Ultranavi Driver based on VoodooPS2
Re: Ultranavi Driver based on VoodooPS2
Tested, and horizontal scroll works like a charm!
For those who are lazy, here's the complete pack: VoodooPS2_ThinkPad.zip
Intel Core 2 Duo T7600
Looks like the x64 version of ThinkpadUltraNav.kext is problematic. I've finally tested it in x64 and got the following and Kernel Panic:
kernel Kext cn.sh.fang.ThinkpadUltraNav - library kext com.apple.kernel.libkern not found.
kernel Can't load kext cn.sh.fang.ThinkpadUltraNav - failed to resolve library dependencies.
kernel Kext cn.sh.fang.ThinkpadUltraNav failed to load (0xdc00800e).
kernel Failed to load kext cn.sh.fang.ThinkpadUltraNav (error 0xdc00800e).
kernel Couldn't alloc class "ThinkpadUltraNav"ThinkPad T60p with Snow Leopard 10.6.8
Not working on a X60t ... even if it seems to load properly and it finds a mouse during boot :
I've tried Silencer's version of VoodooPS2Controller.kext and neither trackpoint nor scrolling work (no mouse found in SysPref ...)
Any idea ?
16/04/10 10:50:30 kernel ThinkpadUltranavi loaded
16/04/10 10:50:30 kernel ThinkpadUltranavi: mouse info 0.0.100Any idea ?
Lenovo X60t (6363-AQ8)
- Intel CoreDuo 1,67 GHz (L2400)
- 3 Go / 320 Go / GMA950 / FW 400 / SD Card
- Bluetooth / Wifi AR5BXB6 / Tablet
Ok, I've fixed the problem that I had. Default dependecies in Info.plist of ThinkpadUltraNav.kext were wrong. Here's the fixed version: VoodooPS2Controller_ThinkPad_i386_x64.zip
This is the part that needed to be fixed:
Now it works fine in x64.
<key>OSBundleLibraries</key>
<dict>
<key>com.apple.iokit.IOHIDSystem</key>
<string>1.1</string>
<key>com.apple.kpi.bsd</key>
<string>8.0.0</string>
<key>com.apple.kpi.iokit</key>
<key>com.apple.kpi.libkern</key>
<key>com.apple.kpi.mach</key>
<key>com.apple.kpi.unsupported</key>
<key>org.voodoo.driver.PS2Controller</key>
</dict>
<key>OSBundleRequired</key>
<string>Console</string>
nuskoolkiddie
is it possible to use the middle mouse button as middle mouse button (for opening and closing tabs in a browser for example)
This ultranavi kext doesn't work for me and I use SmartScroll to get Scroll with the middle button, and this button works like you say ... open in tabs ...nuskoolkiddie wrote:is it possible to use the middle mouse button as middle mouse button (for opening and closing tabs in a browser for example)
adidasprince
UPDATES:
* Fix: vertical scrolling does not work as expected sometimes.
http://wencheng.fang.sh.cn/2010/03/thin ... opard.html
@Silencer
Thank you so much for the packaging and the x64 fix!! I merged it to my source.
@Sebinouse
I'm sorry that i don't have a x60t (tablets may differ from others) to test this kext.
@nuskoolkiddie
You may use SmartScroll as Sebinouse suggested. I'm sorry my kext is for those who wanted middle-button scrolling just like me and meself won't do anything about middle-button click.
@Silencer
@Sebinouse
@nuskoolkiddie
IBM ThinkPad T60p 2007-93J
adidasprince
My server is temporarily down until next wednesday ...
Hi!
Thanks a lot for your work!
Could you please post the source of your kext?
Just an example: I'd like to tune the speed between the Trackpoint and the Trackpad.
The mouse speed of the Trackpoint is just a bit too sentitive comparing to the Trackpad (i switch often between them). It would be great to change this.
max
max
Check out the link in the first post. The source code is available there.max22 wrote:Hi!
whops! sorry, must have been very tired
Hey, adidasprince, I hope you still check this thread. There's a discussion going on in the thread regarding ThinkPad fan speed control under OSX, and I was hoping you might have a look there, since you're apparently the most experienced with low level programming amongst the crowd here. If you have some time, please check this link.
und3rf0rce
Guys, please share latest version of ThinkUltraNavi, 'cause http://wencheng.fang.sh.cn/ is down now. Thx!
Apple MacBook Pro 13" (MC990LL/A)
and
IBM ThinkPad X61s (7668-CTO)
Intel Core 2 Duo L7500 @ 1.6 GHz, 2 GB DDR2, 320 GB @ 7200 Seagate, Atheros (as AirPort Extreme)
MacOS 10.6.7 w/ Sebinouse's fixes & Anastasius DSDT + modded AppleHDA.kext
and
Any chance of getting the drag issue fixed? It drives me nuts b/c the left click of my touchpad is broken.adidasprince wrote: knowing issue: no h-scroll, no drag by trackpad's move with trackpoint's button and vice versa.
adidasprince
Is it possible to increase Trackpoint sensitivity (speed)? If I drag the speed slider in the Trackpad prefpane all the way up, it is fast but really choppy. I tried lowering the divisor value in the kext's plist file but it only affected the touchpad.
32bit OS, and directx. Based on premise of old gaming.
by thinkpadcollection » Wed May 10, 2017 6:21 pm » in Off-Topic Stuff - 3 Replies
- 219 Views
Last post by theterminator93
Thu May 11, 2017 6:39 am
x41 Pen driver for winxp
by D L Davis » Sun Jan 08, 2017 2:00 am » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 1 Replies
- 370 Views
Last post by rkawakami
Sun Jan 08, 2017 3:26 am
- 2 Replies
- 489 Views
Last post by Sudevan
Sat Jan 28, 2017 8:21 pm
Audio driver driving me nuts!
by sktn77a » Tue Jan 31, 2017 11:11 am » in ThinkPad T430/T530 and later Series - 4 Replies
- 518 Views
Sun May 14, 2017 9:17 pm
