10.6.X on X60/T60/X61 (CoreDuo, Core2Duo / GMA950, GMA3100)
Successful Installation Reports (with this Guide):
X60t
16
23%
X60s
16
23%
T60
25
35%
Other ...
14
20%
Total votes: 71
Anastasius
Re: 10.6.X on X60/T60/X61 (CoreDuo, Core2Duo / GMA950, GMA3100)
#211 Post by Anastasius » Wed Nov 24, 2010 9:47 pm
Thanks! I'll try it!
Do you know, if sleep/wake is available when loading Mac OS from external drive? I have actually installed it on external USB and my X61 first switches off the USB hard drive and then tries to go to sleep.
Great Gatsby
#212 Post by Great Gatsby » Thu Nov 25, 2010 5:21 pm
Something unrelated to the recent support issues here, but perhaps nonetheless interesting for the future: When I looked into the different options for getting Wi-Fi to run on our X60 Tablets despite their unsupported Intel 3945s, I noticed that there's not only the IBM 11a/b/g Wireless LAN Mini PCI Adapter II using the Atheros AR5004X chipset supported by OS X. According to ThinkWiki, Lenovo also has used the so-called ThinkPad 11a/b/g/n Wireless LAN Mini Express Adapter which - and this is my point - already supports the 802.11 n standard! It is also a Mini-PCI Express card and costs about 35 Euro on eBay.
So my idea is: If we already need to exchange our ThinkPad's Mini-PCI Express cards to get Wi-Fi under Snow Leopard working, wouldn't it be nice if we could upgrade our ThinkPads to have 802.11n, also under Snow Leopard? The support under Snow Leopard is somewhat unclear, some posts seem to indicate it actually is supported, others suggest it is not. On the hardware side, there are reports that people successfully use these cards in X60s. How many WLAN antenna cables are build into a X60 Tablet? You normally would need three to connect an 802.11n card adequately, wouldn't you?
Sebinouse
#213 Post by Sebinouse » Thu Nov 25, 2010 5:25 pm
Great Gatsby wrote:How many WLAN antenna cables are build into a X60 Tablet? You normally would need three to connect an 802.11n card adequately, wouldn't you?
As far as I remember there are 2 antenna cables in our X60t ... you can check the Maintenance Manual if you want : http://download.lenovo.com/ibmdl/pub/pc ... 551_02.pdf
Lenovo X60t (6363-AQ8)
  • Intel CoreDuo 1,67 GHz (L2400)
  • 3 Go / 320 Go / GMA950 / FW 400 / SD Card
  • Bluetooth / Wifi AR5BXB6 / Tablet
WinXP / MacOSX 10.6.8 (DSDT patch and vanilla SLE)
Great Gatsby
#214 Post by Great Gatsby » Thu Nov 25, 2010 8:11 pm
Sebinouse wrote:As far as I remember there are 2 antenna cables in our X60t ... you can check the Maintenance Manual if you want : http://download.lenovo.com/ibmdl/pub/pc ... 551_02.pdf
Thanks a lot! - It's still a bit unclear to me though if this is the case for really all X60t's. The Maintenance Manual mentions machines with a third, white WLAN cable that might reside in a cable box, presumably below (?) the card (chapter 1120).
I also found two threads on a German ThinkPad forum which support this assumption: According to them, a X60 Tablet 6363-HAU obviously comes with three WLAN and two WWAN antennas. Furthermore, the starter of this thread writes his X60 Tablet 6363-CTO has the usual Intel 3945 and comes with three WLAN cables as well, one of them being stored unused in the already mentioned cable box (see above - it is not clear though from the post if that third WLAN cable is attached to a third antenna or if it's just a spare cable). Another post suggests using only two antennas with an 802.11 n card, which is said to only reduce the card's range, but not its power. Finally, there's another thread suggesting to simply use the ThinkPad's WWAN antenna cable as the third WLAN cable.
So, after all, there still seems hope and room for further research, I think ... :-)
Anastasius
#215 Post by Anastasius » Fri Nov 26, 2010 11:18 pm
I have installed 10.6.5 update.
Now I'm receiving TSC Unsynchronized errors and some programs seem to work slower (is it connected?)
I tried VoodooTSCSyn.kext - but computer hangs with it on boot. :(
Sebinouse
#216 Post by Sebinouse » Sat Nov 27, 2010 6:58 am
Anastasius wrote:I have installed 10.6.5 update.
I've these errors since 10.6.2, I also tried VoodooTSCSyn.kext, but it doesn't seem to work on CoreDuo ... even with this kext loaded (/E/E) ... I still have these error in my log ...
nestawasright
#217 Post by nestawasright » Sat Nov 27, 2010 12:12 pm
I have an updated Vanilla install SL on an R60. I've used the directions here for sleep but it does not wake from sleep. I get a blinking half moon and desktop that's grey, I can see desktop but I can't interact with it as it has what looks like a grey screen on it---much like when you're using an app that has frozen.
There are very few people here with this machine and any help would be greatly appreciated.
Thanks a lot
IBM R60 9456-68U Core Solo
Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
Great Gatsby
#218 Post by Great Gatsby » Sat Nov 27, 2010 12:35 pm
nestawasright wrote:I have an updated Vanilla install SL on an R60. I've used the directions here for sleep but it does not wake from sleep. I get a blinking half moon and desktop that's grey, I can see desktop but I can't interact with it as it has what looks like a grey screen on it---much like when you're using an app that has frozen.
Thanks a lot
One possible reason could be: AppleACPIPS2Nub.kext isn't properly unloaded during the attempt to sleep and/or doesn't properly get reloaded on wakeup (there are numerous other reasons for your problem, of course, but that's the first one that comes to my mind). To investigate that further, could you provide us with a few things?
- Which ThindPad model do you have (e.g. 6363-2AG) and how much RAM does your R60 have?
- Your R60 comes with a Core 2 Duo processor, right? Did you choose Sebinouse's Core2Duo-package accordingly?
- To which hibernationmode did you set your ThinkPad?
- Could you post the part of your System log (from the OS X Console application) that is created during the time of your attempt to send your ThinkPad to sleep? See here for an example.
nestawasright
#219 Post by nestawasright » Sat Nov 27, 2010 1:20 pm
That's superb help. Let me get to your questions right now.
My model is this: R60 9456-68U
Mine is Core Solo
I did not set the "hibernatemode". Assistance on this will be great.
Sorry, I can't seem to know how to get the part of the system log before sleep. But below the lspci is the dmesg out put.
I've included below here the lspci output:
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA AHCI Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
02:00.0 Ethernet controller: Broadcom Corporation NetXtreme BCM5751M Gigabit Ethernet PCI Express (rev 21)
03:00.0 Ethernet controller: Atheros Communications Inc. AR5212 802.11abg NIC (rev 01)
15:00.0 CardBus bridge: Texas Instruments PCI1510 PC card Cardbus Controller
dmesg:
npvhash=4095
PAE enabled
Darwin Kernel Version 10.5.0: Fri Nov 5 23:20:39 PDT 2010; root:xnu-1504.9.17~1/RELEASE_I386
vm_page_bootstrap: 376707 free pages and 16509 wired pages
standard timeslicing quantum is 10000 us
mig_table_max_displ = 73
NullCPUPowerManagement::init: properties=0x4750e00
NullCPUPowerManagement::start
AppleACPICPU: ProcessorId=0 LocalApicId=0 Enabled
AppleACPICPU: ProcessorId=1 LocalApicId=1 Disabled
calling mpo_policy_init for Quarantine
Security policy loaded: Quarantine policy (Quarantine)
calling mpo_policy_init for Sandbox
Security policy loaded: Seatbelt sandbox policy (Sandbox)
calling mpo_policy_init for TMSafetyNet
Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Copyright (c) 1982, 1986, 1989, 1991, 1993
The Regents of the University of California. All rights reserved.
MAC Framework successfully initialized
using 7864 buffer headers and 4096 cluster IO buffer headers
Trying to change a collection in the registry
Backtrace 0x502e54 0x534aab 0x533dd0 0x25fc9ce2 0x25fc9fef 0x53ca9e 0x53acd3
Kernel Extensions in backtrace (with dependencies):
org.voodoo.driver.PS2Controller(1.1.0)@0x25fc6000->0x25fcbfff
IOAPIC: Version 0x20 Vectors 64:87
PS2Controller: Created dev /ps2controller
Using new IRQ layout 0,1
ACPI: System State [S0 S3 S4 S5] (S3)
RTC: Only single RAM bank (128 bytes)
mbinit: done (64 MB memory set for mbuf pool)
From path: "uuid",
Waiting for boot volume with UUID B5889320-248D-3D66-A0AA-8E4182CD19A2
Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
com.apple.AppleFSCompressionTypeZlib kmod start
com.apple.AppleFSCompressionTypeZlib load succeeded
netkas presents fakesmc, a kext which emulates smc device
Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/FUJITSU MHW2120BH Media/IOFDiskPartitionScheme/Untitled 1@1
BSD root: disk0s1, major 14, minor 1
Waiting for DSMOS...
