When I sleep (close lid, or from button), upon wake, CPU is on max performance and temp goes back to 60 C (just as there is no speedstep).
C and P states seem to break after sleep.
Please advise.
Weird. I have been using sleep for some time (not anymore), and it was fine (except for the sound). Can you check what eats CPU after wake? Install iStat (version 2.0 is free, google it up), and check the processes there after wake. It might be that some software you installed is problemtatic.bgalakazam wrote:Silencer, I have this problem and verified it over 2 weeks time.
C and P states seem to break after sleep.D
Don't need to sacrifice anything, it works with VoodooHDA before and after sleep, but VoodooHDa has some sound quirks after waking up. Just get one of my latest packs (or someone else's) and use VoodooHDA.kext from there.bgalakazam wrote:Silencer, what do I have to change so I get microphone working at the cost of sleep? I want to give it a try since I won't be using sleep that much, but I need Skype
Well the issue is still there. I sleep,then on wake, CPU temps go to 65-70 C. stayed like that for 30 min. No process was taking more than 1%. I restarted, and CPU temp dropped instantly to 46-48 C.Silencer wrote:Weird. I have been using sleep for some time (not anymore), and it was fine (except for the sound). Can you check what eats CPU after wake? Install iStat (version 2.0 is free, google it up), and check the processes there after wake. It might be that some software you installed is problemtatic.
Well, I've been a bit rusty lately, didn't check any updated kexts, since my setup was working just fine. But I've just quickly tried latest FakeSMC.kext with plugins, and no luck so far. The only additional value I could see in iStat was CPU voltage, which is not very useful. ThinkPad fan is not detected automatically, need to try to mess with DSDT. The same goes for GPU temperature. So I've now returned to the original FakeSMC.kext.mightycrown wrote:Hi.
I m just wondering have you ever figured out any optimized way to control fan? BTW are you able to get fan and other sensor reading via the new version of Fakesmc?
Thanks for your guild. It definitely educated me!
HiSilencer wrote: Well, I've been a bit rusty lately, didn't check any updated kexts, since my setup was working just fine. But I've just quickly tried latest FakeSMC.kext with plugins, and no luck so far. The only additional value I could see in iStat was CPU voltage, which is not very useful. ThinkPad fan is not detected automatically, need to try to mess with DSDT. The same goes for GPU temperature. So I've now returned to the original FakeSMC.kext.
The thread is not dead, but the answer to your question is in the very first original post. To decode the binary DSDT you will need to use a tool called DSDTSE. The the original post for links and description.Charlie.Brown wrote:Perhaps I am digging up an old, dead, thread. If I am, please forgive me. After using Lavalay's tool, my DSDT among all the other devices ACPI had been dumped in a bin format. I am supposed to rename this to .dsl or .asl, or was there an option to dump to these format's that I had missed? I am currently in my Linux distro making my second SSD bootable for the initial Leo install. Hopefully I am able to answer my own question before I make my self look stupid and if not, well thank you for your help guys. I really appreciate this thread
Intel ACPI Component Architecture
ASL Optimizing Compiler version 20091214 [Dec 16 2009]
Copyright (C) 2000 - 2009 Intel Corporation
Supports ACPI Specification Revision 4.0
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 37: Device (PNLF)
Error 4096 - syntax error, unexpected PARSEOP_DEVICE, expecting '{' ^
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 44: {
Error 4096 - syntax error, unexpected '{' ^
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 45: If (LEqual (\SCMP (\_OS, "Microsoft Windows"), Zero))
Error 4064 - Object does not exist ^ (\SCMP)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 47: Store (0x01, \W98F)
Error 4064 - Object does not exist ^ (\W98F)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 51: If (CondRefOf (\_OSI, Local0))
Remark 5113 - Local or Arg used outside a control method ^
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 55: Store (0x01, \WNTF)
Error 4064 - Object does not exist ^ (\WNTF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 56: Store (0x01, \WXPF)
