Freeware
Talk about "WhatEVER !"..
fasteez
Re: Freeware
#31 Post by fasteez » Tue Aug 31, 2010 3:09 pm
Nobody uses PDFCreator ? opensource virtual pdf printer which is close to perfection. (Never used the other though.. because PDFCreator always delivered, well almost always)
If you often run into "locked files" that you cannot open/copy/rename, try http://ccollomb.free.fr/unlocker/
my own list goes like this
pdf:
foxit reader, sumatra pdf
multimedia:
xnview
vlc/mpc/klcp
foobar+plugins
imgburn
hmm:
notepad2/notepad++
putty/winscp
system internals suite
unlocker
eraser
utorrent
7zip
tp related:
nhc
tpfc
ps : we should centralize this someway
X60s 1702-YAB `L2400 | T61 7659-12U `T7300
X32 2672-KJG `750 | X31 2672-CBG `705 |X41 | X41t 1867-A44 `758
[fs] x61s 3GB, 100GB, Batt+AC ... dead mobo & lcd
[sold] x60 T2400 1Gb wlan|eth
crashnburn
Re: Freeware
#32 Post by crashnburn » Tue Aug 31, 2010 4:34 pm
fasteez.. I use ALL of the ones you listed.. :)
I'll add ..
TreeSize
Sizer
fasteez
Re: Freeware
#33 Post by fasteez » Tue Aug 31, 2010 5:21 pm
Treesize mos def !
I forgot to check the "old portable apps" dir
emacs
dokan sshfs ( add ssh folders under "My Computer" in windows )
treesizefree
winmerge
windirstats
i took windows binaries of wget and curl, always handy to mass download
nlite
qemu
virtualdub
I guess that's it
ThinkRob
Re: Freeware
#34 Post by ThinkRob » Tue Aug 31, 2010 6:24 pm
Of the programs I use that are Free software (and free software), by far the most useful is VirtualBox, as it lets me do my job. Having the ability to use a well-supported, fully-functional, totally-free VM solution is awesome. I routinely have to test things on a number of different platforms, and not a workday goes by where I don't use VirtualBox for at least a couple instances.
Current laptop: X1 Carbon 3
Current workstation: none
A31
Re: Freeware
#35 Post by A31 » Sat Sep 04, 2010 2:55 am
I do my programming on Visual Basic 2010 Express (which is free from Microsoft and it has all the features I will ever need and more), and I do file archiving on 7-Zip, which is free and open source.
Past: IBM ThinkPad A31, R40
Tasurinchi
Re: Freeware
#36 Post by Tasurinchi » Wed Oct 06, 2010 4:07 am
In my Windows machines (Thinkpads or Desktops) I use only freeware software (appart from Windows itself, of course). But what I particularly like to use is a bunch of portable software that I don't need to re-install after every clean install or setting up a new desktop/Thinkpad. My preferred ones:
- Thunderbird portable
- Firefox portable
- Chrome portable
- Free Commander Portable
- 7zip portable
- VLC portable
- uTorrent portable
- Skype portable
- Foxit reader portable (PDFs)
- ProcessExplorer
The best thing is that I have a copy of all those folders on a pendrive and after a clean install I just copy them to the target machine and voila! Everything is working...
My 0,02 cents...
crashnburn
Re: Freeware
#37 Post by crashnburn » Wed Oct 06, 2010 7:03 am
Tasu - Which PORTING portable app are you using.. ? Are your using U3 or any Launcher? e.g. PStart
Tasurinchi
Re: Freeware
#38 Post by Tasurinchi » Wed Oct 06, 2010 8:13 am
crashnburn wrote:Tasu - Which PORTING portable app are you using.. ? Are your using U3 or any Launcher? e.g. PStart
Actually I don't use any launcher. I have an usb stick with a backup of all the portable software and the standard launcher from http://portableapps.com/.
Normally I will copy the folders with the software I need in my target desktop/TP and then use Rocketdock as launcher, but I have to configure it locally and add all the applications I want/need manually.
The best would be to have Portable Rocketdock :wink:
jdrou
Re: Freeware
#39 Post by jdrou » Thu Oct 07, 2010 1:00 pm
Few that I don't think have been mentioned yet:
IZArc - free but not opensource; handles a few formats that 7-Zip doesn't (I use 7-Zip as my primary though)
DeepBurner - CD/DVD burner
CygWin - run GNU/linux software on Windows; I mainly use the command-line text utilities and cdrtools (the real ones, not from the CygWin distribution)
Virtual Floppy Drive (http://chitchat.at.infoseek.co.jp/vmware/vfd.html#top )
TightVNC
CopSSH - CygWin-based OpenSSH package
ISO creator and patch creator from http://www.lucersoft.com/freeware.php
Current Thinkpads:
A31
Re: Freeware
#40 Post by A31 » Mon Oct 11, 2010 11:52 am
Tasurinchi wrote:The best would be to have Portable Rocketdock
LOVE RocketDock!
I don't know where I'd be without my dock!!
Also discovered nLite and vLite, for modifying the Windows installation disc, making a 'modded' version of the XP Pro w/SP1 disc at the moment on nLite, with SP3 slipstreamed, and the language options etc already set to the United Kingdom for me!
Return to “Off-Topic Stuff”
Users browsing this forum: axur-delmeria and 5 guests
