Mini PCI-e SSD
Radioguy
Re: Mini PCI-e SSD
#31 Post by Radioguy » Fri Jan 27, 2012 5:54 pm
I think the effort to maximize the use of an older model by trying to exploit every possibility is laudable. I have a free mini-pci-e slot in my T61 that I never used, and putting an SSD in there would be great.
  • T61 - 6465CTO - T9500 - 15.4" LG WSXGA+ - 8GB OCZ- 120GB EVO 850 SSD - X3100 - Win 8.1 Pro 64-bit
loyukfai
Re: Mini PCI-e SSD
#32 Post by loyukfai » Sat Jan 28, 2012 12:51 pm
Sure.
And if you happen to find any reasonably priced mini PCIe SSD (*not* mSATA), please do let us know.
Cheers.
brixvold
Re: Mini PCI-e SSD
#33 Post by brixvold » Tue Mar 18, 2014 4:20 pm
The Super Talent CoreStoreMV SSD 64 GB is available for 75EUR in europe.
I still haven't found any confirmation of a scheme to make a thinkpad boot from it though.
Anyone heard anything?
eyeland
Re: Mini PCI-e SSD
#34 Post by eyeland » Tue Mar 18, 2014 5:17 pm
I was looking into this option as well a while back before I upgraded from my trusty T61 .
As far as I recall, booting the T61 from the mPcie is not supported, but this is not something that I have tested myself.
W530 FHD - 32GB Ram - K2000m - >1TBSSD |
Modded T61| Scarlet Saffire 6i6-Phillips IPS | Win10x64
daybreak broke me loose and brought me back...
dmdsoftware
Re: Mini PCI-e SSD
#35 Post by dmdsoftware » Tue Mar 18, 2014 6:19 pm
Have you guys read the thread? If you want to use a Mini PCI-e SSD, you'll have to use them in the 2.5" SATA slot or solder the i/o from it to the pci-e, and when you do that, then what is the point? The drives in this form factor are slower and more expensive.
X62 SXGA+ i7 5600u
Carbon X1 i5 UHD
W520 quad-i7
X131e AMD
"Think" Ultrabook i7
in storage:
X61T Touch L7500
X61T SXGA+ 8GB
X60/X60s, X61, T61, T420, X30
past:
X24, X23, X22, X21, X20, 390X
flyingfishfinger
Re: Mini PCI-e SSD
#36 Post by flyingfishfinger » Tue Jun 03, 2014 2:22 am
What you're looking at has been discussed fairly often, to varying degrees of success AFAIK. As mentioned, true mini PCIe SSDs are both expensive and probably not the best perfomers
However, I have had some success with physically locating an mSATA SSD in the PCMCIA slot and running a ribbon cable to the main hard drive connector (which I sacrificed). It was part of this project: http://forum.thinkpads.com/viewtopic.php?f=30&t=107360. That machine was recently stolen, so until I can find a satisfactorily cheap and working replacement, the project is on hold...again. I'd be happy to answer questions pertaining to my project, and otherwise I'm sorry for somewhat hijacking the thread.
I hope this may help answer some of your questions though...
Rafael