BCM5751Enet: Ethernet address 00:00:00:00:00:00
systemShutdown false
Previous Shutdown Cause: 0
Atheros: mac 10.3 phy 6.1 radio 10.2
Unable to obtain BE Output Queue
start [/SourceCache/AirPortDriverAtheros5424/AirPortDriverAtheros5424-411.19.4/src/common/lmac/ath_dev/darwin/AtherosController.cpp:1149] load failed
VoodooPS2SynapticsTouchPad loaded
VoodooPS2Trackpad: Synaptics TouchPad v6.2
DSMOS has arrived
VoodooBattery 1.3 (C) 2009 Superhai, All Rights Reserved. Jan 7 2010 23:18:58 32 bit
FakeSMC: key info not found MSDS, length - 6
ACPI_SMC_PlatformPlugin::start - waitForService(resourceMatching(AppleIntelCPUPowerManagement) timed out
FakeSMC: key not found BEMB, length - 1
display: Not usable
AppleBCM5751Ethernet: a 0 interruptOccurred - Not my interrupt
AppleBCM5751Ethernet - en1 link active, 100-Mbit, full duplex, symmetric flow control enabled
AppleBCM5751Ethernet: 0 4 setupCopperPhy - link is down
I will say that the machine when it goes to sleep and I try to wake it by hitting the power button, it seems to restart, then I get the bootloader screen and then a greyscreen with my desktop seen through it. And then the this reloops and on and on. But when I take the HD out the system, run pfix on it, it boots back right up, no problem.
Also looking for the proper VooddooHDA for this machine that has micin working, if anyone has that.
Thanks a lot to all those helping me out here.
Please let me know what you think I should do with the kexts you mentioned earlier.
v3960
#220 Post by v3960 » Sat Nov 27, 2010 4:31 pm
Hello, dear All !
Thanks ti All for your work and info!
My laptop:
Lenovo X61t (7762- B6U)
Intel Core2Duo 1,60 GHz (L7500)
1.5 GB / 120 GB / FW 400 / SD Card
Bluetooth / Wifi AR5BXB72 / Tablet (non multitouch)
X3100 / 12.1" (1024x768) ...
I've replaced wi-fi card from intel 4965AG (no 'N' here) to APPLE AR5BXB72 AR5008 802.11N
http://cgi.ebay.com/APPLE-AR5BXB72-AR50 ... 4cf2c625b5
It's actually Atheros chipset card AR5008 + AR5416 802.11a/b/g/n
It can work in 5GHz or in 2.4 GHz mode, but a bit later about that...
Of course thinkpad burned with a modified BIOS
As fo the SL installation:
I followed Sebinouse's guide from first post. There was 10.6.3 retail disk, and on step 2) there was screen divided by half and 1/4 and so on, with blue , white and other colors
so I decided to boot in 64 mode - and screen was perfect but no mouse no keyboard, even no USB mouse ...
so than I changed DSDT.aml with the one provided by Anastasius
and so I finished Guide at step 3)
No Updates, Sleep/Wake fixes yet
What I have now
1) wi-fi is working
in System Profiler in Hardware/Ethernet section it shows as 'Atheros AR5212 802.11abg NIC'
and in Net/AirPort all is correct - AR5416 802.11a/b/g/n and so on
tests shows me :
802.11n 2.4GHz Download ~70 Mbps , Upload ~50 Mbps
802.11n 5GHz Download ~80 Mbps , Upload ~ from few Kbps to few Mbps (Upload is very bad)
As for the X61T at all
1) brightness changing works with ScrLk and Pause, but how! fading goes from left down corner to right top, it's terrible looking ;(
on linux or windows all is OK
2) trackpoint, kb, GMA X3100 (QE, OpenGL 2.1) work
3) USB, Sound, Digitizer, - NO
4) BatteryMeter, WiFi, BT, CPU Termal monitoring - OK
5) according to Guide p-states, c-states work
x61t_l7500:~ pavel$ ioreg -lw0 | grep PerformanceStateArray
    | |   |     "PerformanceStateArray" = (<41060000b88800000a0000000a0000002009000020090000>,<40060000b88800000a0000000a0000001608000016080000>,<b0040000803e00000a0000000a0000001506000015060000>,<20030000b03600000a0000000a0000000b8800000b880000>)
x61t_l7500:~ pavel$ ioreg -lw0 | grep CSTInfo
    | |   |     "CSTInfo" = 19136773
x61t_l7500:~ pavel$
All other things not checked yet
Sebinouse
#221 Post by Sebinouse » Sat Nov 27, 2010 7:38 pm
nestawasright wrote:Backtrace 0x502e54 0x534aab 0x533dd0 0x25fc9ce2 0x25fc9fef 0x53ca9e 0x53acd3
I used to have issue with Sleep and VoodooPS2 ... (now I am using ApplePS2Controller)
you can try to add VooDooPS2Controller.kext in rc.wakeup / rc.sleep to load / unload this kext on sleep ...
BTW: You can try the UltraNavi driver made by AdidasPrince on this forum ... (if there is a trackpad on you T60 ...)
nestawasright
#222 Post by nestawasright » Sun Nov 28, 2010 12:16 am
So do you not have sleep issues anymore because you're using ApplePS2controller?
I've just tried ApplePS2Controller from the first post on this thread and it does not work. Using trackpad to move mouse does not work. Going back to voodooPS2.
Does ApplePS2controller need UltraNavi to work?
I do have a trackpad, but I'm not sure if it's related to the sleep issue...would like your thoughts on this.
Do you have a working VoodooHDA that has sound input? Or, know where I can find one?
nestawasright
#223 Post by nestawasright » Sun Nov 28, 2010 1:00 am
Just an update to say that I've tried this package http://forum.thinkpads.com/viewtopic.php?f=32&t=86059 It's the third post by Silencer. I'm using both kexts from there and everything seems to be working.
I used to be able to single-click a folder to open it, but that's gone now. Maybe someone has suggestion.
I'm also using the VoododHDA from the first post here. I don't have internal mic input. Any help folks, please.
Report on sleep:
If the screen goes black to sleep and I touch the trackpad, it comes back from sleep without an issue. So the problem seems to be when it goes to sleep for a long time. The hibenation mode is now set to 1.
Thanks, if you're reading, and have ideas, please help. Just two crucial things left to go: sleep and internal mic input.
Thanks in advance.
Sebinouse
#224 Post by Sebinouse » Sun Nov 28, 2010 4:53 am
Sebinouse wrote:you can try to add VooDooPS2Controller.kext in rc.wakeup / rc.sleep to load / unload this kext on sleep ....)
Did you tried this to fix sleep ?
Does sleep work with ApplePS2Controller ? Your trackpad won't work with the kexts from the MacPNT parckage as there is no trackpad on X60t and I had to delete one plugin to make the trackpoint and the keyboard work ...
Utranavi is a plugin made by AdidasPrince, to make middle button and scrolling with trackpoint work ... Only available with VoodooPS2Controller ... HERE
VoodooHDA from the macPNT package has internal mic support (custom info.plist) ... I followed Silencer's instruction for his T60p ...
nestawasright
#225 Post by nestawasright » Sun Nov 28, 2010 10:37 am
Great Gatsby wrote: - Could you post the part of your System log (from the OS X Console application) that is created during the time of your attempt to send your ThinkPad to sleep? See here for an example.
