The Starving Student - Thinkpad T43P Resurrection Project
underclocker
moderator
moderator
Re: The Starving Student - Thinkpad T43P Resurrection Project
#91 Post by underclocker » Sun Jan 31, 2010 11:26 am
I've cleaned them in the past with an old, soft bristle toothbrush and alcohol. A toothbrush for toddlers works best - very small and very soft bristles (great for CPU fan cleaning, too).
A Q-tip will leave lint.
Harryc
#92 Post by Harryc » Sun Jan 31, 2010 12:23 pm
OK, I'll give it a try. Thanks
Harryc
#93 Post by Harryc » Sun Jan 31, 2010 2:31 pm
I cleaned the mPCI slot with a soft bristle brush and alcohol..for several minutes. Let it dry then ran some more tests. The same issue still exists. Not even sure it''s a slot problem because if I push down on or hold up the card the symptoms do not change. I am going to hook up an Ethernet cable and run some more tests. I also swapped RAM modules...no change.
Edit: Ethernet works fine...this is a systemboard issue.
Harryc
#94 Post by Harryc » Sun Jan 31, 2010 10:22 pm
This project has ended for my part anyway. The machine goes back to the OP tomorrow. He has decided to use a PCMCIA WiFi card and to get some use out of the T42 before getting a new machine. Thanks to all for suggestions and donations.
midnight08
#95 Post by midnight08 » Tue Feb 02, 2010 1:45 pm
Thank you everyone! it will be nice having a computer again....
killer
#96 Post by killer » Tue Feb 02, 2010 6:02 pm
@midnight08: Good luck with it, matey.
Harryc has shown great tenacity in this project. I think he deserves a round of applause. :bow:
T540p Win 7 Pro 64
Tasurinchi
#97 Post by Tasurinchi » Tue Feb 02, 2010 6:38 pm
Agreed! :bow:
(we may need a clapping hands smiley)
Pawelek
#98 Post by Pawelek » Wed Feb 03, 2010 12:11 pm
From me: :bow:
T40 and T43 on bookshelf, t61 sxga+ x3100 + T8100 (Mum), t61 sxga+ x3100 t9300 and t420s i5 (mine toys :D), R500 P8400 (sister)
tysong
#99 Post by tysong » Sun Feb 07, 2010 2:44 am
I'll second/third/fourth that... :bow:
By the way... I have a ~dead T43p that I'd be happy to part with. I'm pretty sure the machine is fine except for a hard drive crash and a loud fan... I put it on ebay this morning... I don't imagine it'll go for very much money. At the very least, it might serve as a platform for a resurrected machine.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0527316578
In any case... Back to my post about T42p ethernet driver issues under Windows 7...
http://forum.thinkpads.com/viewtopic.php?f=2&t=84695
:roll:
Harryc
#100 Post by Harryc » Sun Feb 07, 2010 3:36 am
Thanks for the comments everyone, it's appreciated. tysong, if you are willing to donate the machine, I am willing to spend the time to get it working. We'll find a local charity or school for it, another student in need, or any worthy cause you'd prefer. PM me if you're interested.
#101 Post by RealBlackStuff » Sun Feb 07, 2010 5:39 am
Just checking the description on tysong's eBay ad, gives me the impression that all it needs is a reballing of the Southbridge.
$45.- will fix that!
ashat
#102 Post by ashat » Sun Feb 07, 2010 10:44 am
tysong wrote:I'll second/third/fourth that... :bow:
Just to notice that Lenovo's support page description of the product number doesn't match with the ebay announce specifications.
Is this a 14 inch or a 15 inch, (as it looks from the picture) machine?
A.
T41p 2374-GGG P M 1.7GHz, 1Gb RAM, 60GB 7200rpm HDD, 14.1 SXGA+(1400x1050), 128MB Fire GL T2, XPP-SP2
R40 2681-F7G P4-M 2GHz, 256MB, 30GB 4200rpm HDD, 14.1 XGA(1024x768), 16MB ATI Radeon, XPP-SP?
tysong
#103 Post by tysong » Sun Feb 07, 2010 3:59 pm
Ruh roh... Thanks for noting this... It's a 15" machine!
