OK.
Thank you for advises, I will try to find the problem, for me is too much another laptop...
And, I cannot accept that a problem like this can stop me.
All I need is to separate the VCC3M from chip to chip.
T41 LCD inverter problems
Re: T41 LCD inverter problems
Hey, Jimmy!
Have you alreday solved your problem with not working backlight? I have the same symptoms on T43, so I am searching for some advice how to get over it.
In my case CCFL and inverter are working, F3,F8 fuses are giving 3,3V, F7 around 16V, but on the LCD connector, there is no pin with that voltage.
Hello, first post in years here so please be kind
I'm debugging a T43p backlight problem and am measuring about 4.7V on F7 when powered (my good T43 measures ~16V as expected). What can I infer as the possible cause? Have the dim LCD, LEDs operational, and a known good inverter. I suppose there's some switch upstream of F7 and/or more fuses. Any help would be appreciated, including schematics.
Many thanks,
Chris
Many thanks,
Chris
T60p backlight problem - inverter or panel?
by bloovis » Thu Apr 27, 2017 5:36 am » in ThinkPad T6x Series - 7 Replies
- 847 Views
Last post by bloovis
Wed May 24, 2017 3:13 pm
- 5 Replies
- 281 Views
Wed Jun 28, 2017 2:40 am
WTT: T41 w/LCD lines + T61 broken ultranav key
by Raidriar » Wed Mar 22, 2017 10:47 am » in Marketplace - Forum Members only - 1 Replies
- 209 Views
Wed Mar 22, 2017 1:46 pm
Wake up after suspend problem on T41 with new SSD on IDE2SATA controller
by Mac-Chatter » Sat Mar 04, 2017 6:10 am » in ThinkPad T4x Series - 0 Replies
- 1745 Views
Last post by Mac-Chatter
Users browsing this forum: karotlopj and 2 guests
