Snow leopard on X60s
Re: Snow leopard on X60s
I have done a clean install method for 10.6.2 in french and in english ... based on this page.
The files you need are here
Update : English
Update : English
Lenovo X60t (6363-AQ8)
- Intel CoreDuo 1,67 GHz (L2400)
- 3 Go / 320 Go / GMA950 / FW 400 / SD Card
- Bluetooth / Wifi AR5BXB6 / Tablet
I also decided to give DSDT Fixing a try. I manage in addition to fix:martin255 wrote: Since nothing else seems to be working, I am now in the (long) process of fixing the DSDT. Not much result for now, except that I can now use native brightness control and I don't need a modded IOATAFamily.kext anymore. Also the GMA950 works with the Vanilla kexts, even without an EFI string.
Next up are:
- Sleep
- Correct FSB detection
- Fix the Firewire error that slows down the boot process
- AHCI (no more AHCIPortInjector.kext and IOAHCIBlockStorageInjector.kext in /E/E)
- AppleHDA (don't need to delete AppleHDA.kext from /S/L/E, but require VoodooHDA in /E/E)
- Vanila SpeedStep (no NullCPUPowerManagement.kext, SleepEnabler.kext and VoodooPowerMini.kext)
- EHCI / UHCI (right device id)
But as you were previously, I am stuck with:
- Firewire
- Sleep
For the sleep issue, here is a log of the sleep/wake sequence :
20/02/10 15:27:05 mDNSResponder[25] mDNSPlatformRawTime: last_mach_absolute_time 85BCF37D00000048
20/02/10 15:27:05 mDNSResponder[25] mDNSPlatformRawTime: this_mach_absolute_time 85BB2BC500000048
20/02/10 15:27:05 kernel FakeSMC: key info not found CLWK, length - 6
20/02/10 15:27:05 kernel hibernate image path: /var/vm/sleepimage
20/02/10 15:27:05 kernel sizeof(IOHibernateImageHeader) == 512
20/02/10 15:27:05 kernel Opened file /var/vm/sleepimage, size 1073741824, partition base 0x3c0007e00, maxio 100000
20/02/10 15:27:05 kernel hibernate image major 14, minor 4, blocksize 512, pollers 4
20/02/10 15:27:05 kernel AirPort: Link Down on en0. Reason 1 (Unspecified).
20/02/10 15:27:05 kernel hibernate_alloc_pages flags 00000000, gobbling 0 pages
20/02/10 15:27:05 kernel VoodooHDADevice[0x36a7800]::performPowerStateChange(1, 0)
20/02/10 15:27:05 kernel VoodooHDADevice[0x36a7800]::suspend
20/02/10 15:27:05 kernel Power down FG cad=0 nid=1 to the D3 state...
20/02/10 15:27:05 kernel Power down FG cad=1 nid=2 to the D3 state...
20/02/10 15:27:05 kernel Resetting controller...
20/02/10 15:27:05 kernel VoodooHDADevice[0x36a7800]::resetController(0)
20/02/10 15:27:05 kernel Suspend done.
20/02/10 15:27:05 kernel System SafeSleep
20/02/10 15:27:20 kernel hibernate_page_list_setall start
20/02/10 15:27:20 kernel hibernate_page_list_setall time: 109 ms
20/02/10 15:27:20 kernel pages 175100, wire 44370, act 28836, inact 185, spec 50, zf 0, throt 0, could discard act 16477 inact 17914 purgeable 3530 spec 63738
20/02/10 15:27:20 kernel hibernate_page_list_setall found pageCount 73441
20/02/10 15:27:20 kernel IOHibernatePollerOpen, ml_get_interrupts_enabled 0
20/02/10 15:27:20 kernel IOHibernatePollerOpen(0)
20/02/10 15:27:20 kernel writing 72620 pages
20/02/10 15:27:20 kernel image1Size 64749056
20/02/10 15:27:20 kernel PMStats: Hibernate write took 3663 ms
20/02/10 15:27:20 kernel all time: 3663 ms, comp time: 1318 ms, deco time: 0 ms,
20/02/10 15:27:20 kernel image 121381888, uncompressed 297451520 (72620), compressed 117717368 (39%), sum1 8f5c1562, sum2 876a51c3
20/02/10 15:27:20 kernel hibernate_write_image done(0)
20/02/10 15:27:20 kernel sleep
20/02/10 15:27:20 kernel Wake reason = power-button
20/02/10 15:27:20 kernel Unsynchronized TSC for cpu 1: 0x0000000020a3fe06, delta 0x73ef6
20/02/10 15:27:20 kernel System Wake
20/02/10 15:27:20 kernel FakeSMC: key info not found CLWK, length - 6
20/02/10 15:27:20 kernel Previous Sleep Cause: 0
20/02/10 15:27:20 kernel ApplePS2Mouse: Unexpected data from PS/2 controller.