Gatsby, the great, please forgive me for saying I don't know how to do this earlier. I had no idea what I was thinking about, but here's my console message, complete. I cleaned it up, left the machine on and allowed it to go to sleep, took the HD out, ran pfix on it, restart and go to console. Here's the message. Here's the complete file http://www.mediafire.com/?x7i6fstidkx5z37
And here a complete information of my hardware: http://www.mediafire.com/file/fdyiqb58f ... eport.html
This console message from below is the reduced version. I cut much of the top of it, leaving the end:
10-11-25 9:15:39 PM com.apple.ReportCrash.Root[174] 2010-11-25 23:15:39.866 ReportCrash[174:1207] Saved crash report for installd[168] version ??? (???) to /Library/Logs/DiagnosticReports/installd_2010-11-25-231539_localhost.crash
10-11-25 9:15:40 PM Installer[125] The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
10-11-25 9:17:25 PM Installer[194] <ZeroSliderSplitView: 0x1d6250>: the delegate <TargetSelectPage: 0x1de660> was sent -splitView:resizeSubviewsWithOldSize: and left the subview frames in an inconsistent state:
10-11-25 9:17:25 PM Installer[194] Split view bounds: {{0, 0}, {402, 104}}
10-11-25 9:17:25 PM Installer[194] Subview frame: {{0, 0}, {0, 32}}
10-11-25 9:17:25 PM Installer[194] Subview frame: {{0, 0}, {402, 104}}
10-11-25 9:17:25 PM Installer[194] The outer edges of the subview frames are supposed to line up with the split view's bounds' edges. NSSplitView is working around the problem, perhaps at the cost of more redrawing. (This message is only logged once per NSSplitView.)
10-11-25 9:23:04 PM com.apple.WindowServer[65] Thu Nov 25 23:23:04 well-wells-MacBook.local WindowServer[65] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 34
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 30
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 29
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 28
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 26
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 33
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 27
10-11-25 9:23:07 PM com.apple.notifyd[11] EV_DELETE failed for file watcher 32
10-11-25 9:24:37 PM System Preferences[365] error getting audio property: 560947818
10-11-25 9:24:49 PM com.apple.DirectoryServices[33] change_password: Principal does not exist while changing password for "wellwell@LKDC:SHA1.68882DB98E3B3F388AAC221969C06CD287CDFD4C".
10-11-25 9:25:15 PM com.apple.launchd.peruser.501[81] ([0x0-0x15015].com.apple.Terminal[351]) Exited: Killed
10-11-25 9:25:52 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-25 9:25:52 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-25 9:26:04 PM com.apple.DumpPanic[32] 2010-11-25 23:26:04.668 DumpPanic[32:107] Error getting a reference to IODeviceTree:/options
10-11-25 9:26:04 PM com.apple.launchd[1] (com.apple.DumpPanic[32]) Exited with exit code: 1
10-11-25 9:26:21 PM com.apple.launchd.peruser.501[76] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-25 9:26:26 PM com.apple.launchd.peruser.501[76] (com.apple.Kerberos.renew.plist[96]) Exited with exit code: 1
10-11-25 9:27:40 PM com.apple.WindowServer[62] Thu Nov 25 23:27:40 well-wells-MacBook.local WindowServer[62] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-25 9:34:21 PM SystemUIServer[81] It does not make sense to draw an image when [NSGraphicsContext currentContext] is nil. This is a programming error. Break on _NSWarnForDrawingImageWithNoCurrentContext to debug. This will be logged only once. This may break in the future.
10-11-25 9:36:38 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-25 9:36:50 PM com.apple.DumpPanic[30] 2010-11-25 23:36:50.904 DumpPanic[30:107] Error getting a reference to IODeviceTree:/options
10-11-25 9:36:50 PM com.apple.launchd[1] (com.apple.DumpPanic[30]) Exited with exit code: 1
10-11-25 9:37:18 PM com.apple.launchd.peruser.501[75] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-25 9:37:21 PM com.apple.launchd.peruser.501[75] (com.apple.Kerberos.renew.plist[95]) Exited with exit code: 1
10-11-25 10:00:01 PM com.apple.WindowServer[60] Fri Nov 26 00:00:01 well-wells-MacBook.local WindowServer[60] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-25 10:06:47 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-25 10:06:47 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-25 10:06:55 PM com.apple.DumpPanic[34] 2010-11-26 00:06:55.953 DumpPanic[34:107] Error getting a reference to IODeviceTree:/options
10-11-25 10:06:55 PM com.apple.launchd[1] (com.apple.DumpPanic[34]) Exited with exit code: 1
10-11-25 10:06:56 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-25 10:07:03 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 3 seconds
10-11-25 10:07:03 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 2 seconds
10-11-26 7:20:42 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-26 7:20:42 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-26 7:20:54 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:20:55 PM com.apple.DumpPanic[30] 2010-11-26 21:20:55.466 DumpPanic[30:107] Error getting a reference to IODeviceTree:/options
10-11-26 7:20:55 PM com.apple.launchd[1] (com.apple.DumpPanic[30]) Exited with exit code: 1
10-11-26 7:21:04 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:21:07 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 7 seconds
10-11-26 7:22:37 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:22:56 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 2 seconds
10-11-26 7:22:58 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:23:00 PM com.apple.launchd.peruser.501[82] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-26 7:23:07 PM com.apple.launchd.peruser.501[82] (com.apple.Kerberos.renew.plist[114]) Exited with exit code: 1
10-11-26 7:31:08 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 9 seconds
10-11-26 7:33:22 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.NetworkUtility"></bundle>
10-11-26 7:33:22 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.RAIDUtility"></bundle>
10-11-26 7:33:23 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.Terminal"></bundle>
10-11-26 7:33:23 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.SystemProfiler"></bundle>
10-11-26 7:33:23 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.DiskUtility"></bundle>
10-11-26 7:33:23 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:49:18 PM com.apple.fontd[220] FODBCheck: foRec->annexNumber != kInvalidAnnexNumber (0)
10-11-26 7:51:22 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:55:03 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.RAIDUtility"></bundle>
10-11-26 7:55:03 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.Terminal"></bundle>
10-11-26 7:55:03 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.SystemProfiler"></bundle>
10-11-26 7:55:03 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.DiskUtility"></bundle>
10-11-26 7:55:04 PM Installer[168] PackageKit: Missing bundle path, skipping: <bundle id="com.apple.NetworkUtility"></bundle>
10-11-26 7:55:48 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:55:59 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 9 seconds
10-11-26 7:56:42 PM com.apple.loginwindow[23] shutdown: / is busy updating; waiting for lock
10-11-26 7:56:43 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:57:52 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-26 7:58:02 PM com.apple.DumpPanic[46] 2010-11-26 21:58:02.043 DumpPanic[46:107] Error getting a reference to IODeviceTree:/options
10-11-26 7:58:02 PM com.apple.launchd[1] (com.apple.DumpPanic[46]) Exited with exit code: 1
10-11-26 7:58:05 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 6 seconds
10-11-26 7:58:12 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:58:18 PM com.apple.coreservicesd[61] 2010-11-26 21:58:18.926 lsregister[79:903] _CFGetHostUUIDString: unable to determine UUID for host. Error: 35
10-11-26 7:58:22 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:58:33 PM com.apple.launchd[1] (com.apple.aslmanager) Throttling respawn: Will start in 10 seconds
10-11-26 7:58:33 PM com.apple.coreservicesd[61] ThrottleProcessIO: throttling disk i/o
10-11-26 7:58:38 PM com.apple.launchd.peruser.501[103] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-26 7:58:40 PM com.apple.coreservicesd[61] ThrottleProcessIO: throttling disk i/o
10-11-26 7:58:42 PM fontd[116] Database content version mismatch (stored(10) != expected(14))
10-11-26 7:58:42 PM fontd[116] Database content version mismatch (stored(15) != expected(14))
10-11-26 7:58:42 PM fontd[116] Failed to open read-only database, regenerating DB
10-11-26 7:58:45 PM com.apple.launchd.peruser.501[103] (com.apple.Kerberos.renew.plist[125]) Exited with exit code: 1
10-11-26 7:58:48 PM com.apple.fontd[116] FODBCheck: foRec->annexNumber != kInvalidAnnexNumber (0)
10-11-26 7:58:56 PM iCal Helper[135] In-place migration failed. Trying to restore from the truth files...
10-11-27 6:19:20 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 6:19:20 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 6:19:32 AM com.apple.DumpPanic[35] 2010-11-27 08:19:32.314 DumpPanic[35:107] Error getting a reference to IODeviceTree:/options
10-11-27 6:19:32 AM com.apple.launchd[1] (com.apple.DumpPanic[35]) Exited with exit code: 1
10-11-27 6:20:01 AM com.apple.launchd.peruser.501[88] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 6:20:05 AM com.apple.launchd.peruser.501[88] (com.apple.Kerberos.renew.plist[109]) Exited with exit code: 1
10-11-27 6:20:29 AM com.apple.WindowServer[70] Sat Nov 27 08:20:29 well-wells-MacBook.local WindowServer[70] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 6:24:39 AM System Preferences[139] Could not connect the action resetLocationWarningsSheetOk: to target of class AppleSecurity_Pref
10-11-27 6:24:39 AM System Preferences[139] Could not connect the action resetLocationWarningsSheetCancel: to target of class AppleSecurity_Pref
10-11-27 6:24:56 AM System Preferences[139] error getting audio property: 560947818
10-11-27 6:25:48 AM [0x0-0xe00e].com.apple.systempreferences[139] Couldn't find any matches.
