXA+, I recently received a replacement screen from Ebay. The LCD was advertised LTN141P4-L02 (with FRU 42T0369 pictured). I was sent 92P6760 Samsung( SGXA+ for T43). Ok, I got tricked like many others, ouch. The seller gave me advice on soldering and blah blah. The Monitor worked on initial boot but after restart there was no display. Nvidia offers a solution with options to import and export EDID within their software. My original LCD was Toshiba LTD141EN9B. It was still viewable but failing. While the Toshiba was installed, I was able to IMPORT the EDID. Nvidia saves it as a "file". Then, after installing the 92P6760 into the laptop,using external monitor, I exported the EDID into the new screen( it has the chip), BOOM, healthy display. Now the EDID "source" for my laptop LCD is shown as "file" instead of "monitor". All works well and the screen shows the typical old "ice hockey rink" white with vibrant colors(when used with Nvidia settings). I got robbed but it worked out in the end. NO need to solder or tinker. The monitor flex cable was a lil tight and off center a fraction but not a big deal.
T61p SXGA+ CTR-8891 08/04/30
FX570 T8300
Survived 3 deployments
FX570 T8300
T61 8896
TMD (Toshiba M a t s u s h i t a Display) LTD141EN9B (FRU 42T0438 PN 42T0437)
QUANTA QD14FL07
00000000: 00ff ffff ffff ff00 30ae 2240 0000 0000 ........0."@....
00000010: 3011 0103 801d 1578 ea6f 959c 544c 8726 0......x.o..TL.&
00000020: 2150 5400 0000 0101 0101 0101 0101 0101 !PT.............
00000030: 0101 0101 0101 302a 7820 511a 1040 3070 ......0*x Q..@0p
00000040: 1300 1fd7 1000 0018 2523 7820 511a 1040 ........%#x Q..@
00000050: 3070 1300 1fd7 1000 0018 0000 000f 0090 0p..............
00000060: 4332 9043 280f 0100 3064 0055 0000 00fe C2.C(...0d.U....
00000070: 004c 5444 3134 3145 4e39 420a 2020 00e9 .LTD141EN9B. ..
00000080: 00ff ffff ffff ff00 30ae 2240 0000 0000 ........0."@....
00000090: 3011 0103 801d 1578 ea6f 959c 544c 8726 0......x.o..TL.&
000000a0: 2150 5400 0000 0101 0101 0101 0101 0101 !PT.............
000000b0: 0101 0101 0101 302a 7820 511a 1040 3070 ......0*x Q..@0p
000000c0: 1300 1fd7 1000 0018 2523 7820 511a 1040 ........%#x Q..@
000000d0: 3070 1300 1fd7 1000 0018 0000 000f 0090 0p..............
000000e0: 4332 9043 280f 0100 3064 0055 0000 00fe C2.C(...0d.U....
000000f0: 004c 5444 3134 3145 4e39 420a 2020 00e9 .LTD141EN9B. ..
00000000: 00ff ffff ffff ff00 4493 2d00 0000 0000 ........D.-.....
00000010: 000f 0103 801c 1578 0a0d 7997 554f 9326 .......x..y.UO.&
00000020: 2050 5400 0000 0101 0101 0101 0101 0101 PT.............
00000030: 0101 0101 0101 302a 7820 511a 1040 2c70 ......0*x Q..@,p
00000040: 0300 1dd6 1000 0018 0000 000f 0005 7815 ..............x.
00000050: 4801 0808 08a2 082a 2a02 0000 00fe 0051 H......**......Q
00000060: 5541 4e54 4144 4953 504c 4159 0000 00fe UANTADISPLAY....
00000070: 0051 4431 3446 4c30 3733 0a20 2020 0099 .QD14FL073. ..
GIVEN AWAY: A big box of parts from T6x/R6x projects
by wujstefan » Tue Feb 07, 2017 5:04 pm » in Marketplace - Forum Members only - 7 Replies
- 807 Views
Last post by fefrie
Wed Mar 01, 2017 8:20 pm
FS: Assorted Thinkpad Parts (T5xx, T6x, T4x, T3x)
by Medessec » Mon Jun 12, 2017 1:11 pm » in Marketplace - Forum Members only - 1 Replies
- 150 Views
Last post by Medessec
Sun Jun 25, 2017 5:19 pm
Users browsing this forum: pflugshaupt and 4 guests