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::performPowerStateChange(0, 1)
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::resume
20/02/10 15:27:20 kernel Resetting controller...
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::resetController(1)
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::initCorb
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::initRirb
20/02/10 15:27:20 kernel Starting CORB Engine...
20/02/10 15:27:20 kernel Starting RIRB Engine...
20/02/10 15:27:20 kernel Enabling controller interrupt...
20/02/10 15:27:20 kernel Power up audio FG cad=0 nid=1...
20/02/10 15:27:20 kernel AFG commit...
20/02/10 15:27:20 kernel HP switch init...
20/02/10 15:27:20 kernel OSS mixer reinitialization...
20/02/10 15:27:20 kernel VoodooHDADevice[0x36a7800]::audioCtlOssMixerSetRecSrc(0x3a78204, 0x80)
20/02/10 15:27:20 kernel warning: couldn't set recording source to microphone
20/02/10 15:27:20 kernel Power down unsupported non-audio FG cad=1 nid=2 to the D3 state...
20/02/10 15:27:20 kernel Resume done.
20/02/10 15:27:20 kernel getWOW_PARAMETERS: Can't set wow params. Wow is not supported
20/02/10 15:27:20 kernel VoodooSDHCI: initializing spec 2.0 SD card
20/02/10 15:27:20 configd[13] network configuration changed.
20/02/10 15:27:21 kernel VoodooSDHCI: we have HC cardCode: Select all
I don't think that's ever going to be possible. Original Mac use USB bus for internal keyboard/trackpad connection. Most of other laptops use PS2, and unless there's BIOS level emulation of USB for PS2, you cannot do much with it.Sebinouse wrote:Next Step will be to get rid of AppleACPIPS2Nub.kext
Intel Core 2 Duo T7600
I don't have Firewire in T60p, but I've seen some DSDT fixes for it. Have you tried this method:Sebinouse wrote: But as were previously, I am stuck with:
- Firewire
Method (_L18, 0, NotSerialized) // Newly added for FireWire support.
// 18 - Выбираем незанятый номер.
Notify (\_SB.PCI0.PCIB.FRWR, Zero)
Device (FRWR) // Newly added Device for FireWire support.
Name (_ADR, 0x00030000)
Name (_GPE, 0x18) // 0x18 - соответствует номеру в Method (_L18,....
Method (_DSM, 4, NotSerialized)
Store (Package (0x02)
"fwports",
Buffer (0x04)
0x02, 0x00, 0x00, 0x00
}, Local0)
MCDP (Arg2, RefOf (Local0))
Return (Local0)
Method (MCDP, 2, NotSerialized) // New Method V1.1 – By Master Chief.
If (LEqual (Arg0, Zero)) // Function index: 0
Store (Buffer (One)
0x03
}, Arg1)
I have tried this (which is very close):
lspci gave me :
I added this in "Scope (_GPE)"
and this in "Device (PCIB)"
But I still have this error on boot :
As I don't have any FireWire device with me, I don't know if it really works ...