10-11-27 6:25:48 AM [0x0-0xe00e].com.apple.systempreferences 2010-11-27 08:25:48.548 writeconfig[146:903] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection or ports are invalid
10-11-27 6:28:37 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 6:28:48 AM com.apple.DumpPanic[36] 2010-11-27 08:28:48.759 DumpPanic[36:107] Error getting a reference to IODeviceTree:/options
10-11-27 6:28:48 AM com.apple.launchd[1] (com.apple.DumpPanic[36]) Exited with exit code: 1
10-11-27 6:29:15 AM com.apple.launchd.peruser.501[88] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 6:29:18 AM com.apple.launchd.peruser.501[88] (com.apple.Kerberos.renew.plist[109]) Exited with exit code: 1
10-11-27 6:39:30 AM com.apple.WindowServer[71] Sat Nov 27 08:39:30 well-wells-MacBook.local WindowServer[71] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 6:46:20 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 6:46:30 AM com.apple.DumpPanic[37] 2010-11-27 08:46:30.931 DumpPanic[37:107] Error getting a reference to IODeviceTree:/options
10-11-27 6:46:30 AM com.apple.launchd[1] (com.apple.DumpPanic[37]) Exited with exit code: 1
10-11-27 6:46:54 AM com.apple.SystemStarter[22] Starting Sleep Watcher
10-11-27 6:46:55 AM com.apple.SystemStarter[22] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 6:46:57 AM com.apple.launchd.peruser.501[101] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 6:46:59 AM com.apple.launchd.peruser.501[101] (com.apple.Kerberos.renew.plist[122]) Exited with exit code: 1
10-11-27 7:35:19 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 7:35:19 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 7:35:31 AM com.apple.DumpPanic[32] 2010-11-27 09:35:31.070 DumpPanic[32:107] Error getting a reference to IODeviceTree:/options
10-11-27 7:35:31 AM com.apple.launchd[1] (com.apple.DumpPanic[32]) Exited with exit code: 1
10-11-27 7:38:23 AM com.apple.SystemStarter[16] Starting Sleep Watcher
10-11-27 7:38:23 AM com.apple.SystemStarter[16] Notice: -print-diagnostics (-t) ignored; use kextutil(8) to test kexts.
10-11-27 7:38:23 AM com.apple.SystemStarter[16] /Extra/Extensions/AppleACPIPS2Nub.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 7:38:23 AM com.apple.SystemStarter[16] /Extra/Extensions/VoodooHDA.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 7:38:24 AM com.apple.SystemStarter[16] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 7:38:29 AM com.apple.launchd.peruser.501[116] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 7:38:32 AM SoftwareUpdateCheck[126] Checking for updates
10-11-27 7:38:33 AM SoftwareUpdateCheck[126] This computer’s Internet connection appears to be offline.
10-11-27 7:38:33 AM com.apple.launchd.peruser.501[116] ([0x0-0x8008].SoftwareUpdateCheck[126]) Exited with exit code: 102
10-11-27 7:38:33 AM com.apple.launchd[1] (com.apple.suhelperd[128]) Exited with exit code: 2
10-11-27 7:38:37 AM com.apple.WindowServer[82] Sat Nov 27 09:38:37 well-wells-MacBook.local WindowServer[82] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 7:38:37 AM com.apple.launchd.peruser.501[116] (com.apple.Kerberos.renew.plist[137]) Exited with exit code: 1
10-11-27 8:21:28 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 8:21:28 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 8:21:42 AM com.apple.DumpPanic[32] 2010-11-27 10:21:42.114 DumpPanic[32:107] Error getting a reference to IODeviceTree:/options
10-11-27 8:21:42 AM com.apple.launchd[1] (com.apple.DumpPanic[32]) Exited with exit code: 1
10-11-27 8:24:24 AM com.apple.SystemStarter[16] Starting Sleep Watcher
10-11-27 8:24:25 AM com.apple.SystemStarter[16] Notice: -print-diagnostics (-t) ignored; use kextutil(8) to test kexts.
10-11-27 8:24:25 AM com.apple.SystemStarter[16] /Extra/Extensions/AppleACPIPS2Nub.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 8:24:25 AM com.apple.SystemStarter[16] /Extra/Extensions/VoodooHDA.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 8:24:26 AM com.apple.SystemStarter[16] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 8:24:31 AM com.apple.launchd.peruser.501[89] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 8:24:38 AM com.apple.launchd.peruser.501[89] (com.apple.Kerberos.renew.plist[136]) Exited with exit code: 1
10-11-27 8:24:55 AM com.apple.WindowServer[82] Sat Nov 27 10:24:55 well-wells-MacBook.local WindowServer[82] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 8:25:39 AM System Preferences[153] Could not connect the action resetLocationWarningsSheetOk: to target of class AppleSecurity_Pref
10-11-27 8:25:39 AM System Preferences[153] Could not connect the action resetLocationWarningsSheetCancel: to target of class AppleSecurity_Pref
10-11-27 8:25:45 AM [0x0-0xe00e].com.apple.systempreferences[153] Couldn't find any matches.
10-11-27 8:25:45 AM [0x0-0xe00e].com.apple.systempreferences 2010-11-27 10:25:45.422 writeconfig[157:903] *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection or ports are invalid
10-11-27 10:43:10 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 10:43:23 AM com.apple.DumpPanic[32] 2010-11-27 12:43:23.876 DumpPanic[32:107] Error getting a reference to IODeviceTree:/options
10-11-27 10:43:23 AM com.apple.launchd[1] (com.apple.DumpPanic[32]) Exited with exit code: 1
10-11-27 10:46:08 AM com.apple.SystemStarter[16] Starting Sleep Watcher
10-11-27 10:46:08 AM com.apple.SystemStarter[16] Notice: -print-diagnostics (-t) ignored; use kextutil(8) to test kexts.
10-11-27 10:46:08 AM com.apple.SystemStarter[16] /Extra/Extensions/AppleACPIPS2Nub.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 10:46:08 AM com.apple.SystemStarter[16] /Extra/Extensions/VoodooHDA.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 10:46:09 AM com.apple.SystemStarter[16] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 10:46:14 AM com.apple.launchd.peruser.501[117] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 10:46:21 AM com.apple.WindowServer[82] Sat Nov 27 12:46:21 well-wells-MacBook.local WindowServer[82] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 10:46:21 AM com.apple.launchd.peruser.501[117] (com.apple.Kerberos.renew.plist[135]) Exited with exit code: 1
10-11-27 10:59:33 AM com.apple.launchd.peruser.501[117] ([0x0-0xd00d].com.apple.Terminal[148]) Exited: Killed
10-11-27 10:59:33 AM com.apple.launchd.peruser.501[117] ([0x0-0xf00f].com.apple.TextEdit[183]) Exited: Killed
10-11-27 11:01:42 AM com.apple.loginwindow[25] shutdown: / is busy updating; waiting for lock
10-11-27 11:04:36 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 11:04:36 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 11:04:49 AM com.apple.DumpPanic[35] 2010-11-27 13:04:49.127 DumpPanic[35:107] Error getting a reference to IODeviceTree:/options
10-11-27 11:04:49 AM com.apple.launchd[1] (com.apple.DumpPanic[35]) Exited with exit code: 1
10-11-27 11:05:13 AM com.apple.SystemStarter[20] Starting Sleep Watcher
10-11-27 11:05:13 AM com.apple.SystemStarter[20] Notice: -print-diagnostics (-t) ignored; use kextutil(8) to test kexts.
10-11-27 11:05:13 AM com.apple.SystemStarter[20] /Extra/Extensions/AppleACPIPS2Nub.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 11:05:13 AM com.apple.SystemStarter[20] /Extra/Extensions/VoodooHDA.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 11:05:14 AM com.apple.SystemStarter[20] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 11:05:18 AM com.apple.launchd.peruser.501[106] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 11:05:26 AM com.apple.launchd.peruser.501[106] (com.apple.Kerberos.renew.plist[130]) Exited with exit code: 1
10-11-27 11:05:26 AM com.apple.WindowServer[73] Sat Nov 27 13:05:26 well-wells-MacBook.local WindowServer[73] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 4:51:06 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 4:51:21 PM com.apple.DumpPanic[35] 2010-11-27 18:51:21.369 DumpPanic[35:107] Error getting a reference to IODeviceTree:/options
10-11-27 4:51:21 PM com.apple.launchd[1] (com.apple.DumpPanic[35]) Exited with exit code: 1
10-11-27 4:51:46 PM com.apple.SystemStarter[20] Starting Sleep Watcher
10-11-27 4:51:46 PM com.apple.SystemStarter[20] Notice: -print-diagnostics (-t) ignored; use kextutil(8) to test kexts.
