HV121WX4-120 (Matte AFFS panel) on X200 (Pics inside)
jcvjcvjcvjcv
Re: HV121WX4-120 (Matte AFFS panel) on X200 (Pics inside)
#31 Post by jcvjcvjcvjcv » Wed Mar 10, 2010 1:35 am
The big question now is: how is the X201(s)? Same connection as the X200(s)?
W520
T61
Harryc
#32 Post by Harryc » Wed Mar 17, 2010 9:19 pm
I bought an HV121WX4-120 with a digitizer for $99 on EBay and a brand new CCFL WXGA X200 (for a lot more than $99 :) ). I should be able to do this modification early next week. It will probably take me longer to remove the digitizer and touch panel than to do the actual LCD removal/installation.
ZaZ
moderator
moderator
#33 Post by ZaZ » Thu Mar 18, 2010 2:30 am
jcvjcvjcvjcv wrote:The big question now is: how is the X201(s)? Same connection as the X200(s)?
Depends. All the X201 will be LED panels while the X200 can come with either a LED or CFFL, which would will give it a different connector depend on the screen. Since the X201 and X200 share a HMM, my guess would be if you're willing to replace enough parts you could get the CFFL LCD to work in the X201.
Sounds like you're going to have a nice little portable on your hands Harry. Congrats. I'm kind of jealous.
E7440
Harryc
#34 Post by Harryc » Thu Mar 18, 2010 4:56 am
FredGarvin - thanks!
khtse
#35 Post by khtse » Thu Mar 18, 2010 2:43 pm
Harryc wrote:I bought an HV121WX4-120 with a digitizer for $99 on EBay and a brand new CCFL WXGA X200 (for a lot more than $99 :) ). I should be able to do this modification early next week. It will probably take me longer to remove the digitizer and touch panel than to do the actual LCD removal/installation.
Only if the seller knew that there is a higher demand for the panel without the writing surface than for the panel with one... he wouldn't have priced his panel with a scratched writing surface at such a low price. Even a TN panel costs more than $99.
Harryc
#36 Post by Harryc » Thu Mar 18, 2010 3:18 pm
Agreed, but the only way he'd know that is if he was a member here or at notebookreview.com. I am glad he isn't :).
yak
#37 Post by yak » Thu Mar 18, 2010 7:52 pm
What's the difference between 100 and 110 versions of this panel? They seem to be both glossy. Are they both compatible with X200?
Are you sure you got the matte 120 version and not the glossy 100 or 110 one? Are there any more on eBay? I can't find them.
ThinkPad™ X201 / AFFS-120
Harryc
#38 Post by Harryc » Thu Mar 18, 2010 8:10 pm
yak wrote:What's the difference between 100 and 110 versions of this panel? They seem to be both glossy. Are they both compatible with X200?
I don't know the difference between the 100 and 110's, but the 110 is glossy and it is compatible with an X200. As far as what I got, here's the EBay auction.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0413762198
AvalonXIII
#39 Post by AvalonXIII » Thu Mar 18, 2010 8:48 pm
I got my HV121WX4 panel on ebay for $50. I guess some people don't care enough to price them higher :lol:
X61SXGA: L7700/3GB RAM/Toshiba mSATA SSD 64GB/Intel Wifi 5300AGN/4-cell battery/Flexview AFFS SXGA+
AvalonXIII
#40 Post by AvalonXIII » Thu Mar 18, 2010 9:15 pm
I get used to both actually, but I may just be flexible.
There is no outdoor readable panel. That's only for LED-backlit.
There's only one type of CCFL panel.
andykrej wrote:
I have thought about this for some time, but on the other hand, I'm quite happy with my X61s SXGA+. And I'm not too much into sacrificing 30 % of the resolution by going to WXGA. Avalon, how does it feel working on WXGA compared to SXGA+ ?
Also, which panel would be the best for this? I think the outdoor readable one would make most sence, but I have never seen any x20x display in real life.
AvalonXIII
#41 Post by AvalonXIII » Thu Mar 18, 2010 9:18 pm
X201(s) now comes with LED screen as standard. If you want to replace the screen, you'll have to replace the whole upper assembly.
ricerocket
#42 Post by ricerocket » Thu Mar 18, 2010 11:12 pm
So if LED is standard......
Why wouldn't they use the same connector scheme as the tablet? Might as well try to standardize, right?
Who wants to tear into their brand new laptop?
TP of yore: 380ED/600E/770/T20/T23/T30/T43/T60p/X41T
Current: X200s
ansible212
#43 Post by ansible212 » Fri Mar 19, 2010 2:11 am
AvalonXIII wrote:X201(s) now comes with LED screen as standard. If you want to replace the screen, you'll have to replace the whole upper assembly.