Do you know where to put the third part of you code, I have never seen this for firewire ... I used this topic for the DSDT patch : http://www.insanelymac.com/forum/index. ... pic=196359 ... thanks
lspci gave me :
15:00.1 Ricoh Co Ltd R5C552 IEEE 1394 Controller [1180:0552] (rev 09)Code: Select all
Method (_L0B, 0, NotSerialized)
Notify (\_SB.PCI0.PCIB, 0x02) Notify (\_SB.SLPB, 0x02)
Device (FRWR) // Added device for 15:00.1 Ricoh Co Ltd R5C552 IEEE 1394 Controller [1180:0552] (rev 09)
Name (_ADR, 0x15000001) // Reported by 'lspci' 15:00.1
Name (_GPE, 0x0B) // Callback to (_GPE) Method (_L0B) for (PCIB)
// Name (_SUN, 0x01) // PCI slot 1 in System Profiler (cosmetic)
Store (Package (0x06)
"built-in",
Buffer (0x01)
Zero
"fwhub",
Buffer (0x04)
0x00, 0x00, 0x00, 0x00
"device-id",
Buffer (0x04)
0x52, 0x05, 0x00, 0x00 // device ID [1180:0552]
}, Local0)
DTGP (Arg0, Arg1, Arg2, Arg3, RefOf (Local0))
Return (Local0)
FireWire runtime power concervation disabled. (2)Do you know where to put the third part of you code, I have never seen this for firewire ... I used this topic for the DSDT patch : http://www.insanelymac.com/forum/index. ... pic=196359 ... thanks
Here is my latest DSDT with ... http://www.mediafire.com/?znxltvwgd5v
(2) : AppleHDA.kext can remain unchanged (and be with VoodooHDA.kext) in S/L/E
(3) : NullCPUPowerManagement.kext and VoodooPowerMini.kext can be deleted, 5 P-States for Intel(R) Core(TM) Duo CPU L2400 @ 1.66GHz (in theory we no longer need SleepEnabler.kext also ...)
(4) : May be required for sleep ...
Edit: I've got some random KP with power management ... just add NullCPUPowerManagement.kext to boot again and then delete it again
- DTGP to enable other fix
- IntelGMA950 Support
- Native Brightness Control
- IOATAFamily.kext fix
- AHCI Support (1)
- AppleHDA Disabler (2)
- Vanilla SpeedStep (3)
- EHCI/UHCI Fix (4)
- HPET Fix (4)
- RTC Fix (4)
I got my X60s working again, currently installing Snow. I am impatient to test your new DSDT and will try to help getting sleep to work.
Once you have 10.6.2 working on you X60, you can download my /Extra folder, Run AsereBLN installer, remove/restore any custom kext in /S/L/E and then run pfix ... this might work for you as well ... let me know !
Just using your E/E folder 'as is' does not work for me. It might be because I did not follow the same install procedure, or something else entirely, I don't know.
Anyway, I am now using your DSDT, a legacy kext for Wifi support, fakemsc, VoodooMonitor, VoodooTSCSync, VoodooHDA, VoodooPS2Controller/ACPIPS2Nub, VoodooBattery, and VoodooSDHC. Sleep does not work - it's impossible to wake.
The other problem I have is with VoodooHDA - when I try to enable mic support, everything seems to work, but I actually have no sound anymore. The mic is not essential to me so I might switch back to AppleAzaliaAudio.
What kind of battery life are you getting with Vanilla Speedstep? My temps are bad (idle at around 60°C), and so is battery life (3-4h on an 8-cell). I had way better results with VooodooPower.
Also, I did take a look inside your legacy kext. Can you explain what each fix does? I don't have a tablet, so I'm not sure which fixes are useful for me.
In any case thanks for your hard work. Without your efforts I would not even have tried to reinstall Snow Leo.
Switch to AppleAzaliaAudio for now, and Sleep will work. This is now known problem with 60-series ThinkPads. I will have vanilla AppleHDA solution ready to replace Azalia sometime soon.martin255 wrote:Anyway, I am now using your DSDT, a legacy kext for Wifi support, fakemsc, VoodooMonitor, VoodooTSCSync, VoodooHDA, VoodooPS2Controller/ACPIPS2Nub, VoodooBattery, and VoodooSDHC. Sleep does not work - it's impossible to wake.