10-11-27 4:51:46 PM com.apple.SystemStarter[20] /Extra/Extensions/AppleACPIPS2Nub.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 4:51:46 PM com.apple.SystemStarter[20] /Extra/Extensions/VoodooHDA.kext failed to load - (libkern/kext) not found; check the system/kernel logs for errors or try kextutil(8).
10-11-27 4:51:47 PM com.apple.SystemStarter[20] /etc/rc.wakeup: line 64: /usr/local/bin/hid2hci: No such file or directory
10-11-27 4:51:50 PM com.apple.launchd.peruser.501[108] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 4:51:54 PM com.apple.launchd.peruser.501[108] (com.apple.Kerberos.renew.plist[129]) Exited with exit code: 1
10-11-27 4:53:20 PM com.apple.WindowServer[74] Sat Nov 27 18:53:20 new-host-2.home WindowServer[74] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 5:36:23 PM com.apple.Finder[114] Sat Nov 27 19:36:23 new-host-2.home Finder[114] <Error>: kCGErrorInvalidConnection: CGSGetSurfaceBounds: Invalid connection
10-11-27 5:36:23 PM com.apple.Finder[114] Sat Nov 27 19:36:23 new-host-2.home Finder[114] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 6:05:39 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:05:39 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:06:12 PM SystemUIServer[113] It does not make sense to draw an image when [NSGraphicsContext currentContext] is nil. This is a programming error. Break on _NSWarnForDrawingImageWithNoCurrentContext to debug. This will be logged only once. This may break in the future.
10-11-27 6:07:41 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:07:41 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:31:58 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:31:58 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:33:29 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:33:29 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:35:32 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:35:32 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:37:35 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:37:35 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:41:08 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:41:08 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: allow sleep
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: allow sleep
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[333] sh: /Users/wellwell/.sleep: No such file or directory
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[333] sleepwatcher: sleep: ~/.sleep: 32512
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[322] kextunload: unrecognized option `-t'
10-11-27 6:43:11 PM de.bernhard-baehr.sleepwatcher[322] sleepwatcher: sleep: /etc/rc.sleep: 0
10-11-27 7:09:26 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 7:09:26 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 7:09:45 PM com.apple.DumpPanic[31] 2010-11-27 21:09:45.552 DumpPanic[31:107] Error getting a reference to IODeviceTree:/options
10-11-27 7:09:45 PM com.apple.launchd[1] (com.apple.DumpPanic[31]) Exited with exit code: 1
10-11-27 7:09:51 PM de.bernhard-baehr.sleepwatcher[42] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:09:51 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[42]) Exited with exit code: 1
10-11-27 7:09:51 PM de.bernhard-baehr.sleepwatcher[52] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:09:51 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[52]) Exited with exit code: 1
10-11-27 7:09:51 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:09:52 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 9 seconds
10-11-27 7:10:01 PM de.bernhard-baehr.sleepwatcher[76] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:01 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[76]) Exited with exit code: 1
10-11-27 7:10:01 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:10:12 PM de.bernhard-baehr.sleepwatcher[77] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:12 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[77]) Exited with exit code: 1
10-11-27 7:10:12 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:10:22 PM de.bernhard-baehr.sleepwatcher[78] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:22 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[78]) Exited with exit code: 1
10-11-27 7:10:22 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:10:32 PM de.bernhard-baehr.sleepwatcher[86] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:32 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[86]) Exited with exit code: 1
10-11-27 7:10:32 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:10:42 PM de.bernhard-baehr.sleepwatcher[87] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:42 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[87]) Exited with exit code: 1
10-11-27 7:10:42 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:10:52 PM de.bernhard-baehr.sleepwatcher[88] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:10:52 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[88]) Exited with exit code: 1
10-11-27 7:10:52 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:11:02 PM de.bernhard-baehr.sleepwatcher[89] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:11:02 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[89]) Exited with exit code: 1
10-11-27 7:11:02 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:11:12 PM de.bernhard-baehr.sleepwatcher[90] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 7:11:12 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[90]) Exited with exit code: 1
10-11-27 7:11:12 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 7:11:18 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 5 seconds
10-11-27 7:11:42 PM com.apple.launchd.peruser.501[113] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 7:11:49 PM com.apple.launchd.peruser.501[113] (com.apple.Kerberos.renew.plist[132]) Exited with exit code: 1
10-11-27 7:23:04 PM de.bernhard-baehr.sleepwatcher[92] sleepwatcher: allow sleep
10-11-27 7:23:04 PM de.bernhard-baehr.sleepwatcher[135] sleepwatcher: allow sleep
10-11-27 7:23:04 PM de.bernhard-baehr.sleepwatcher[135] sh: /Users/wellwell/.sleep: No such file or directory
10-11-27 7:23:04 PM de.bernhard-baehr.sleepwatcher[135] sleepwatcher: sleep: ~/.sleep: 32512
10-11-27 7:23:05 PM de.bernhard-baehr.sleepwatcher[92] kextunload: unrecognized option `-t'
10-11-27 7:23:05 PM de.bernhard-baehr.sleepwatcher[92] sleepwatcher: sleep: /etc/rc.sleep: 0
10-11-27 10:06:23 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 10:06:37 PM com.apple.DumpPanic[31] 2010-11-28 00:06:37.166 DumpPanic[31:107] Error getting a reference to IODeviceTree:/options
10-11-27 10:06:37 PM com.apple.launchd[1] (com.apple.DumpPanic[31]) Exited with exit code: 1
10-11-27 10:06:44 PM de.bernhard-baehr.sleepwatcher[42] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:06:44 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[42]) Exited with exit code: 1
10-11-27 10:06:44 PM de.bernhard-baehr.sleepwatcher[52] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:06:44 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[52]) Exited with exit code: 1
10-11-27 10:06:44 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:06:45 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:06:55 PM de.bernhard-baehr.sleepwatcher[76] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:06:55 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[76]) Exited with exit code: 1
10-11-27 10:06:55 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:05 PM de.bernhard-baehr.sleepwatcher[77] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:05 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[77]) Exited with exit code: 1
10-11-27 10:07:05 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:15 PM de.bernhard-baehr.sleepwatcher[78] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:15 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[78]) Exited with exit code: 1
10-11-27 10:07:15 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:26 PM de.bernhard-baehr.sleepwatcher[85] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:26 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[85]) Exited with exit code: 1
10-11-27 10:07:26 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:36 PM de.bernhard-baehr.sleepwatcher[86] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:36 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[86]) Exited with exit code: 1
10-11-27 10:07:36 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:46 PM de.bernhard-baehr.sleepwatcher[87] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:46 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[87]) Exited with exit code: 1
10-11-27 10:07:46 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:07:56 PM de.bernhard-baehr.sleepwatcher[88] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:07:56 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[88]) Exited with exit code: 1
10-11-27 10:07:56 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:06 PM de.bernhard-baehr.sleepwatcher[89] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:06 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[89]) Exited with exit code: 1
10-11-27 10:08:06 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:16 PM de.bernhard-baehr.sleepwatcher[90] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:16 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[90]) Exited with exit code: 1
10-11-27 10:08:16 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:26 PM de.bernhard-baehr.sleepwatcher[91] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:26 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[91]) Exited with exit code: 1
10-11-27 10:08:26 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:36 PM de.bernhard-baehr.sleepwatcher[92] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:36 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[92]) Exited with exit code: 1
