Car Adapter
JHEM
#31 Post by JHEM » Sun Feb 27, 2005 2:52 pm
Leon wrote:won't hurt, but IMO not necessary.....
IMO a waste of money.
Your power brick will give up it's life before it allows anything injurious to pass through it.
I'd wager that 99% of all the laptops that died from a nearby lightning strike, or other spike or transient, succumbed due to the current entering via the modem connector not the power connector.
Regards,
James
James at thinkpads dot com
aamsel
Moderator1
Moderator1
#32 Post by aamsel » Sun Feb 27, 2005 2:53 pm
I just bought one on EBAY for less than 1/2 price shipped (about $60), so hopefully I can tell you about it next week.
It is much thinner and ligher, but not smaller...just thinner and lighter. Comes with the cords for a/c, car, or airplane (yeah, like I am gonna be flying First Class real soon) <grin>
Andrew
Austin, TX
krosenstein wrote:Speaking of car adapters . . .
Does anyone have any experience with the Targus Universal Adapter PAPWR300U? It looks like it's smaller and lighter than the IBM brick.
texasdiver
#33 Post by texasdiver » Mon Feb 28, 2005 2:27 pm
Can't imagine how you could get a massive surge through your cigarette lighter that would pass through both the inverter and your power supply. So I wouldn't bother with the surge protector.
I also use the inverter route. A cheap inverter that I bought from WalMart. Actually I don't use it with the new thinkpad as I dont' use that in the car. What I do use it for is to run my old Dell Inspiron 5000 to play movies for my kids while we are on road trips. The 15" display on the Inspiron beats the heck out of any cheap portable DVD players on the market. And it's a lot cheaper than the built-in DVD players.
As for using these things on airplanes, that is the one good reason to get the universal adaptor from Targus or Kensington. It isn't just first class. Take a look at
http://www.seatguru.com/
You can find the power ports on any US airline.
rhema83
#34 Post by rhema83 » Mon Feb 28, 2005 11:52 pm
Can a capacitor and a resistor be used in tandem to smooth out the square wave?
X61 7675-CTO Merom 2.0GHz 4GB RAM, 7K200 HDD
texasdiver
#35 Post by texasdiver » Tue Mar 01, 2005 8:50 am
This is a huge topic in the sailing and yachting worlds where inverters are used to power a huge number of electric devices at sea. That's because it is usually far cheaper to buy cheap 110v electrical appliances like microwaves, vacuums, shavers, coffee makers, etc. than buy specially-made 12v DC appliances that cost far more. So if you go to boating chat rooms they are always talking about inverters and batteries, especially the sailboat crew.
In order to get a true sine wave inverter you're probably looking at starting at $800 for something like this West Marine unit:
http://www.westmarine.com/webapp/wcs/st ... storeNum=9
lI would take the advice of others upstream and just get a cheap inverter from Walmart or radio shack and trust your power adaptor. Thousands of others do this without problem and they are designed to take power from less than clean sources. I've powered laptops, camera battery rechargers, camcorder rechargers, and various other items off my $25 Walmart inverter without the slightest problem.
kev009
#36 Post by kev009 » Wed Mar 02, 2005 7:58 pm
texasdiver wrote:Can't imagine how you could get a massive surge through your cigarette lighter that would pass through both the inverter and your power supply. So I wouldn't bother with the surge protector.
My thought is that the surge protector might have a ferrite or other noise filtering equipment. Do those small in line notebook surge protectors do that?
http://www.kev009.com/ - Blog
http://ps-2.kev009.com:8081/ - IBM Retro Archive
IBM ThinkPad T42, vintage 730TE, RS/6000 7006-42T, 7011-250, 7012-397, 7012-G40 (upgraded to 4x 200MHz PPC), xSeries rack servers, NetVista 2800
Sun Oracle Ultra 27 Xeon (i7) Quad Core 3.20GHz
SGI Fuel
frankiepankie
#37 Post by frankiepankie » Mon May 26, 2008 8:34 am
I used a cheap 150 Watt inverter (modified sinus) on the road to my vacation place, but it didn't worked correctly.
The AC adapter from my ThinkPad would make a buzzing/crackling sound, and the battery led on my T40 would flash for 1 second.
I have 2 AC adapters here, a 02K6754, and a 02K6751.
Sometimes it would work, and i could use it to charge the battery of my ThinkPad, or just use the ThinkPad.
I now ordered a Voltcraft transformator (from Conrad electronics) which transforms 12V DC to a range starting at 12V and ending at 24V.
It can deliver 6A, so it should work flawless.
Should receive it this week.
Lenovo ThinkPad T410
Msmax
#38 Post by Msmax » Mon May 26, 2008 10:22 am
I have bought an IBM AC/DC Combo adapter which has 2 entries:
- 1 for 100-240VAC
- 1 for 11.5-18VCD
IBM P/N 22P9004 - FRU 22P9022
Cost me only 30 euro and works perfect.
Msmax
frankiepankie
#39 Post by frankiepankie » Mon May 26, 2008 2:39 pm
WOW That's a nice bargain
Groetjes van uit Drenthe :lol:
Msmax
#40 Post by Msmax » Mon May 26, 2008 4:03 pm
Actually I bought 3 of them...
One was without the car cable. have to make 1 cable myself.
Msmax
Users browsing this forum: micrex22 and 39 guests