The X201 WXGA shares the same upper assembly as you call it with the X200, regardless of whether the screen is LED or CCFL backlit.
X220 : Premium HD : Core i7-2640M : 8GB : 256GB Samsung 850 Pro : WWAN : Intel AC7260 : Mini Dock Series 3 with USB 3.0 : ThinkPad USB keyboard : 2 x HP LP2475w : Win 10 64bit
X200s : WXGA (LED) : C2D SL9600 : 4GB : 256GB Samsung 830 : WWAN : Intel AC7260 : Broadcom Crystal HD : UltraBase : Win 10 64bit
Harryc
#44 Post by Harryc » Sat Mar 20, 2010 2:07 pm
Ok, so I received the HV121WX4-120. It is a FRU# 45N6091, which is a CCFL LCD from an X200 TABLET 12.1 WXGA. It does not have any glass touch panel, but it does have a digitizer card taped to the back. My understanding in looking at the X200T maintenance manual is that there are (2) types of X200 tablet LCD's, one is a single touch panel, and the other is a direct bonding glass model (multitouch ?). I'd assume that I have the single touch panel model. Will this fit in an X200? It is very thin, so I am not worried about the thickness of it, just the connector. It appears to be 1.25 inches long or so. Also, I'd assume that if it does fit I can just leave the digitizer card in place? I'm not trying to be lazy here, it's just that I'd rather not take apart a one day old X200 for no particular reason ;).
khtse
#45 Post by khtse » Sun Mar 21, 2010 2:54 pm
Harryc wrote:Ok, so I received the HV121WX4-120. It is a FRU# 45N6091, which is a CCFL LCD from an X200 TABLET 12.1 WXGA. It does not have any glass touch panel, but it does have a digitizer card taped to the back. My understanding in looking at the X200T maintenance manual is that there are (2) types of X200 tablet LCD's, one is a single touch panel, and the other is a direct bonding glass model (multitouch ?). I'd assume that I have the single touch panel model. Will this fit in an X200? It is very thin, so I am not worried about the thickness of it, just the connector. It appears to be 1.25 inches long or so. Also, I'd assume that if it does fit I can just leave the digitizer card in place? I'm not trying to be lazy here, it's just that I'd rather not take apart a one day old X200 for no particular reason ;).
So the scratch is on the screen itself? :(
I was under the impression that even the single touch model has a touch panel (may or may not be made of glass) on top of the LCD panel, since the LCD itself cannot sense touch input.
Anyway, I remember reading on a Taiwanese forum that someone successfully installed the screen with the digitizer still on the back. Can't find that page right now, so I may be wrong. But since it's only held by tape, you should be able to remove it easily.
AvalonXIII
#46 Post by AvalonXIII » Sun Mar 21, 2010 3:49 pm
The CCFL X200t model doesn't have touchscreen, so there is no touch panel on the front.
Harryc
#47 Post by Harryc » Sun Mar 21, 2010 4:02 pm
AvalonXIII wrote:The CCFL X200t model doesn't have touchscreen, so there is no touch panel on the front.
Thanks for the information. That's the LCD I bought then. @khtse, it has a small scuff on the upper left. Here's a pic of it installed. Look to the right of the IE icon...and yes the digitizer is still there.
http://home.comcast.net/~harryc56/Jpegs/X200_AFFS.jpg
Subliming
#48 Post by Subliming » Wed Mar 24, 2010 10:03 pm
khtse wrote:I remember reading on a Taiwanese forum that someone successfully installed the screen with the digitizer still on the back. Can't find that page right now, so I may be wrong. But since it's only held by tape, you should be able to remove it easily.
By digitizer are you referring to the WACOM chip and circuitry on the back? That definitely does not need to be removed. I wonder if it consumes power even though its functions are not used?
Harryc
#49 Post by Harryc » Thu Mar 25, 2010 12:38 am
Subliming wrote: That definitely does not need to be removed. I wonder if it consumes power even though its functions are not used?
There is no LCD cable hooked to it in this scenario, so it does not consume power.
variant
#50 Post by variant » Thu Mar 25, 2010 6:46 pm
I wasn't able to tell from this thread, but is a HV121WX4-110 a direct drop-in as well? I know the 110 and 100 are glossy. There are lots of 100s and 110s up on ebay (though no 120s)... are these directly compatible and a drop-in, like the 120?
http://cgi.ebay.com/BOEHYDIS-HV121WX4-1 ... 2265wt_940
Does that look like the right thing? I've got an X200s with the WXGA CCFL panel.