10-11-27 10:08:36 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:46 PM de.bernhard-baehr.sleepwatcher[93] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:46 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[93]) Exited with exit code: 1
10-11-27 10:08:46 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:08:56 PM de.bernhard-baehr.sleepwatcher[94] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:08:56 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[94]) Exited with exit code: 1
10-11-27 10:08:56 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:09:03 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 4 seconds
10-11-27 10:09:07 PM de.bernhard-baehr.sleepwatcher[95] sleepwatcher:
10-11-27 10:09:07 PM de.bernhard-baehr.sleepwatcher[95] IOServiceGetMatchingService failed
10-11-27 10:09:07 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[95]) Exited with exit code: 1
10-11-27 10:09:07 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:09:29 PM com.apple.launchd.peruser.501[118] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 10:09:37 PM com.apple.launchd.peruser.501[118] (com.apple.Kerberos.renew.plist[137]) Exited with exit code: 1
10-11-27 10:28:21 PM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-27 10:28:21 PM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-27 10:28:35 PM com.apple.DumpPanic[31] 2010-11-28 00:28:35.179 DumpPanic[31:107] Error getting a reference to IODeviceTree:/options
10-11-27 10:28:35 PM com.apple.launchd[1] (com.apple.DumpPanic[31]) Exited with exit code: 1
10-11-27 10:28:42 PM de.bernhard-baehr.sleepwatcher[42] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:28:42 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[42]) Exited with exit code: 1
10-11-27 10:28:42 PM de.bernhard-baehr.sleepwatcher[51] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:28:42 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[51]) Exited with exit code: 1
10-11-27 10:28:42 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:28:43 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 9 seconds
10-11-27 10:28:52 PM de.bernhard-baehr.sleepwatcher[76] sleepwatcher:
10-11-27 10:28:52 PM de.bernhard-baehr.sleepwatcher[76] IOServiceGetMatchingService failed
10-11-27 10:28:52 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[76]) Exited with exit code: 1
10-11-27 10:28:52 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:03 PM de.bernhard-baehr.sleepwatcher[77] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:29:03 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[77]) Exited with exit code: 1
10-11-27 10:29:03 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:13 PM de.bernhard-baehr.sleepwatcher[78] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:29:13 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[78]) Exited with exit code: 1
10-11-27 10:29:13 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:23 PM de.bernhard-baehr.sleepwatcher[85] sleepwatcher: IOServiceGetMatchingService failed
10-11-27 10:29:23 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[85]) Exited with exit code: 1
10-11-27 10:29:23 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:33 PM de.bernhard-baehr.sleepwatcher[86] sleepwatcher:
10-11-27 10:29:33 PM de.bernhard-baehr.sleepwatcher[86] IOServiceGetMatchingService failed
10-11-27 10:29:33 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[86]) Exited with exit code: 1
10-11-27 10:29:33 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:43 PM de.bernhard-baehr.sleepwatcher[87] sleepwatcher:
10-11-27 10:29:43 PM de.bernhard-baehr.sleepwatcher[87] IOServiceGetMatchingService failed
10-11-27 10:29:43 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[87]) Exited with exit code: 1
10-11-27 10:29:43 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:29:53 PM de.bernhard-baehr.sleepwatcher[88] sleepwatcher:
10-11-27 10:29:53 PM de.bernhard-baehr.sleepwatcher[88] IOServiceGetMatchingService failed
10-11-27 10:29:53 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[88]) Exited with exit code: 1
10-11-27 10:29:53 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:03 PM de.bernhard-baehr.sleepwatcher[90] sleepwatcher:
10-11-27 10:30:03 PM de.bernhard-baehr.sleepwatcher[90] IOServiceGetMatchingService failed
10-11-27 10:30:03 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[90]) Exited with exit code: 1
10-11-27 10:30:03 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:14 PM de.bernhard-baehr.sleepwatcher[92] sleepwatcher:
10-11-27 10:30:14 PM de.bernhard-baehr.sleepwatcher[92] IOServiceGetMatchingService failed
10-11-27 10:30:14 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[92]) Exited with exit code: 1
10-11-27 10:30:14 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:24 PM de.bernhard-baehr.sleepwatcher[93] sleepwatcher:
10-11-27 10:30:24 PM de.bernhard-baehr.sleepwatcher[93] IOServiceGetMatchingService failed
10-11-27 10:30:24 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[93]) Exited with exit code: 1
10-11-27 10:30:24 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:34 PM de.bernhard-baehr.sleepwatcher[94] sleepwatcher:
10-11-27 10:30:34 PM de.bernhard-baehr.sleepwatcher[94] IOServiceGetMatchingService failed
10-11-27 10:30:34 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[94]) Exited with exit code: 1
10-11-27 10:30:34 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:44 PM de.bernhard-baehr.sleepwatcher[95] sleepwatcher:
10-11-27 10:30:44 PM de.bernhard-baehr.sleepwatcher[95] IOServiceGetMatchingService failed
10-11-27 10:30:44 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[95]) Exited with exit code: 1
10-11-27 10:30:44 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:54 PM de.bernhard-baehr.sleepwatcher[96] sleepwatcher:
10-11-27 10:30:54 PM de.bernhard-baehr.sleepwatcher[96] IOServiceGetMatchingService failed
10-11-27 10:30:54 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[96]) Exited with exit code: 1
10-11-27 10:30:54 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-27 10:30:59 PM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 5 seconds
10-11-27 10:31:26 PM com.apple.launchd.peruser.501[118] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-27 10:31:33 PM com.apple.WindowServer[99] Sun Nov 28 00:31:33 well-wells-MacBook.local WindowServer[99] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-27 10:31:33 PM com.apple.launchd.peruser.501[118] (com.apple.Kerberos.renew.plist[137]) Exited with exit code: 1
10-11-27 10:35:19 PM KeyboardSetupAssistant[159] writeKeyboardType <0-1452-0> 40
10-11-27 11:53:30 PM [0x0-0x20020].com.apple.iTunes[207] DownloadCategoryContentsThread took 0.568356051 seconds
10-11-27 11:54:26 PM Safari[228] AQMEIO_Base::DoStartIO: timeout
10-11-27 11:54:26 PM Safari[228] AQMEDevice::StartIO: error -66681
10-11-27 11:54:57 PM Safari[228] AQMEIO_Base::DoStartIO: timeout
10-11-27 11:54:57 PM Safari[228] AQMEDevice::StartIO: error -66681
10-11-28 12:14:35 AM com.apple.launchd.peruser.501[118] ([0x0-0x22022].com.apple.iTunesHelper[220]) Exited: Killed
10-11-28 12:46:29 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-28 12:46:29 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-28 12:46:43 AM com.apple.DumpPanic[31] 2010-11-28 02:46:43.233 DumpPanic[31:107] Error getting a reference to IODeviceTree:/options
10-11-28 12:46:43 AM com.apple.launchd[1] (com.apple.DumpPanic[31]) Exited with exit code: 1
10-11-28 12:46:45 AM de.bernhard-baehr.sleepwatcher[42] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:46:45 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[42]) Exited with exit code: 1
10-11-28 12:46:45 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 3 seconds
10-11-28 12:46:46 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 2 seconds
10-11-28 12:46:48 AM de.bernhard-baehr.sleepwatcher[73] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:46:48 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[73]) Exited with exit code: 1
10-11-28 12:46:48 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:46:58 AM de.bernhard-baehr.sleepwatcher[76] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:46:58 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[76]) Exited with exit code: 1
10-11-28 12:46:58 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:08 AM de.bernhard-baehr.sleepwatcher[77] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:08 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[77]) Exited with exit code: 1
10-11-28 12:47:08 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:19 AM de.bernhard-baehr.sleepwatcher[78] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:19 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[78]) Exited with exit code: 1
10-11-28 12:47:19 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:29 AM de.bernhard-baehr.sleepwatcher[85] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:29 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[85]) Exited with exit code: 1
10-11-28 12:47:29 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:39 AM de.bernhard-baehr.sleepwatcher[87] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:39 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[87]) Exited with exit code: 1
10-11-28 12:47:39 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:49 AM de.bernhard-baehr.sleepwatcher[88] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:49 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[88]) Exited with exit code: 1
10-11-28 12:47:49 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:47:59 AM de.bernhard-baehr.sleepwatcher[89] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:47:59 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[89]) Exited with exit code: 1
10-11-28 12:47:59 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:09 AM de.bernhard-baehr.sleepwatcher[90] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:48:09 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[90]) Exited with exit code: 1