Check my DSDT guide, you need to make sure that you have C-states and P-states active, that will lower your temps. Vanilla SpeedStep can bring temps lower than VoodooPower solution, but you have to work for it.martin255 wrote:What kind of battery life are you getting with Vanilla Speedstep? My temps are bad (idle at around 60°C), and so is battery life (3-4h on an 8-cell). I had way better results with VooodooPower.
Thanks for your advice. I was actually planing to also participate in your thread about DSDT patching, but you were quicker than me!
I will try AppleAzaliaAudio and work on Vanilla Speedstep, and report back.
I noticed that DSDT SpeedStep doesn't work at all with VoodooBattery ... that would explain your 60° idle temp and that's why i used AppleACPIBattery which is compatible .
I guess VanillaSpeedStep can also be improved : I just copy/paste the C-States from Silencer's, I have a very good idle temps around 45° but I also have audio/video lags ... for the moment I am still using VoodooPower !
About Audio and Sleep, I already tried Azalia and VoodooHDA in almost every configuration (E/E, S/L/E), sleep works but no keyboard and no mouse on wake ... According to me it comes from PS2 driver which cannot wake the track point for some reason ...
Lag is easy to fix - check my guide and find DSDT fixes for PIC and TIMR devices.Sebinouse wrote:I guess VanillaSpeedStep can also be improved : I just copy/paste the C-States from Silencer's, I have a very good idle temps around 45° but I also have audio/video lags ... for the moment I am still using VoodooPower !
What PS2 kexts are you using? I have now no problem with waking and using keyboard or trackpoint.Sebinouse wrote:About Audio and Sleep, I already tried Azalia and VoodooHDA in almost every configuration (E/E, S/L/E), sleep works but no keyboard and no mouse on wake ... According to me it comes from PS2 driver which cannot wake the track point for some reason ...
... you are right that one was really easy to fix ! (I should have paid more attention reading your guide !)Silencer wrote:Lag is easy to fix - check my guide and find DSDT fixes for PIC and TIMR devices.
I have tried many of them ... including yours ...Silencer wrote: What PS2 kexts are you using? I have now no problem with waking and using keyboard or trackpoint.
My problem is with ApplePS2Mouse.kext ... once deleted sleep/wake works ! But I really don't understand why !
I am still looking for a solution (my X60 is a tablet so I can use a pointer instead of the trackpoint ...)
Pointer - you mean trackpad or trackpoint? Red nubbin is trackpointSebinouse wrote:My problem is with ApplePS2Mouse.kext ... once deleted sleep/wake works ! But I really don't understand why !
I mean the magnetic pen provided with the x60t to use directly on the screen ... it's a real TabletMac with either Sleep or trackpoint (the x60t has no trackpad)
Oh, in that case I won't be able to help, since I have to means of testing this.Sebinouse wrote:I mean the magnetic pen provided with the x60t to use directly on the screen ... it's a real TabletMac with either Sleep or trackpoint (the x60t has no trackpad)
ernstloeffel
he probably means the tablet pen.
i'm following this thread for a while. i have a x60t and i'm running leopard currently. as soon as sleep is working reliably i'll make the switch.
Well, *beep* me, sleep works on my X60s. Perfectly. I finally had the time to carefully read Silencer's DSDT thread and to try Sebinouse's Extra folder, and voilà, it works like a charm. So all credit goes to you guys. I even get the Trackpoint back on wake using VoodooPS2 instead of ApplePS2Controller (this version: http://forum.voodooprojects.org/index.p ... 718.0.html , and you should remove the Mouse plugin from inside the kext).
Now, I will concentrate on the last missing piece: Vanilla Speedstep. I am using the DSDT and legacy kext from Sebinouse but for some reason it does not work (no c-states), even though we have the exact same CPU.
Also, this is not a priority, but I found this thread relating to the Firewire error messages on boot: http://forum.voodooprojects.org/index.php?topic=200.0 . What I don't understand is that according to the thread, it should already work.
