ThinkPad W510 hackintosh
Yong
Re: ThinkPad W510 hackintosh
#31 Post by Yong » Thu May 13, 2010 4:46 pm
ok I'll post it later ,cause I can't use Mac online.
ThinkPad W510 I7 720p, 4G , Nvidia 1G Fx880M,HD+ LED,intel82577 6300 ,Win 7 x64 Ultimate & Mac OS Snow
Yong
#32 Post by Yong » Thu May 13, 2010 8:42 pm
compile dsdt 's error ,how to fix it?
intel ACPI Component Architecture
AML Disassembler version 20081204 [Dec 4 2008]
Copyright (C) 2000 - 2008 Intel Corporation
Supports ACPI Specification Revision 3.0a
Intel ACPI Component Architecture
ASL Optimizing Compiler version 20081204 [Dec 4 2008]
dsdt.dsl 1: ACPI SWGP, 8,
Error 4095 - ^ parse error, expecting `error' or `PARSEOP_DEFINITIONBLOCK'
ASL Input: dsdt.dsl - 12898 lines, 436123 bytes, 0 keywords
AML Output: (null) - 0 bytes, 0 named objects, 0 executable opcodes
Compilation complete. 1 Errors, 0 Warnings, 0 Remarks, 0 Optimizations
Silencer
#33 Post by Silencer » Fri May 14, 2010 2:53 am
Yong wrote: dsdt.dsl 1: ACPI SWGP, 8,
Upload full DSDT somewhere. It's hard to check what's wrong without seeing full code.
Intel Core 2 Duo T7600
Sebinouse
#34 Post by Sebinouse » Fri May 14, 2010 4:09 am
If the beginning of your dsdt.dsl is like this :
ACPI Error (dmutils-0261): Argument count mismatch for method \_SB_.VWAK 3 1 [20080926]
ACPI Error (dmutils-0261): Argument count mismatch for method \_GPE.VBRE 2 1 [20080926]
 * Intel ACPI Component Architecture
 * AML Disassembler version 20080926
 * Disassembly of ./dsdt.dat, Wed Dec 10 09:55:50 2008
 * Original Table Header:
 *     Signature        "DSDT"
 *     Length           0x00016838 (92216)
 *     Revision         0x01 **** ACPI 1.0, no 64-bit math support
 *     Checksum         0xA6
 *     OEM ID           "HPQOEM"
 *     OEM Table ID     "30E7    "
 *     OEM Revision     0x00000001 (1)
 *     Compiler ID      "INTL"
 *     Compiler Version 0x20060912 (537266450)
Just remove the lines before the "/*"
Then your file will start to compile (and then you may find other errors ...)
Source InsanelyMac
Lenovo X60t (6363-AQ8)
  • Intel CoreDuo 1,67 GHz (L2400)
  • 3 Go / 320 Go / GMA950 / FW 400 / SD Card
  • Bluetooth / Wifi AR5BXB6 / Tablet
WinXP / MacOSX 10.6.8 (DSDT patch and vanilla SLE)
Yong
#35 Post by Yong » Fri May 14, 2010 7:57 am
Yong Hong’s Mac Pro
10-05-14 4:32 AM
Hardware:
Hardware Overview:
Model Name: Mac Pro
Model Identifier: MacPro2,1
Processor Speed: 1.69 GHz
Number Of Processors: 1
Total Number Of Cores: 4
L2 Cache (per core): 256 KB
L3 Cache: 6 MB
Memory: 4 GB
Processor Interconnect Speed: 55.30 GT/s
Boot ROM Version: MP21.005C.B01
SMC Version (system): 1.13f3
Serial Number (system): SOMESRLNMBR
Network:
Bluetooth DUN:
Type: PPP (PPPSerial)
Hardware: Modem
BSD Device Name: Bluetooth-Modem
IPv4:
Configuration Method: PPP
IPv6:
Configuration Method: Automatic
