How to recover password from password manager?
Thinkboy
#1 Post by Thinkboy » Thu Jan 21, 2010 8:11 am
I cannot start password manager anymore. Which means thta I don't have access to my passwords anymore. I have to disable it to be able to browse a webpage with a login. :(
How can I recover the list of passwords stored in password manager? Does this list disappear if I reinstall it?
Thanks for any help.
T60p 14" SXGA+ C2D T7600 2GB RAM
beGi
Re: How to recover password from password manager?
#2 Post by beGi » Tue Jan 26, 2010 5:51 am
I believe that forum rules does not allow password removal/extraction discussions...
terry64
#3 Post by terry64 » Tue Apr 13, 2010 2:49 am
If you've not made a backup of your password I don't think it's possible.
I have the same problem, Password Manager (Currently the one inside CSS 8.0) starts but it just makes a flash on the screen and it then disappears (does anybody have this same problem ?).
But if you have saved/exported your passwords at least once (I hope you made it) you should have a protected .exe somewhere.
When you double click on it it is just like another password manager opens. It asks you the password you selected when you made the backup and you will obviously see the passwords at the time you made the backup.
Unfortunately everything is grayed and you cannot make modifications ... nor save them!
In practice you have a file with a single password you can use to see all the passwords you've saved.
Thinkpad R40 2681-HSG, T61 6460-D6G
#4 Post by RealBlackStuff » Tue Apr 13, 2010 6:33 am
For the very same reason (problems with PW manager) I never use that unreliable crap.
Maybe you can do a System Restore to a date when it was still working?
Make sure to backup personal files if needed.
This is about the only 'help' that's available:
http://www-307.ibm.com/pc/support/site. ... MIGR-56104
Found in this thread (scroll way down to see cleartext):
http://www.experts-exchange.com/Securit ... 16927.html
beGi
#5 Post by beGi » Tue Apr 13, 2010 8:33 am
second link requires registration with credit card info... :/
Harryc
#6 Post by Harryc » Tue Apr 13, 2010 9:05 am
I know that password manager broke with the recent Firefox versions. A security app like that is not reliable if it will break easily. I do not and will not use it.