Anyway this is unbelievably great news! I sold my X200s in December to get a more OS X-compatible Thinkpad, and now I am really glad I did.
Extract your SSDT tables as explained in my guide, and send me your DSDT, SSDT, SMBIOS.plist and legacy kext you're using. I will then have a look, where you might have a problem.martin255 wrote:Now, I will concentrate on the last missing piece: Vanilla Speedstep. I am using the DSDT and legacy kext from Sebinouse but for some reason it does not work (no c-states), even though we have the exact same CPU.
Good news ! Even if it doesn't work for me ... I have still the same ApplePS2Mouse issue on wake ... by the way did you remove the Mouse plugin or the Trackpad plugin ?martin255 wrote:Well, *beep* me, sleep works on my X60s. Perfectly. I finally had the time to carefully read Silencer's DSDT thread and to try Sebinouse's Extra folder, and voilà, it works like a charm. So all credit goes to you guys. I even get the Trackpoint back on wake using VoodooPS2 instead of ApplePS2Controller (this version: http://forum.voodooprojects.org/index.p ... 718.0.html , and you should remove the Mouse plugin from inside the kext).
And for the vanilla speedstep ... I used a MacbookPro1,1 model for the smbios.plist / legacy kext and I never generated SSDT table I just pasted the content of Silencer's ... and it worked for me ... to get the SSDT table you can use ACPIDumper
Finally I got my X60t to wake properly !
:at last:
The problem was due to unexpected data from ApplePS2Mouse.kext, so I tried to use SleepWatcher ... and i made 2 script (rc.sleep and rc.wakeup) to unload AppleACPIPS2Nub.kext and ApplePS2Controller.kext from /E/E/ on sleep and load them on wake ...
You can download the files here
Place rc.sleep and rc.wakeup in /etc/
chmod +x these two files
That's it !
That's it !
ernstloeffel
can you summarize what's working for you, and what not at the moment? and also, what installation method did you use? sorry for asking noob questions, i'm beginner with os x.Sebinouse wrote:Finally I got my X60t to wake properly !:at last:
is tablet mode working with tablet magic?
could you maybe post all of your kexts, dsdt and all changed files? i have the latest x60t bios 1.15 which is out for quite a while, so i suppose you probably have the same and i won't have to go through the hazzle of dsdt patching myself.
i have put an atheros ar9280 wifi into my x60t (with hacked bios), it's an original apple pcie card from latest 2009 macbook pro - full 11n with just 2 antennas. it's the main reason for upgrading, because the card doesn't work in leopard and the old atheros card didnt work well.
Everything is working except VGA-Out, IRda, PCMCIA Slot-in, and I have no way to test firewire ...ernstloeffel wrote:can you summarize what's working for you, and what not at the moment? and also, what installation method did you use? sorry for asking noob questions, i'm beginner with os x.
I have never updated my bios ... I gonna check the version on next reboot. mine is 1.08 ...ernstloeffel wrote:could you maybe post all of your kexts, dsdt and all changed files? i have the latest x60t bios 1.15 which is out for quite a while, so i suppose you probably have the same and i won't have to go through the hazzle of dsdt patching myself.
The link for my files can be found in this thread : old installation method, updated EE to keep SLE clean ... I will update this guide when i have enough time ...
You just have to edit info.plist in Atherosfix.kext or LegacyX60t.kext and modify the Vendor/Devide Id.ernstloeffel wrote:i have put an atheros ar9280 wifi into my x60t (with hacked bios), it's an original apple pcie card from latest 2009 macbook pro - full 11n with just 2 antennas. it's the main reason for upgrading, because the card doesn't work in leopard and the old atheros card didnt work well.
Keep us adviced ...
ernstloeffel
thank you for your summary.
i think my new card *should* just work without any changes, i'll report back here. besides the probs i had with the old original atheros ar5001x+ under os x, another reason for upgrading the wifi card was that the new 9-series consumes considerably less power, has 11n and has optimized drivers for windows 7 (the old card drew ~ 8w when downloading large files with 2 mb/s where the new card consumes max ~ 4w).Sebinouse wrote: You just have to edit info.plist in Atherosfix.kext or LegacyX60t.kext and modify the Vendor/Devide Id.