Proxies:
FTP Passive Mode: Yes
Service Order: 0
PCI Serial Adapter (22):
Hardware: Modem
BSD Device Name: pci-serial22
IPv4:
IPv6:
Proxies:
Service Order: 1
FireWire:
Type: FireWire
Hardware: FireWire
BSD Device Name: fw0
IPv4:
Configuration Method: DHCP
IPv6:
Ethernet:
MAC Address: 00:26:2d:ff:f7:04:2b:ff
Media Options: Full Duplex
Media Subtype: Auto Select
Proxies:
Exceptions List: *.local, 169.254/16
Service Order: 2
Software:
System Software Overview:
System Version: Mac OS X 10.6.3 (10D575)
Kernel Version: Darwin 10.3.0
Boot Volume: Mac OS Snow Leopard
Boot Mode: Normal
Computer Name: Yong Hong’s Mac Pro
User Name: Yong Hong (Yong)
Secure Virtual Memory: Enabled
64-bit Kernel and Extensions: Yes
Time since boot: 3 minutes
Audio (Built In):
Intel High Definition Audio:
Device ID: 0x17AA215E
Audio ID: 0
Bluetooth:
Apple Bluetooth Software Version: 2.3.1f4
Hardware Settings:
Address: c4-17-fe-f1-2c-6a
Manufacturer: Broadcom
Firmware Version: 3 (360)
Bluetooth Power: On
Discoverable: Yes
Vendor ID: 0
Product ID: 0
HCI Version: 4 (0x4)
HCI Revision: 360 (0x168)
LMP Version: 4 (0x4)
LMP Subversion: 16899 (0x4203)
Device Type (Major): Computer
Device Type (Complete): Macintosh Portable
Composite Class Of Device: 3670284 (0x38010c)
Device Class (Major): 1 (0x1)
Device Class (Minor): 3 (0x3)
Service Class: 448 (0x1c0)
Requires Authentication: No
Services:
Bluetooth File Transfer:
Folder other devices can browse: ~/Public
Requires Authentication: Yes
State: Enabled
Bluetooth File Exchange:
Folder for accepted items: ~/Downloads
When other items are accepted: Ask
When PIM items are accepted: Ask
When receiving items: Prompt for each file
State: Enabled
Incoming Serial Ports:
Serial Port 1:
RFCOMM Channel: 3
Outgoing Serial Ports:
Serial Port 1:
Address:
RFCOMM Channel: 0
Diagnostics:
Power On Self-Test:
Last Run: 10-05-14 4:29 AM
Result: Passed
Disc Burning:
HL-DT-ST DVDRAM GT30N:
Firmware Revision: LT09
Interconnect: ATAPI
Burn Support: Yes (Generic Drive Support)
Profile Path: None
Cache: 1024 KB
Reads DVD: Yes
CD-Write: -R, -RW
DVD-Write: -R, -R DL, -RAM, -RW, +R, +R DL, +RW
Write Strategies: CD-TAO, CD-SAO, CD-Raw, DVD-DAO
Media: To show the available burn speeds, insert a disc and choose View > Refresh
FireWire:
FireWire Bus:
Maximum Speed: Up to 400 Mb/sec
Graphics/Displays:
Unknown nVidia card:
Chipset Model: Unknown nVidia card
Type: GPU
Bus: PCIe
PCIe Lane Width: x16
VRAM (Total): 1024 MB
Vendor: NVIDIA (0x10de)
Device ID: 0x0a3c
Revision ID: 0x00a2
Displays:
Display:
Resolution: 1600 x 900 @ 60 Hz
Pixel Depth: 32-Bit Color (ARGB8888)
Main Display: Yes
Mirror: Off
Online: Yes
Built-In: Yes
Display Connector:
Status: No Display Connected
Memory:
Memory Slots:
ECC: Disabled
Bank 0/1/DIMM 1:
Type: DDR2 SDRAM
Speed: 667 MHz
Status: OK
Manufacturer: Apple Inc.