10-11-28 12:48:09 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:19 AM de.bernhard-baehr.sleepwatcher[91] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:48:19 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[91]) Exited with exit code: 1
10-11-28 12:48:19 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:29 AM de.bernhard-baehr.sleepwatcher[92] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:48:29 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[92]) Exited with exit code: 1
10-11-28 12:48:29 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:39 AM de.bernhard-baehr.sleepwatcher[93] sleepwatcher:
10-11-28 12:48:39 AM de.bernhard-baehr.sleepwatcher[93] IOServiceGetMatchingService failed
10-11-28 12:48:39 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[93]) Exited with exit code: 1
10-11-28 12:48:39 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:49 AM de.bernhard-baehr.sleepwatcher[94] sleepwatcher:
10-11-28 12:48:49 AM de.bernhard-baehr.sleepwatcher[94] IOServiceGetMatchingService failed
10-11-28 12:48:49 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[94]) Exited with exit code: 1
10-11-28 12:48:49 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:48:59 AM de.bernhard-baehr.sleepwatcher[95] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 12:48:59 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[95]) Exited with exit code: 1
10-11-28 12:48:59 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 12:49:03 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 7 seconds
10-11-28 12:49:28 AM com.apple.launchd.peruser.501[118] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-28 12:49:36 AM com.apple.launchd.peruser.501[118] (com.apple.Kerberos.renew.plist[137]) Exited with exit code: 1
10-11-28 12:49:38 AM com.apple.WindowServer[97] Sun Nov 28 02:49:38 well-wells-MacBook.local WindowServer[97] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
10-11-28 1:23:46 AM de.bernhard-baehr.sleepwatcher[100] sleepwatcher: allow sleep
10-11-28 1:23:46 AM de.bernhard-baehr.sleepwatcher[140] sleepwatcher: allow sleep
10-11-28 1:23:46 AM de.bernhard-baehr.sleepwatcher[140] sh: /Users/wellwell/.sleep: No such file or directory
10-11-28 1:23:46 AM de.bernhard-baehr.sleepwatcher[140] sleepwatcher: sleep: ~/.sleep: 32512
10-11-28 1:23:47 AM de.bernhard-baehr.sleepwatcher[100] kextunload: unrecognized option `-t'
10-11-28 1:23:47 AM de.bernhard-baehr.sleepwatcher[100] sleepwatcher: sleep: /etc/rc.sleep: 0
10-11-28 7:51:00 AM com.apple.launchd[1] *** launchd[1] has started up. ***
10-11-28 7:51:00 AM com.apple.launchd[1] *** Verbose boot, will log to /dev/console. ***
10-11-28 7:51:14 AM com.apple.DumpPanic[31] 2010-11-28 07:51:14.283 DumpPanic[31:107] Error getting a reference to IODeviceTree:/options
10-11-28 7:51:14 AM com.apple.launchd[1] (com.apple.DumpPanic[31]) Exited with exit code: 1
10-11-28 7:51:21 AM de.bernhard-baehr.sleepwatcher[42] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:51:21 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[42]) Exited with exit code: 1
10-11-28 7:51:21 AM de.bernhard-baehr.sleepwatcher[51] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:51:21 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[51]) Exited with exit code: 1
10-11-28 7:51:21 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:51:23 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 9 seconds
10-11-28 7:51:32 AM de.bernhard-baehr.sleepwatcher[76] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:51:32 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[76]) Exited with exit code: 1
10-11-28 7:51:32 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:51:42 AM de.bernhard-baehr.sleepwatcher[77] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:51:42 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[77]) Exited with exit code: 1
10-11-28 7:51:42 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:51:52 AM de.bernhard-baehr.sleepwatcher[78] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:51:52 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[78]) Exited with exit code: 1
10-11-28 7:51:52 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:02 AM de.bernhard-baehr.sleepwatcher[86] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:52:02 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[86]) Exited with exit code: 1
10-11-28 7:52:02 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:12 AM de.bernhard-baehr.sleepwatcher[87] sleepwatcher:
10-11-28 7:52:12 AM de.bernhard-baehr.sleepwatcher[87] IOServiceGetMatchingService failed
10-11-28 7:52:12 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[87]) Exited with exit code: 1
10-11-28 7:52:12 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:22 AM de.bernhard-baehr.sleepwatcher[88] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:52:22 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[88]) Exited with exit code: 1
10-11-28 7:52:22 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:32 AM de.bernhard-baehr.sleepwatcher[89] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:52:32 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[89]) Exited with exit code: 1
10-11-28 7:52:32 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:42 AM de.bernhard-baehr.sleepwatcher[90] sleepwatcher:
10-11-28 7:52:42 AM de.bernhard-baehr.sleepwatcher[90] IOServiceGetMatchingService failed
10-11-28 7:52:42 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[90]) Exited with exit code: 1
10-11-28 7:52:42 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:52:53 AM de.bernhard-baehr.sleepwatcher[91] sleepwatcher:
10-11-28 7:52:53 AM de.bernhard-baehr.sleepwatcher[91] IOServiceGetMatchingService failed
10-11-28 7:52:53 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[91]) Exited with exit code: 1
10-11-28 7:52:53 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:53:03 AM de.bernhard-baehr.sleepwatcher[92] sleepwatcher: IOServiceGetMatchingService failed
10-11-28 7:53:03 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[92]) Exited with exit code: 1
10-11-28 7:53:03 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:53:13 AM de.bernhard-baehr.sleepwatcher[93] sleepwatcher:
10-11-28 7:53:13 AM de.bernhard-baehr.sleepwatcher[93] IOServiceGetMatchingService failed
10-11-28 7:53:13 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[93]) Exited with exit code: 1
10-11-28 7:53:13 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:53:23 AM de.bernhard-baehr.sleepwatcher[94] sleepwatcher:
10-11-28 7:53:23 AM de.bernhard-baehr.sleepwatcher[94] IOServiceGetMatchingService failed
10-11-28 7:53:23 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[94]) Exited with exit code: 1
10-11-28 7:53:23 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:53:33 AM de.bernhard-baehr.sleepwatcher[95] sleepwatcher:
10-11-28 7:53:33 AM de.bernhard-baehr.sleepwatcher[95] IOServiceGetMatchingService failed
10-11-28 7:53:33 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[95]) Exited with exit code: 1
10-11-28 7:53:33 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:53:40 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 3 seconds
10-11-28 7:53:43 AM de.bernhard-baehr.sleepwatcher[96] sleepwatcher:
10-11-28 7:53:43 AM de.bernhard-baehr.sleepwatcher[96] IOServiceGetMatchingService failed
10-11-28 7:53:43 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher[96]) Exited with exit code: 1
10-11-28 7:53:43 AM com.apple.launchd[1] (de.bernhard-baehr.sleepwatcher) Throttling respawn: Will start in 10 seconds
10-11-28 7:54:06 AM com.apple.launchd.peruser.501[119] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
10-11-28 7:54:13 AM com.apple.launchd.peruser.501[119] (com.apple.Kerberos.renew.plist[138]) Exited with exit code: 1
IBM R60 9456-68U Core Solo
Intel Corporation Mobile 945GM/PM/GMS, 943/940GML and 945GT Express Memory Controller Hub (rev 03)
nestawasright
Re: 10.6.X on X60/T60/X61 (CoreDuo, Core2Duo / GMA950, GMA3100)
#226 Post by nestawasright » Sun Nov 28, 2010 10:47 am
No, I've not. I've tried the one by the Great Gatsby earlier in this thread, but adding a line different from this one. Maybe I should give this a try also. It won't hurt.
The files you linked here are the ones I'm using. I'd mentioned this in an update. I was not able to see if ApplePS2controller work with sleep because mouse did not work. So I removed it and went to using the files in the link here that has AdidasPrince's driver. And that's working. I reported this earlier.
VoodooHDA from the macPNT package has internal mic support (custom info.plist) ... I followed Silencer's instruction for his T60p ...[/quote]
The VoodooHDA in the macPNT package is the one I'm using. I'm not sure about the custom "info.plist" you mentioned, what does that mean. Silencer has tons of post here, could you please send the link to his instruction.
I've uploaded complete information on my hardware, since it's the R60, this way to make sure we're not trying to squeeze water out of stone here. I appreciate all the help guys.
Sebinouse
#227 Post by Sebinouse » Sun Nov 28, 2010 12:43 pm
Silencer's modification is here
Our hardwares seem to be the same, except for the trackpad. You can use this PS2 kext instead.
Try to reinstall sleepwatcher (both packages) and add VoodooPS2Controller in rc.sleep/wakeup ... and it should be OK.
Lenovo X60t (6363-AQ8)
  • Intel CoreDuo 1,67 GHz (L2400)
  • 3 Go / 320 Go / GMA950 / FW 400 / SD Card
  • Bluetooth / Wifi AR5BXB6 / Tablet
WinXP / MacOSX 10.6.8 (DSDT patch and vanilla SLE)
Great Gatsby
#228 Post by Great Gatsby » Sun Nov 28, 2010 12:46 pm
Wow, quite a few posts since Friday - I'll try to answer the remaining questions (sorry if I don't keep their order):
nestawasright wrote:The VoodooHDA in the macPNT package is the one I'm using. I'm not sure about the custom "info.plist" you mentioned, what does that mean. Silencer has tons of post here, could you please send the link to his instruction.