Here are the file you requested, Silencer: http://dl.dropbox.com/u/602349/X60s-martin255.zip I would be really grateful if you could have a look someday. I don't have much time to tinker at the moment, but I will try to work on it on my own too.
Anyway, other than that everything works pretty well. I lose brightness control when waking from sleep, though, so I will probably switch back to Fn+Home/End.
ernstloeffel
that's really old. there have been a lot of fixes since then, including acpi fixes and in particular a "lid close" fix in 1.12Sebinouse wrote: I have never updated my bios ... [snip] mine is 1.08 ...
have a look here:
http://www-307.ibm.com/pc/support/site. ... 48#changes
ernstloeffel
i gave sl a try now. my atheros ar9280 is working since i updated to 10.6.2 out of the box.
however, sleep, sound and tablet don't work for me. i had tablet working, but then it stopped working and i don't see what caused it to stop working.
same with sound: it sometimes works, but then again it just stops working and sound control gets disabled.
same with sleep. i think i have patched my dsdt correctly, but only the hdd stops spinning when i close the lid and the screen remains active. also, the lid close event was working with another boot loader (i now use the recommended asere which fixes restart etc), but with the old boot loader the pc restartet as soon as i reopened the lid.
do you have a clue what's wrong?
i have uploaded my dsdt here:
http://www.mediafire.com/?dgku4j4ibwz
this is my extra folder (basically sebinhouses folder with altered voodoops2controller with new ultranav driver from other thread here, works for me):
http://www.mediafire.com/?0zjyz2goe2z
Here is my latest working config :ernstloeffel wrote:sleep, sound and tablet don't work for me.
DSDT with DTGP/HPET/RTC/IOATAFamily/AHCI/Brightness/Speedstep/IntelGMA950/...
Extentions :
ApplePS2Controller (I think you can use VoodooPS2 but you have to delete ApplePS2 ...)
VoodooMonitor removed
AsereBLN 1.1.9
With this configuration Sound should work.
For sleep you have to installthese files (and update rc.sleep and rc.wakeup if you use VoodooPS2) as I did earlier in this thread.
For tablet, you config should work ... did you check "Launch Daemon on startup" in TabletMagic PrefPane ... My tablet stopped working under Leo when this box was checked
PS: Do you have an Intel GMA950 with the genuine screen ? My boot resolution is only 1024x768 ... and yours 1400x1050 !!!
ernstloeffel
thank you very much! i'm just running pfix now. i've a l7500 core2duo and indeed a genuine sxga+ screen. i'm now using a modified t60p legacy kext based on silencer for that reason (core2duo) and your dsdt.Sebinouse wrote:PS: Do you have an Intel GMA950 with the genuine screen ? My boot resolution is only 1024x768 ... and yours 1400x1050 !!!ernstloeffel wrote:sleep, sound and tablet don't work for me.
Low Intel X25-M G2 SSD read speed in X60s with AHCI
by dandreye » Wed Feb 08, 2017 5:59 am » in Thinkpad X6x Series incl. X6x Tablet - 19 Replies
- 1937 Views
Last post by dandreye
Mon Mar 06, 2017 7:35 pm
Swapped X61s motherboard into X60s, questions on BIOS version / computrace
by thewanderer » Sun Feb 12, 2017 3:01 pm » in Thinkpad X6x Series incl. X6x Tablet - 10 Replies
- 1586 Views
Thu Feb 16, 2017 9:14 am
FS: X60s, Good Oldie, $60 Shipped OBO
by BobA » Mon Mar 13, 2017 3:16 pm » in Marketplace - Forum Members only - 1 Replies
- 1264 Views
Last post by BobA
Fri Mar 24, 2017 2:03 am
X60S password locked?
by Dos3.1 » Mon Mar 13, 2017 5:39 pm » in Thinkpad X6x Series incl. X6x Tablet - 2 Replies
- 1716 Views
Last post by Dos3.1
Mon Mar 13, 2017 10:30 pm
