X61s AC LED ON but no boot at all
fasteez
#1 Post by fasteez » Thu Jul 15, 2010 3:08 pm
I can't witness any activity except the ac led is on when plugged on charger. No fan spinning, no heat, no other blinking lights etc. I swapped keyboards just in case: no luck. (I dont have a laptop base). Using other batteries doesnt change anything (except for the battery led to get on)
I saw some brown fluid (coffee.. coke, I didnt taste ^_^) traces under the keyboard so it's a probable cause. The semi transparent plastic sheet over the mobo seems glued .. and i don't know if it's on purpose or if it's spillage under the plastic.
I didnt see any burns or blown things .. so I wonder, if the mobo was dead from spillage, would there be active leds ? ahh hope.
Cheers
X60s 1702-YAB `L2400 | T61 7659-12U `T7300
X32 2672-KJG `750 | X31 2672-CBG `705 |X41 | X41t 1867-A44 `758
[fs] x61s 3GB, 100GB, Batt+AC ... dead mobo & lcd
[sold] x60 T2400 1Gb wlan|eth
fasteez
Re: X61s AC LED ON but no boot at all
#2 Post by fasteez » Thu Jul 15, 2010 4:04 pm
with both battery and adapter plugged; the battery led blinks; I guess it means it's charging the cells. This might be the fanciest battery charger ever \o/
strange thing I noticed while disassembling, no leds are on if I disconnect the lcd cable (does it means no boot without lcd ? which is smashed btw.)
I might try to wash the mobo with isopropyl as a last attempt before saling it for parts.
Users browsing this forum: Dekks, tfa and 2 guests