Error 4064 - Object does not exist ^ (\WXPF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 57: Store (0x00, \WSPV)
Error 4064 - Object does not exist ^ (\WSPV)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 62: Store (0x01, \WSPV)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 67: Store (0x02, \WSPV)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 72: Store (0x01, \WVIS)
Error 4064 - Object does not exist ^ (\WVIS)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 77: If (LEqual (\SCMP (\_OS, "Microsoft Windows NT"), Zero))
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 79: Store (0x01, \WNTF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 83: If (LEqual (\SCMP (\_OS, "Microsoft WindowsME: Millennium Edition"), Zero))
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 85: Store (0x01, \WMEF)
Error 4064 - Object does not exist ^ (\WMEF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 86: Store (0x01, \W98F)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 91: Store (One, WNTF)
Error 4064 - Object does not exist ^ (WNTF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 92: Store (One, WXPF)
Error 4064 - Object does not exist ^ (WXPF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 93: Store (0x02, WSPV)
Error 4064 - Object does not exist ^ (WSPV)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 94: Store (One, WVIS)
Error 4064 - Object does not exist ^ (WVIS)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 97: Store (0x01, \H8DR)
Error 4064 - Object does not exist ^ (\H8DR)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 100: Store (0x01, \OSIF)
Error 4064 - Object does not exist ^ (\OSIF)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 101: \_SB.PCI0.LPC.MOU.MHID ()
Error 4064 - Object does not exist ^ (\_SB.PCI0.LPC.MOU.MHID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 102: Store (\SRAH, \_SB.PCI0.RID)
Error 4064 - Object does not exist ^ (\SRAH)
Error 4064 - Object does not exist ^ (\_SB.PCI0.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 103: If (VIGD)
Error 4064 - Object does not exist ^ (VIGD)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 105: Store (\SRHE, \_SB.PCI0.VID.RID)
Error 4064 - Object does not exist ^ (\SRHE)
Error 4064 - Object does not exist ^ (\_SB.PCI0.VID.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 109: Store (\SRHE, \_SB.PCI0.AGP.RID)
Error 4064 - Object does not exist ^ (\_SB.PCI0.AGP.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 112: Store (\SRE0, \_SB.PCI0.EXP0.RID)
Error 4064 - Object does not exist ^ (\SRE0)
Error 4064 - Object does not exist ^ (\_SB.PCI0.EXP0.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 113: Store (\SRE1, \_SB.PCI0.EXP1.RID)
Error 4064 - Object does not exist ^ (\SRE1)
Error 4064 - Object does not exist ^ (\_SB.PCI0.EXP1.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 114: Store (\SRE2, \_SB.PCI0.EXP2.RID)
Error 4064 - Object does not exist ^ (\SRE2)
Error 4064 - Object does not exist ^ (\_SB.PCI0.EXP2.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 115: Store (\SRE3, \_SB.PCI0.EXP3.RID)
Error 4064 - Object does not exist ^ (\SRE3)
Error 4064 - Object does not exist ^ (\_SB.PCI0.EXP3.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 116: Store (\SRU0, \_SB.PCI0.USB0.RID)
Error 4064 - Object does not exist ^ (\SRU0)
Error 4064 - Object does not exist ^ (\_SB.PCI0.USB0.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 117: Store (\SRU1, \_SB.PCI0.USB1.RID)
Error 4064 - Object does not exist ^ (\SRU1)
Error 4064 - Object does not exist ^ (\_SB.PCI0.USB1.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 118: Store (\SRU2, \_SB.PCI0.USB2.RID)
Error 4064 - Object does not exist ^ (\SRU2)
Error 4064 - Object does not exist ^ (\_SB.PCI0.USB2.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 119: Store (\SRU3, \_SB.PCI0.USB3.RID)
Error 4064 - Object does not exist ^ (\SRU3)
Error 4064 - Object does not exist ^ (\_SB.PCI0.USB3.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 120: Store (\SRU7, \_SB.PCI0.USB7.RID)
Error 4064 - Object does not exist ^ (\SRU7)
Error 4064 - Object does not exist ^ (\_SB.PCI0.USB7.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 121: Store (\SRPB, \_SB.PCI0.PCI1.RID)
Error 4064 - Object does not exist ^ (\SRPB)