Part Number: ABCDEFGHIJ
Serial Number: 1234567890
Bank 2/3/DIMM 2:
Type: Empty
Speed: Empty
Status: Empty
Manufacturer: Empty
Part Number: Empty
Serial Number: Empty
Bank 4/5/DIMM 3:
Type: DDR2 SDRAM
Speed: 667 MHz
Status: OK
Bank 6/7/DIMM 4:
Type: Empty
Speed: Empty
Status: Empty
Manufacturer: Empty
Part Number: Empty
Power:
System Power Settings:
AC Power:
System Sleep Timer (Minutes): 10
Disk Sleep Timer (Minutes): 10
Display Sleep Timer (Minutes): 10
Sleep On Power Button: Yes
Wake On Clamshell Open: Yes
Current Power Source: Yes
Battery Power:
Display Sleep Timer (Minutes): 2
Hardware Configuration:
UPS Installed: No
Printers:
The printers list is empty. To add printers, choose Apple menu > System Preferences…, click Print & Fax, and then click Add (+).:
CUPS Version: 1.4.3 (cups-218.9)
Serial-ATA:
Intel 5 Series Chipset:
Vendor: Intel
Product: 5 Series Chipset
Link Speed: 3 Gigabit
Negotiated Link Speed: 3 Gigabit
Description: AHCI Version 1.30 Supported
ST9320423AS:
Capacity: 320.07 GB (320,072,933,376 bytes)
Model: ST9320423AS
Revision: 0003LVM1
Serial Number: 5VH29221
Native Command Queuing: Yes
Queue Depth: 32
Removable Media: No
Detachable Drive: No
BSD Name: disk0
Rotational Rate: 7200
Partition Map Type: MBR (Master Boot Record)
S.M.A.R.T. status: Verified
Volumes:
Windows7_OS:
Capacity: 53.69 GB (53,686,370,304 bytes)
Available: 30.85 GB (30,851,915,776 bytes)
Writable: No
File System: NTFS
BSD Name: disk0s1
Mount Point: /Volumes/Windows7_OS
Program:
Capacity: 223.15 GB (223,150,604,288 bytes)
Available: 41.01 GB (41,006,292,992 bytes)
Writable: No
File System: NTFS
BSD Name: disk0s2
Mount Point: /Volumes/Program
Mac OS Snow Leopard:
Capacity: 43.23 GB (43,232,788,480 bytes)
Available: 31.61 GB (31,607,611,392 bytes)
Writable: Yes
File System: Journaled HFS+
BSD Name: disk0s3
Mount Point: /
Vendor: Intel
Negotiated Link Speed: 1.5 Gigabit
HL-DT-STDVDRAM GT30N:
Model: HL-DT-STDVDRAM GT30N
Revision: LT09
Serial Number: M2NA3GE1021
Native Command Queuing: No
Power Off: No
Async Notification: Yes
Vendor: Intel
Vendor: Intel
USB:
USB High-Speed Bus:
Host Controller Location: Built-in USB
Host Controller Driver: AppleUSBEHCI
PCI Device ID: 0x3b3c
PCI Revision ID: 0x0006
PCI Vendor ID: 0x8086
Bus Number: 0x1a
Hub:
Product ID: 0x0020
Vendor ID: 0x8087 (Intel Corporation)
Version: 0.00
Speed: Up to 480 Mb/sec
Location ID: 0x1a100000
Current Available (mA): 500
Current Required (mA): 0
Biometric Coprocessor:
Product ID: 0x2016
Vendor ID: 0x147e
Version: 0.02
Speed: Up to 12 Mb/sec
Manufacturer: UPEK
Location ID: 0x1a130000
Current Required (mA): 100
Broadcom Bluetooth Device:
Product ID: 0x217f
Vendor ID: 0x0a5c (Broadcom Corp.)
Version: 3.60
Serial Number: C417FEF12C6A
Manufacturer: Broadcom Corp
Location ID: 0x1a140000
USB2.0 Hub Controller:
Product ID: 0x0058
Vendor ID: 0x0409 (NEC Corporation)
Version: 1.00
Manufacturer: NEC Corporation
Location ID: 0x1a120000
Logitech BT Mini-Receiver:
Product ID: 0x0b06
Vendor ID: 0x046d (Logitech Inc.)