A kext is nothing more than a folder with sub-folders and files in it. It is only displayed as a single file by the Macintosh Finder. However, you can circumvent the Finder's default behavior and view the kext's contents from the its context menu (right-click) by choosing "Show contents" (... or similar - I don't want to switch languages and logout/re-login right now to see what the English menu item is). Inside this structure of folders, you will find a .plist file modified by Sebinouse to enable Mic-in.
Great Gatsby
#229 Post by Great Gatsby » Sun Nov 28, 2010 1:07 pm
nestawasright wrote:That's superb help. Let me get to your questions right now.
My model is this: R60 9456-68U
Mine is Core Solo
Yes, I downloaded your system report and it's indeed a T1300 Core Solo. If you want to have your CPU reported correctly in the "About this Mac" dialog - albeit only a cosmetic issue -, you could insert the correct SMcputype value into smbios.plist. Core 2 Solo should be
<key>SMcputype</key>
<string>257</string>
Unfortunately, I don't have the correct value for a plain Core Solo - maybe someone else on this board has?
Edit: I'm a bit confused about whether the '257'-value stands for a Core 2 Solo or a Core Solo. AsereBLN actually lists it as the correct value for a Core Solo. If your CPU is currently reported as a Core 2-something CPU, you could try to remove the value for SMcputype from smbios.plist to check whether AsereBLN's auto-detection is able to identify your CPU. If that doesn't work, either, you could try the '257'-value. It has to be said, however, that this is only cosmetic and has no real impact on your system's performance.
nestawasright wrote:I did not set the "hibernatemode". Assistance on this will be great.
Sebinouse had posted an URL to an article about the different hibernatemodes above. In short, they determine how your ThinkPad goes to sleep and in what kind of sleep it goes. You can display your machine's current hibernatemode using the Mac OS X Terminal:
pmset -g | grep hibernatemode
On particular configurations of RAM, only very specific hibernatemodes seem to work, e.g. on my X60 Tablet with three Gigabytes of RAM where sleep will only work using hibernatemode 1 (at least for the moment, hopefully there will be a workaround for this in the future). For further information, also have a look at Sebinouse's post on this here on the forum.
Concerning your system log: - Wow, these are quite a number of errors in it. :o I can't comment on every single line, but there's obviously still a problem with SleepWatcher, so I'd recommend you try the complete SleepWatcher re-install first that Sebinouse has already proposed above.
Good luck!
nestawasright
#230 Post by nestawasright » Sun Nov 28, 2010 3:45 pm
Sebinouse wrote:The VoodooHDA in the macPNT package is the one I'm using. I'm not sure about the custom "info.plist" you mentioned, what does that mean. Silencer has tons of post here, could you please send the link to his instruction.
I will get these and report back later today...soon.
I will remove the VoodooPS2controller that is bundled with UltraNavi driver made by AdidasPrince that I'm using now. And then I will install this one. Though you've not said if this is connected with the sleep issue. If it's not, I'm fine with the one you suggested earlier and that I'm currently using (UltraNavi driver made by AdidasPrince) Please clarify, if you can.
Try to reinstall sleepwatcher (both packages) and add VoodooPS2Controller in rc.sleep/wakeup ... and it should be OK.[/quote]
As you may have noticed from the log, I currently have Sleepwatcher 2.1 installed, which was an upgrade from 2.0.5 that is in the MacNT package. I'm not quite sure how to downgrade from 2.1 back to the version that's in the folder you started this post with.
Please offer suggestions. And I will add VoodooPS2Controller for sure to both rc's.
Thanks a lot. I'm close, I can feel it and the help here has been great!
Can I share my dsdt with you guys. It was borrowed from someone's R60 that has Radeon Video card. Could this be the source of the many errors Gatbsy the Great talks about?
I'm glad to hear that we have very similar hardware, that's reason to hope.PS2
Sebinouse
#231 Post by Sebinouse » Sun Nov 28, 2010 4:11 pm
you can keep any VoodooPS2 that is already working for you ... (there is no need to take this one)
I used to have sleep issues with PS2 driver, so I had to use the sleepwatcher trick.
Another issue is RAM. If you have 1 or 2 GB you can set hibernation mode to 1 or 3. If you have 3GB or more you have to set hibernation mode to 1.
About your DSDT, Did you tried my DSDT for the X60t ? If you want to make our own DSDT you can read Silencer's thread and mix yours with mine.
nestawasright
#232 Post by nestawasright » Sun Nov 28, 2010 4:32 pm
Glad to see you're here with me at the same time...give me 5 minutes and I will give you updates. I've already removed the VoodooPS2, working on the VoodooHDA now.
I have less than 3GM RAM
...return soon
nestawasright
#233 Post by nestawasright » Sun Nov 28, 2010 4:37 pm
Silencer's VoodooHDA links are a bit confusing. Would you mind, Sebinouse, send me a link to your complete VoodooHDA solution, as you're using it? Thanks a lot.
nestawasright
#234 Post by nestawasright » Sun Nov 28, 2010 5:00 pm
Great Gatsby wrote:That's superb help. Let me get to your questions right now.
Mine is Core Solo
Good luck![/quote]
How can I downgrade, remove, complete uninstall of Sleepwatcher 2.1? It's not a visible kext I can just delete. I can remove the rc's but there's more to it than that...please help.
Great Gatsby
#235 Post by Great Gatsby » Sun Nov 28, 2010 5:07 pm
nestawasright wrote:How can I downgrade, remove, complete uninstall of Sleepwatcher 2.1? It's not a visible kext I can just delete. I can remove the rc's but there's more to it than that...please help.
I'm not in front of my ThinkPad right now, but as far as I remember there are un-install instructions in the SleepWatcher 2.1 install package from the author's site. He lists what you need to remove from your system to un-install version 2.1, I believe. Have a look at the package's readme file.
nestawasright
#236 Post by nestawasright » Sun Nov 28, 2010 5:48 pm
Sebinouse wrote: The VoodooHDA in the macPNT package is the one I'm using. I'm not sure about the custom "info.plist" you mentioned, what does that mean. Silencer has tons of post here, could you please send the link to his instruction.
I have grabbed all the files. I put the plist into the VoodooADA kexts. Installed that and the prepane. I get a lot of registry type errors and no sound. Can someone with my soundcard share their plist please. I have my complete hardware info here.
I did grab and installed this already and will add it to the rc's once I find out how to downgrade.
It really will be nice if someone can tell me how to completetly remove sleepwatcher 2.1. It's easy to upgrade, as the developer provided instructions, but none to downgrade.
Sebinouse
#237 Post by Sebinouse » Mon Nov 29, 2010 3:41 am
We have the same sound card so you can use VoodooHDA.kext from MacPNT package !
Sometimes with pfix, VoodooHDA is not KextCached properly, try Kextutility instead of pfix.
Try to load it manually with terminal :
sudo kextload /Extra/Extensions/VoodooHDA.kext
nestawasright
#238 Post by nestawasright » Mon Nov 29, 2010 3:14 pm
Sebinouse wrote:We have the same sound card so you can use VoodooHDA.kext from MacPNT package !
This is great news. I will uninstall and use the kexts from MacPNT. Please confirm, do you have internal mic input working on yours?
I will do exactly what you've asked here. And report back later today.
Sebinouse, thanks a lot for your attention to this. I'd ensure I vote on the "other" once I have audio and sleep working, hopefully today.
Also, since you guys saw my console output, and with Gatsby the Great saying that's quite a lot of errors. I was wondering if you doctors would suggest how I could go about fixing those errors. A reminder this is a vanilla install with Myhack, added some kexts and a dsdt from another R60. Should I try the dsdt in the MacPNT package, and if so which one? What other files from that great package should I have in this laptop...thanks a lot, a billion, guys!
Sebinouse
#239 Post by Sebinouse » Mon Nov 29, 2010 3:27 pm
The X60 DSDT should be OK ... I hope so ! (the one by default)
Sebinouse
#240 Post by Sebinouse » Mon Nov 29, 2010 3:42 pm
nestawasright wrote:Also, since you guys saw my console output, and with Gatsby the Great saying that's quite a lot of errors. I was wondering if you doctors would suggest how I could go about fixing those errors. A reminder this is a vanilla install with Myhack, added some kexts and a dsdt from another R60.
This entire thread is about the installation method from the first post, not every method ! We can't help you if we don't have the same data !
So PLEASE follow this guide and then report back ... (we have almost the same hardware)
Once again every single detail relies on another ... for instance PowerManagement is related to the DSDT, the choice of the bootloader, the smbios file and one kext ... and it is one example among others !
