Operating System not found?
Re: Operating System not found?
Are you sure that your CD reader is working at all?
Do you have a different hard drive with an OS already installed on it to see if it boots?
DKB
Nope, all I know is that is will play movies, music, and install software.
Acer Aspire One, IBM ThinkPad T40
You are going to hate Vista on a T40. That is a bad choice for that machine and it will be slow ...
Oh, is there a way to get Ubuntu 10.04 original disk, because I think the ThinkPad is having problems with burnt disks.
emeraldgirl08
When you create a burnt disc are you setting the write speed to x2 or x4??? If you burn it at x16 or "Max Speed" it may create the disc but with errors!
YES! But, I don't know if they send you a pressed disk, or a burned disk, as I've never ordered one.cookie wrote:Oh, is there a way to get Ubuntu 10.04 original disk, because I think the ThinkPad is having problems with burnt disks.
Thanks for everyones help!
I just brought the ThinkPad to a laptop repair place, and the guy has a recovery disk for thinkpads, and he is going to put an OS on it, and antivirus for me, and it only cost $60!
T450 - Brightness control hotkeys not working after system wake
by Czechnology » Tue Jan 10, 2017 9:05 am » in ThinkPad T430/T530 and later Series - 0 Replies
- 415 Views
Last post by Czechnology
Camera LED does not work? Make sure it's not taped over. :)
by dr_st » Sat Feb 18, 2017 12:00 pm » in ThinkPad X200/201/220 and X300/301 Series - 0 Replies
- 800 Views
- 3 Replies
- 402 Views
Mon Jan 30, 2017 4:08 pm
FOUND: Docking station for the T410
by Whitieiii » Sun Jan 22, 2017 7:23 am » in Marketplace - Forum Members only - 1 Replies
- 228 Views
Last post by Whitieiii
Sun Jan 22, 2017 5:15 pm