Version: 1.01
Manufacturer: Logitech
Location ID: 0x1a123000
Product ID: 0xc71c
Version: 1.01
Serial Number: 000761AEBB33
Location ID: 0x1a123300
Current Available (mA): 150
Current Required (mA): 98
Product ID: 0xc71b
Version: 1.01
Location ID: 0x1a123200
Integrated Camera:
Product ID: 0x480f
Vendor ID: 0x17ef (Lenovo)
Version: 23.45
Manufacturer: Chicony Electronics Co., Ltd.
Location ID: 0x1a160000
Current Required (mA): 200
USB High-Speed Bus:
PCI Device ID: 0x3b34
Bus Number: 0x1d
Hub:
Product ID: 0x0020
Version: 0.00
Location ID: 0x1d100000
AirPort:
Software Versions:
Menu Extra: 6.2.1 (621.1)
configd plug-in: 6.2 (620.15.1)
System Profiler: 6.0 (600.9)
Network Preference: 6.2.1 (621.1)
AirPort Utility: 5.4.2 (542.23)
IO80211 Family: 3.1 (310.6)
Firewall:
Firewall Settings:
Mode: Allow all incoming connections
Firewall Logging: No
Stealth Mode: No
Locations:
Automatic:
Active Location: Yes
Services:
Bluetooth DUN:
Type: PPP
IPv4:
IPv6:
Proxies:
PPP:
ACSP Enabled: No
Display Terminal Window: No
Redial Count: 1
Redial Enabled: Yes
Redial Interval: 5
Use Terminal Script: No
Dial on Demand: No
Disconnect on Fast User Switch: Yes
Disconnect on Idle: Yes
Disconnect on Idle Timer: 600
Disconnect on Logout: Yes
Disconnect on Sleep: Yes
Idle Reminder: No
Idle Reminder Time: 1800
IPCP Compression VJ: Yes
LCP Echo Enabled: No
LCP Echo Failure: 4
LCP Echo Interval: 10
Log File: /var/log/ppp.log
Verbose Logging: No
Type: PPP
IPv4:
IPv6:
Proxies:
PPP:
ACSP Enabled: No
Redial Count: 1
Redial Enabled: Yes
Redial Interval: 5
Dial on Demand: No
Idle Reminder: No
LCP Echo Enabled: Yes
LCP Echo Failure: 4
Verbose Logging: No
FireWire:
Type: FireWire
Hardware (MAC) Address: 00:26:2d:ff:f7:04:2b:ff
IPv4:
IPv6:
Proxies:
Volumes:
net:
Type: autofs
Mount Point: /net
Mounted From: map -hosts
Automounted: Yes
home:
Type: autofs
Mount Point: /home
Mounted From: map auto_home
Automounted: Yes
lenovo_99
#36 Post by lenovo_99 » Fri May 14, 2010 8:13 am
Yong:
The system specs posted is from your Lenovo W510 running hackintosh?
Yong/Silencer:
Can any of you tell me that by looking into the System Info uploaded by Yong, is everything working? I'm seeing the GPU card name is unknown but atleast it looks like it correctly identifies the VRAM as 1GB and is CI/QE hardware accelerated?
Thanks.
Silencer
#37 Post by Silencer » Fri May 14, 2010 8:15 am
lenovo_99 wrote: Can any of you tell me that by looking into the System Info uploaded by Yong, is everything working? I'm seeing the GPU card name is unknown but atleast it looks like it correctly identifies the VRAM as 1GB and is CI/QE hardware accelerated?
In Snow Leopard you can't tell if QE/CI is working from System Profiler. You need to see if screensaver works, and if Dashboard widgets have ripple effect when you move/add them.
Yong
#38 Post by Yong » Fri May 14, 2010 8:20 am
[quote="Silencer"]
I post here ,could you please fix it for me ?
Thanks.
http://forum.notebookreview.com/lenovo- ... ost6249271
Silencer
#39 Post by Silencer » Fri May 14, 2010 8:35 am
Yong wrote: I post here ,could you please fix it for me ?
Thanks.
I believe Sebinouse has already provided you with the answer on how to fix your compilation error.
lenovo_99
#40 Post by lenovo_99 » Fri May 14, 2010 9:48 am
Silencer wrote: In Snow Leopard you can't tell if QE/CI is working from System Profiler. You need to see if screensaver works, and if Dashboard widgets have ripple effect when you move/add them.
