What's the maximum RAM I can put in my X31?
Re: What's the maximum RAM I can put in my X31?
Well besides those low-latency Patriot modules I've run my X31 with Crucial and Hynix PC2700 and Kingston, OCZ, and no-name PC3200 modules without problems.
The only case I know of where modules are 'too fast' is with the Kingston HyperX PC2-6400 modules where many laptops apparently can't run with the extremely low latencies set in their SPD (400MHz at 4-4-4-12 or 333MHz at 3-4-4-10).
Also if you buy from a vendor using their 'configurator' I believe they will usually guarantee compatibility. Crucial and Coast-to-Coast Memory (18004memory) have these for example.
Current Thinkpads:
ParatoOptimal
Well, the 1GB PC2700 I bought on ebay arrived. I have to check what it was SUPPOSED to be. What arrived was Centon brand.
RAM slot 1 WAS empty.
RAM slot 2 has 256MB generic RAM.
Booted OK with no probs of conflicting RAM speeds.
DL'd GParted and tested the new 1GB. It seems fine.
I didn't see a choice to test the 256MB stick.
I installed W7 via my X3 Ultrabay. All seems well. The trackpoint works. I hear appropriate beeps when starting-up/shutting-down but otherwise there's no sound in the X31 or X3.
Device Manager shows a multimedia device and two other devices need drivers.
I have a Linksys 802.11b PCMCIA card and an 802.11n draft dongle.
Would you recommend using one of those or should I get an IBM, internal wireless card?
770E (relic not in use
3000 N100 T2080 1.73GHz
R61 773-1GU
T41 2373 7FU Pentium-M 1.6GHz Banias
X31 2672 XXM Pentium-M 1.3GHz
X60s 1702-68U L2400 1.66GHz Core Duo
Compaq Portable (suitcase size, gone)
Mac Portable (first laptop in world, Stored
Mac Laptop (Stored
Toshiba Tecra (Stored
R61 773-1GU
Mac Laptop (Stored
HuhParatoOptimal wrote:DL'd GParted and tested the new 1GB. It seems fine.
The Gparted bootable live CD includes Memtest if I recall correctly.
Oh! I thought it might, but didn't check to see.
I suggest DO NOT USE "Genuine power adapter bought on Ebay"...I lost T43 and (just 2 weeks ago) X31 - blown by this chinese fake rubbish. I do not believe any of them (sold on Ebay) are genuine...I will never ever buy any power adapter on Ebay again...
I did not know any X31 was made without wireless. I thought X30 was the last model that could be ordered without it. Does your X31 have the antennas, but no card?ParatoOptimal wrote:I have a Linksys 802.11b PCMCIA card and an 802.11n draft dongle.
There is a good chance that the dongle will outperform the PC card and the internal card. But you might value the convenience of internal wireless over slightly better performance. If your X31 already has antennas, just an empty slot, then it would be so cheap and easy to find a wireless card and install it.
ParatoOptimal
My X31 came from the factory as wireless upgradable. It has the antenna wrapped around the LCD but no internal card.automobus wrote:
I've been using an 802.11n dongle I got for $11. It's about 3" long. The X31 has only one USB port. So, I use a hub for the 802.11n dongle and a micro BT dongle for my mouse. It would be convenient to have them both inside the computer. BT cards on ebay are about $15. A few include the antenna. Wireless cards are about $10. I think it's strange that BT cards cost more than an 802.11b/g card.
R61 773-1GU
Mac Laptop (Stored
R61 773-1GU
Mac Laptop (Stored
ParatoOptimal
Can my X31 use ECC, Registered RAM or does it have to be NON-ECC and UN-Registered?
R61 773-1GU
Mac Laptop (Stored
R61 773-1GU
Mac Laptop (Stored
Non-ECC only.
You sure about that? Is one broken? Because there should be two.ParatoOptimal wrote:The X31 has only one USB port.
ParatoOptimal
Holy S, Batman. You're right! HA, ha! I completely overlooked the one at the back.automobus wrote: You sure about that? Is one broken? Because there should be two.
Now I'm even more mobile, sleek and slick with a three inch dongle on the side that matches the case perfectly.
The right rear corner isn't secure to the case. It allows for a little movement. Is there a tab I can connect or that maybe broken?
R61 773-1GU
Mac Laptop (Stored
R61 773-1GU
Mac Laptop (Stored
In case anyone is interested I have found a source for those CAS 2 PC2700 modules I mentioned earlier: http://www.memory4less.com/m4l_itemdeta ... d=27129445 . I don't think anyone else besides Patriot made modules at that speed.
At $113 they're around 3x the price of the more common CAS 2.5 modules so probably not worth it for most people.
EDIT: Apparently they don't actually have them any more.
Current Thinkpads:
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 2061 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
How can I find out if I can run Win10 or Win 7 on this T60?
by Muse » Sat Jan 07, 2017 10:29 am » in ThinkPad T6x Series - 15 Replies
- 2241 Views
Last post by sebileis2017
Thu Mar 09, 2017 11:24 am
IBM x31 new parts?
by kon10 » Mon Feb 13, 2017 1:48 pm » in ThinkPad X2/X3/X4x Series incl. X41 Tablet - 1 Replies
- 342 Views
Mon Feb 13, 2017 2:07 pm
Low voltage v Normal RAM (Mixing?)
by blink » Thu Dec 29, 2016 8:17 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 1619 Views
Last post by Kasm279
Fri Dec 30, 2016 11:39 am
