Glossy Thinkpads. black and Ferrari Red!
lfeagan
#31 Post by lfeagan » Tue Mar 01, 2005 6:30 pm
Yes, I imagine you could get an auto shop to do it for the $50 range. I suspect it might be a bit more though, depending on the exact paint you chose. The paint that I used was a little over $200/gallon, luckily I didn't need anywhere near a gallon. But, just thought I would point out that if you buy some extremely fancy paint, it is not cheap. Paints can easily run in excess of $1000/gallon and there are a couple of notable ones that run almost $2000/gallon.
T61p (6459CTO)|T9500|15.4" WUXGA-4GB|200GB FDE|256MB nVidia FX570M|Atheros|Cingular WWAN|openSuSE 11.0
T42p (2373GVU)|PentiumM 1.8GHz|2GB|100GB|ATI FireGL T2|Atheros|openSuSE 10.3
WaterField Designs Cargo + Sleeve