Yong:
Can you try what Silencer suggested to check for CI/QE? Also, Silencer: I'm curious what Yong is trying to compile and for what reason?
Thanks.
Silencer
#41 Post by Silencer » Fri May 14, 2010 10:24 am
lenovo_99 wrote:Can you try what Silencer suggested to check for CI/QE? Also, Silencer: I'm curious what Yong is trying to compile and for what reason?Thanks.
Check my DSDT guide about it: http://forum.thinkpads.com/viewtopic.php?f=32&t=85344
Yong
#42 Post by Yong » Fri May 14, 2010 8:23 pm
Thanks guys , I remove the first two lines ,and got a error and 9 warnings , I'm really noob about this.
dsdt.dsl 3910: If (LFLS ())
Warning 1092 - ^ Called method may not always return a value
dsdt.dsl 4013: If (LFLS ())
dsdt.dsl 4036: If (LFLS ())
dsdt.dsl 4101: If (LFLS ())
dsdt.dsl 4113: If (LFLS ())
dsdt.dsl 4133: Method (LFLS, 0, NotSerialized)
Warning 1087 - ^ Not all control paths return a value (LFLS)
dsdt.dsl 6745: Method (MXDS, 1, NotSerialized)
Warning 1087 - ^ Not all control paths return a value (MXDS)
dsdt.dsl 7249: Name (_HID, "*pnp0c14")
Error 4001 - String must be entirely alphanumeric ^ (*pnp0c14)
dsdt.dsl 7352: Return (\_SB.PCI0.PEG.VID.MXDS (XARG))
Warning 1092 - Called method may not always return a value ^
dsdt.dsl 9247: Method (_Q15, 0, NotSerialized)
Warning 1087 - ^ Not all control paths return a value (_Q15)
ASL Input: dsdt.dsl - 13203 lines, 444088 bytes, 4963 keywords
AML Output: DSDT.aml - 46794 bytes, 1090 named objects, 3873 executable opcodes
Compilation complete. 1 Errors, 9 Warnings, 0 Remarks, 2362 Optimizations
Yong
#43 Post by Yong » Fri May 14, 2010 8:47 pm
I changed "*pnp0c14" to "pnp0c14" ,now no error ,is this right?
Yong
#44 Post by Yong » Fri May 14, 2010 10:02 pm
I just got displayport-dp-to-hdmi-connector-adapte today for my w510 to connect to my LG TV. the website is
http://www.buyincoins.com/displayport-d ... -1334.html
it's free shipping to Canada ,the price is $8.69 US dollars. if add coupon sonyhdr12 ,you can get 5% discount.
In win 7 I press FN+F7 can switch to TV ,the video and sound both are all on TV ,like HDMI. But It's weird , I restart windows ,the windows stuck at "starting windows" when the displayport-dp-to-hdmi-connector-adapte connecting in my w510. I enter into the BIOS ,w510 has a setting -----dispaly -----Boot display Device.
1. Thinkpad LCD(default) 3. Digital on thinkpad is displayport. When I choose 3. Digital on thinkpad is displayport .then restart w510 , I can see before windows logon on my TV , w510's LCD is black ,then it logon into the windows ,LCD is on TV is off.
and I try use displayport to display on my TV in Mac OS, nothing happened ,I try to use FN+F7 ,the Mac Snow stucked ,even mouse is not working .
By the way I saw the ripplle water on my Mac OS , but using VCLto play movies , the videos is a little fast , and the sound is poor.
sorry about my poor English ,hope you guys to understand what I mean.
Yong
#45 Post by Yong » Fri May 14, 2010 11:17 pm
displayport 's problem is solved I just choose the second 2. anolog (VGA) in BIOS ,everything is ok now.
I test the movies , if I use Itune to play 720P mov .Both video and sound are good ,but using quicktime , picture and sound are not synchronous. Using VLC videos are way too fast and this cause the sound are very poor. SO this maybe player's problem. Anyone can recommend me which video player in Mac is the best? I can't use internet on Mac making things hard to be solved.
