Confirmed that I was able to flash 2.25 over 2.27 using the Windows util, and somewhere it is mentioned that there's a switch for the command-line util to force a flash over a newer version.garnet wrote:Can anyone confirm that there is no problem if your current BIOS version is newer than the cracked BIOS version.
Will it let you flash to a older version?
Of course I did get a BSOD recently, but lets hope that it's unrelated... otherwise the laptop has been working great with 300Mbps connections mostly.
