Which HP laptops can do that? I think I am tired of waiting for the W701 to show up, and may get another brand.Oliver26n wrote:The HP laptops and displays have firmware & software that allows users to switch between sRGB mode and full gamut mode.
So what kind of LCD is the new FHD 95% gamut LCD on the W510
Bring_back_IPS
Re: So what kind of LCD is the new FHD 95% gamut LCD on the W510
The ones with the Dreamcolor display, I think it's the 8730w. Hell of a price though.
W510 4319-2PU, X201 tablet 2985-C6U, HP 8740W DC2
Bring_back_IPS
I found this on Wikipedia. Is it true? Did MS finally solved the wide gamut problem?
Wide-Gamut Monitor Support
Using a wide-gamut computer monitor with current Windows machines often results in over-saturated colours when displaying items within software that isn't colour managed (eg web browsers, email clients, etc.). This software is generally designed with the assumption that the monitor displays colour with a gamut similar to the sRGB colour space. When used on a monitor that is closer to the AdobeRGB gamut, however, that smaller gamut is simply mapped over a much wider variety of colours leading to this problem. This isn't an issue in colour-managed software, as the display profile allows these packages to correct for this change in a controlled manner.
With Windows 7, however, users will be able to select an extended colour gamut sRGB mode, as well as the larger scRGB gamut. When this is done, the platform will elegantly handle unmanaged software when run on wide-gamut monitors. This will ensure that colours displayed in web browsers, for instance, will better reflect what is seen in a colour managed program such as Photoshop. Naturally, this isn't a replacement for using a proper colour-managed software package, however it is a step forward for users who need to work with software packages that don't offer this functionality.
I have accepted that at least for some work, I will need to have a dual boot with Windows 7 for issues like these. Windows XP is sadly starting to lose grounds in areas like this.
SOLD: Lenovo Thinkpad T440, 256gb SSD, 12GB, i5 4300U, 2.5ghz, FHD 1920x1080
by nizmoz » Sat Dec 31, 2016 7:27 pm » in Marketplace - Forum Members only - 4 Replies
- 687 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
- 3404 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
T420s/430s FHD/2k upgrade
by tomatohat » Sun Feb 05, 2017 1:31 pm » in ThinkPad T430/T530 and later Series - 18 Replies
- 1980 Views
Last post by llemon
Wed May 24, 2017 6:05 pm
[FS] T440p i7 4700mq, dGPU, FHD, 16GB RAM, 256SSD, 256 SSD (ultrabay)
by suchness » Mon Feb 06, 2017 3:40 pm » in Marketplace - Forum Members only - 2 Replies
- 524 Views
Last post by Johan
Thu Feb 09, 2017 11:02 am