Yong
#46 Post by Yong » Sat May 15, 2010 12:00 am
In Snow Leopard you can't tell if QE/CI is working from System Profiler. You need to see if screensaver works, and if Dashboard widgets have ripple effect when you move/add them.[/quote]
I just tested them ,both are working on my w510 for sure ,so QE/CI is working on my w510?
lenovo_99
#47 Post by lenovo_99 » Sat May 15, 2010 1:07 am
Yong/Silencer/others:
Very helpful guys. I'm almost close to getting a W510.
Yong: Can you download this to a flash drive on Windows 7 and run this on Snow Leopard? http://www.livequartz.com/site/livequar ... rtz_19.dmg
This app supports Core Image as it should make the GPU work. Please let me know how it runs.
Also, please confirm CI/QE here: http://prasys.co.cc/2009/09/quartz-extr ... w-leopard/
But, Silencer has mentioned that it is not shown on a Snow Leopard. I wanted to confirm from Yong that CI/QE is not software based but should be hardware accelerated. Silencer: please advice.
Also, can you tell me why did you compile dsdt for? I don't understand.
Thanks.
Silencer
#48 Post by Silencer » Sat May 15, 2010 3:45 am
Yong wrote:Anyone can recommend me which video player in Mac is the best? I can't use internet on Mac making things hard to be solved.
I use VLC and it is fine. I suggest you to google that specific problem (video is too fast in VLC in OSX), most probably it has simple solution. Quicktime is known to be very slow.
To be on the safe side, check screensavers and resolution switching. If they work, video is fine.
Silencer
#49 Post by Silencer » Sat May 15, 2010 3:48 am
lenovo_99 wrote:Also, can you tell me why did you compile dsdt for? I don't understand.Thanks.
Did you even click on the link I provided before? Please read the DSDT guide first.
lenovo_99
#50 Post by lenovo_99 » Mon May 17, 2010 9:29 am
Yong:
Did you try my suggestions to check for CI/QE?
Also, was your dsdt compilation successful?
Thanks.
Yong
#51 Post by Yong » Mon May 17, 2010 7:36 pm
lenovo_99 wrote:Yong:
Thanks.
Thanks for your link , all of four methods are working like a charm.
Yong
#52 Post by Yong » Mon May 17, 2010 7:37 pm
now the main problem I can't use internet , who has intel 82577lm.kext please?
Sebinouse
#53 Post by Sebinouse » Tue May 18, 2010 4:39 am
Did you tried this kext for Leopard ?
http://www.insanelymac.com/forum/index. ... 5771&st=40
Silencer
#54 Post by Silencer » Tue May 18, 2010 5:04 am
Yong wrote:now the main problem I can't use internet , who has intel 82577lm.kext please?
You can try kext for 82566m, it might work. Download package from here and get the kext there.
Yong
#55 Post by Yong » Tue May 18, 2010 8:30 am
Sebinouse wrote:Did you tried this kext for Leopard ?
haha ,I love you guys this works, my w510 is almost perfect, thank you ,thank you thank you.
crashnburn
#56 Post by crashnburn » Tue May 18, 2010 1:19 pm
Yong wrote:haha ,I love you guys this works, my w510 is almost perfect, thank you ,thank you thank you.
Wow! Can you please post your EXACT Hardware specs and Step by Step Guide to how it all got working successfully.. That would be great.
Yong
#57 Post by Yong » Tue May 18, 2010 10:11 pm
geekbench mark is only 1408 ,something is wrong.
Silencer
#58 Post by Silencer » Wed May 19, 2010 2:58 am
Yong wrote:geekbench mark is only 1408 ,something is wrong.
SpeedStep is probably not working correctly, and CPU is running at the lowest frequency.
marksoccer105
#59 Post by marksoccer105 » Thu May 20, 2010 10:43 pm
Yeah, Yong, if you could please post your DSDT and list all the kexts and special steps needed to get Snow Leopard running, I would really appreciate it. Thanks
crashnburn
#60 Post by crashnburn » Fri May 21, 2010 12:09 pm
marksoccer105 wrote:Yeah, Yong, if you could please post your DSDT and list all the kexts and special steps needed to get Snow Leopard running, I would really appreciate it. Thanks
One more vote here :)