Subliming
#51 Post by Subliming » Thu Mar 25, 2010 10:49 pm
variant wrote:I wasn't able to tell from this thread, but is a HV121WX4-110 a direct drop-in as well? I know the 110 and 100 are glossy. There are lots of 100s and 110s up on ebay (though no 120s)... are these directly compatible and a drop-in, like the 120?
That panel will work. You will have to remove the glass though. The glass will be all scratched up but underneath the glossy screen should be pristine.
Once you receive that panel I would hook it up and test it out before cutting the glass off to be sure that it works.
yak
#52 Post by yak » Thu Mar 25, 2010 10:58 pm
I'm also thinking about getting the 110 (would prefer 120 but the glossiness of 110 is not that bad supposedly). Since I can't find a source here in Europe, I will probably have to get it from US (which means: higher shipping cost, long shipping time, customs taxes).
Is there somebody from Europe here that knows some local source?
My other concern was the choice between new and used panel. As Subliming pointed out, these screens come with glass writing surface which has to be removed so there is no need to worry about the panel underneath being scratched. But what about other defects? How old can these panels be? Should I worry about backlight not being bright as in a new panel? Any other problems these screens are prone to?
Subliming
#53 Post by Subliming » Thu Mar 25, 2010 11:24 pm
yak wrote:My other concern was the choice between new and used panel. As Subliming pointed out, these screens come with glass writing surface which has to be removed so there is no need to worry about the panel underneath being scratched. But what about other defects? How old can these panels be? Should I worry about backlight not being bright as in a new panel? Any other problems these screens are prone to?
If the screen is a -100 or 110 it will likely be from 2006-2007 and may or may not have been used much. They are generally pulls from old gateway brand tablets.
The brightness of the CCFL will vary and is sort of a lottery with these used panels. Over time the CCFL will near the end of its life and you will notice it visually. Whites will have a pink tint, the screen noticeably darker and you might even see flickering.
iwishiwasinwhistler
#54 Post by iwishiwasinwhistler » Sat Apr 03, 2010 10:57 am
Just wanted to say thanks to khtse for posting your .icm profile.
I did this mod back in September on my x200s with the glossy version of the HV121WX4 panel and it made a huge difference then. However the profile you posted is like the next step up and I'm really pleased. I don't own a Spyder and most of my time is spent in Linux so support for making and using profiles is slightly more difficult.
Until recently I had no idea what a vast difference colour management made. I've read that Safari and Firefox (with the optional colour management plugin) are the only browsers that currently support it. I've had to scrap using Chrome for browsing because it looks so washed out - I've been spoilt by the incredible colours within Firefox! (firefox is almost as fast as Chrome anyway when you load the profile into RAM)
Editing and viewing photos now also looks much better.
Thank you very much.
ricerocket
#55 Post by ricerocket » Wed Apr 07, 2010 9:59 am
Why aren't you using a system-wide profile?
Current: X200s
yak
#56 Post by yak » Sun Apr 11, 2010 6:43 pm
There are two HV121WX4-120 on eBay right now, here's one:
http://cgi.ebay.com/A-NEW-HV121WX4-120- ... 5191c979c4
They are advertised as GLOSSY. I was under the impression that 120 indicated a matte version. Can anyone shed some light on this?
There is no mention of a digitizer/writing surface.
-- ADDED --
Just saw they are advertised as LED too...
Harryc
#57 Post by Harryc » Sun Apr 11, 2010 6:47 pm
It is a matte LCD. That EBay ad also states "Hyundai HV121WX4-120". The HV121WX4-120 is a Boe Hydis LCD. That entire LCD auction is suspect IMHO.
yak
#58 Post by yak » Sun Apr 11, 2010 6:54 pm
Harryc wrote:It is a matte LCD. That EBay ad also states "Hyundai HV121WX4-120". The HV121WX4-120 is a Boe Hydis LCD. That entire LCD auction is suspect IMHO.
Thanks. I've let them know and asked to check again what they have and correct it.
yak
#59 Post by yak » Tue Apr 13, 2010 8:30 am
Got an answer:
The item we have is LED glossy finish. HV121WX4-120 is LED glossy screen we
have. Please make sure your screen is exactly same part number.
OK, so they can't be trusted, maybe it's not even a HV121WX4-120. I'll skip.
Harryc
#60 Post by Harryc » Tue Apr 13, 2010 8:51 am
yak wrote: OK, so they can't be trusted, maybe it's not even a HV121WX4-120. I'll skip.
Good idea...'LED' is also incorrect.
Users browsing this forum: nitrocaster and 5 guests