Error 4064 - Object does not exist ^ (\_SB.PCI0.PCI1.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 122: Store (\SRLP, \_SB.PCI0.LPC.RID)
Error 4064 - Object does not exist ^ (\SRLP)
Error 4064 - Object does not exist ^ (\_SB.PCI0.LPC.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 123: Store (\SRSA, \_SB.PCI0.IDE0.RID)
Error 4064 - Object does not exist ^ (\SRSA)
Error 4064 - Object does not exist ^ (\_SB.PCI0.IDE0.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 124: Store (\SRSA, \_SB.PCI0.SATA.RID)
Error 4064 - Object does not exist ^ (\_SB.PCI0.SATA.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 125: Store (\SRSM, \_SB.PCI0.SMBU.RID)
Error 4064 - Object does not exist ^ (\SRSM)
Error 4064 - Object does not exist ^ (\_SB.PCI0.SMBU.RID)
/Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl 128: Device {
Error 4096 - syntax error, unexpected PARSEOP_DEVICE, expecting $end ^
ASL Input: /Users/maxrobbins/Library/Application Support/EvOSoftware/DSDT/DSDTFiles/dsdt.dsl - 13595 lines, 466994 bytes, 63 keywords
Compilation complete. 58 Errors, 0 Warnings, 1 Remarks, 21 Optimizations
Because you are being so kind. There are absolutely no differences in our DSDT's except our video cards. Mine has the string 7145 as I am sure you are well aware of. If this is already included in the DSDT provided in the first post I'm going straight to Snow. If not, could you please provide the appropriate DSDT Silencer? Thank you.Silencer wrote:You have a very simple syntax problem somewhere near PNLF device. Upload your DSDT somewhere, I'll have a look.
In that case you can use one of my DSDTs from the posts above, no need to edit yours.Charlie.Brown wrote:There are absolutely no differences in our DSDT's except our video cards.
Well, AsereBLN is the bootloader of choice, it actually makes a lot of things easier and better. Make sure you are able to use it before going forward with further improvements.Charlie.Brown wrote:Oh and I am posting from my hackintosh right now. I am able to get Leo working 100% but whenever I use AresBLN 1.1.9, it never works.
Well, theoretically it should be possible, but there is some hardware where re-labeling doesn't do the trick. GPU is one of that hardware. I've tried with my card to relabel it as X1600, and had no luck. What works though, is modification of a kext *.plist to include your ID.chris-uk wrote: something i've been wondering is this - given my graphics card (71D4) is the same as 71DE (this is what i changed in patching my kexts on 10.5) - is it possible in DSDT to 'relabel' the graphics card ID rather than having to patch kexts?
Sure, it's actually set up now to switch off at 55 degrees and switch on at 60. But this can be easily adjusted, it's just you don't want to have the same threshold, otherwise fan will start and stop almost constantly.Anastasius wrote:And is there a way to turn fan completely off when having CPU temperature around 60C, for example? As it is with TpFanControl on Windows?
Sorry for noob question, where do I modify this value? Thank you!!!Silencer wrote: Sure, it's actually set up now to switch off at 55 degrees and switch on at 60. But this can be easily adjusted, it's just you don't want to have the same threshold, otherwise fan will start and stop almost constantly.
As an offtopic, I'm using SwitchResX - the whole picture gets flipped or rotated 90,180,270 with a click of a button. I also modified TabletMagic driver to flip the tablet portion as well.grandflash wrote:Can someone test it to, please? In my case, the mouse cursor is not flipped 180° too, that is really bad. Maybe it is related to the tablet driver or ps2?
In DSDT. Check the original thread regarding fan speed control I've linked above, there's the code example that explains how to do it.Anastasius wrote: Sorry for noob question, where do I modify this value? Thank you!!!![]()
Silencer, may you help me to flip the tablet portion? How do you enable this feature. Thanks for your help in advance.As an offtopic, I'm using SwitchResX - the whole picture gets flipped or rotated 90,180,270 with a click of a button. I also modified TabletMagic driver to flip the tablet portion as well.
I would help if I had a tablet. Never had any experience with them. I think Sebinouse should be able to help you better, check out this thread.grandflash wrote: Silencer, may you help me to flip the tablet portion? How do you enable this feature. Thanks for your help in advance.
