T61 and WiMAX
Megavvolt
Re: T61 and WiMAX
#31 Post by Megavvolt » Wed Feb 29, 2012 9:05 am
Thanks guys! You're the best! I've been reading the forum for several months now and basically I didn't need to ask any questions till now because all answers are already there!
But now that I've started asking questions that aren't there they are answered at the speed of google search. This is very cool, thank you!
So the docking connector it is!
But what if I need to use a dock some day (I don't own a dock right now) - will this setup hurt the dock or the card that will be getting the the USB lines from the docking connector? Should I still add a switch to toggle these USB lines between the docking connector and the LAN slot?
I'd rather not cut any holes in my T61 for that switch, but if that's the only way...
Wisest1
Re: T61 and WiMAX
#32 Post by Wisest1 » Thu Mar 22, 2012 3:50 pm
Regarding those questions about what is the difference, if any, between the 622AGXHRU and 622ANXHMW versions of the Intel Centrino 6250 Advanced-N with WiMax, There is ALWAYS a difference however subtle it may be (these guys don't just sit around thinking up model numbers just to pass the time). In this case the 622AGXHRU is for sale and use in Russia only (hence the RU at the end). Does that mean it can only be used in Russia? I doubt it but I can't vouch for its usability outside Russia either. If you're feeling lucky then try it and post back... or if you're planning a stay in Russia then it's a good bet.
Hope that helps and let me know
http://download.intel.com/support/wirel ... brief1.pdf
Users browsing this forum: iModFrenzy and 10 guests