This is quite interesting. I've spent quite some time working out how to make AppleHDA work, and almost succeeded, but on T60/T60p/X60 we have 1981HD audio codec, which is rather buggy and it will not work with AppleHDA properly.In my DSDT (X61tablet) i fixed a lot of devices like IntelHDA1984 (Sound), IntelGMAx3100(Video), Serialport for Tablet and WiFi of course. I had a legacy kext in E/E doing this prior. He provided a patched AppleHDA.kext too (X61tablet with AD1984) in the linked post above.
Scope (\_PR.CPU0)
Name (HI0, 0x00)
Name (HC0, 0x00)
Method (_PDC, 1, NotSerialized)
CreateDWordField (Arg0, 0x00, REVS)
CreateDWordField (Arg0, 0x04, SIZE)
Store (SizeOf (Arg0), Local0)
Store (Subtract (Local0, 0x08), Local1)
CreateField (Arg0, 0x40, Multiply (Local1, 0x08), TEMP)
Name (STS0, Buffer (0x04)
0x00, 0x00, 0x00, 0x00
Concatenate (STS0, TEMP, Local2)
_OSC (Buffer (0x10)
/* 0000 */ 0x16, 0xA6, 0x77, 0x40, 0x0C, 0x29, 0xBE, 0x47,
/* 0008 */ 0x9E, 0xBD, 0xD8, 0x70, 0x58, 0x71, 0x39, 0x53
}, REVS, SIZE, Local2)
Method (_OSC, 4, NotSerialized)
CreateDWordField (Arg3, 0x00, STS0)
CreateDWordField (Arg3, 0x04, CAP0)
CreateDWordField (Arg0, 0x00, IID0)
CreateDWordField (Arg0, 0x04, IID1)
CreateDWordField (Arg0, 0x08, IID2)
CreateDWordField (Arg0, 0x0C, IID3)
Name (UID0, Buffer (0x10)
CreateDWordField (UID0, 0x00, EID0)
CreateDWordField (UID0, 0x04, EID1)
CreateDWordField (UID0, 0x08, EID2)
CreateDWordField (UID0, 0x0C, EID3)
If (LNot (LAnd (LAnd (LEqual (IID0, EID0), LEqual (IID1, EID1)),
LAnd (LEqual (IID2, EID2), LEqual (IID3, EID3)))))
Store (0x06, STS0)
Return (Arg3)
If (LNotEqual (Arg1, 0x01))
Store (0x0A, STS0)
Return (Arg3)
Or (And (PDC0, 0x7FFFFFFF), CAP0, PDC0)
If (And (CFGD, 0x01))
If (LAnd (LAnd (And (CFGD, 0x01000000), LEqual (And (PDC0,
0x09), 0x09)), LNot (And (SDTL, 0x01))))
Or (SDTL, 0x01, SDTL)
OperationRegion (IST0, SystemMemory, DerefOf (Index (SSDT, 0x01)), DerefOf (Index (SSDT, 0x02
Load (IST0, HI0)
If (And (CFGD, 0xF0))
If (LAnd (LAnd (And (CFGD, 0x01000000), And (PDC0, 0x18
)), LNot (And (SDTL, 0x02))))
Or (SDTL, 0x02, SDTL)
OperationRegion (CST0, SystemMemory, DerefOf (Index (SSDT, 0x07)), DerefOf (Index (SSDT, 0x08
Load (CST0, HC0)
Return (Arg3)
Well, usually you have to not only patch _CST function but also PSS. CST is for C-states and PSS is for P-states, which is actual speedstep. My Thinkpad ACPI already has proper definition of speedstep which works well with OSX. so I only patch CST to enable deep sleep and lower power consumption.chinaski wrote:@Silencer:
Can you please explain what exactly you are doing by patching the CPU0/CPU1 scopes in DSDT in order to enable speedstep feature.
It seems that you are overwriting the _CST function (= what gets executed when the system wants to enter a cstate?) but i couldn't find your code snippet or anything similar neither in the original MacBook1,1 DSDT/SSDTs nor in my Thinkpad x60ts DSDT/SSDTs. There are no _CST functions or C*M* arrays!
I extracted them all via "acpidump -a" and grepped them for "CST" or "C1M1" "C1M2" and so on... so I'm pretty sure. Weird :/Silencer wrote: It looks like you didn't extract all SSDT tables, there are a bunch of them.
