SATA-II BIOS patch for T61/T61p and X61/X61s (X61t coming)
redleaderone
Re: SATA-II BIOS patch for T61/T61p and X61/X61s (X61t coming)
Is there a chance we will ever see SATA-II on a regular T60?
Is it a hardware difference between the T60 and T61, where T61 has the capability (but wasn't enabled in the BIOS) but T60 does not have the ability at all?
donzoomik
I read through entire thread at Notebookreview and i didn't find any exact information about whitelist. I saw a few references to WWAN whitelist being disabled but is WLAN whitelist also disabled? I'd like to upgrade my 4965AG to 5100AGN - the generic versions are dirt cheap.
Lenovo Thinkpad X200 7458-85G
Does anyone know if the fix also applies to the 2nd HDD bay? Thanks.
Turboqueef
I am also very interested in the answer to this question..redleaderone wrote:Is there a chance we will ever see SATA-II on a regular T60?
Thank you
Jeff B
W510 4318-CTO i7 720QM, Win7 64, SSD, Passmark Rating: 1338 & 1398 (OC graphics)
SOLD>>>T60p 2623-DDU, T7600, Win7 64, SSD, Passmark Rating: 835.5
05 STi 11.44 @ 123.6
I got the answer from the other forum. Apparently the ultrabay is uses a PATA controller so no love for the 2nd HDD bay.geohsia wrote:Does anyone know if the fix also applies to the 2nd HDD bay? Thanks.
crashnburn
Im glad I went for the T61 SXGA+
Worked for my T61 as well. Got a Vertex 60gb. Does this mean I already broke the SATA I speeds?
Sorry, never tested my SSD on SATA I as I already flashed mine with this bios.
CrystalDiskMark 3.0 x64 (C) 2007-2010 hiyohiyo
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
Sequential Read : 215.964 MB/s
Sequential Write : 106.336 MB/s
Random Read 512KB : 161.293 MB/s
Random Write 512KB : 96.723 MB/s
Random Read 4KB (QD=1) : 0.000 MB/s [ 0.0 IOPS]
Random Write 4KB (QD=1) : 0.000 MB/s [ 0.0 IOPS]
Random Read 4KB (QD=32) : 0.000 MB/s [ 0.0 IOPS]
Random Write 4KB (QD=32) : 0.000 MB/s [ 0.0 IOPS]
Test : 500 MB [C: 15.5% (7.6/48.7 GB)] (x5)
Date : 2010/08/14 4:27:32
OS : Windows 7 [6.1 Build 7600] (x64)
And me too I'd love to know this! I've just bought a 2nd hand OCZ Vertex SSD boy is this fast!redleaderone wrote:Is there a chance we will ever see SATA-II on a regular T60?
Maybe it's not possible since the T60 uses the 945 chipset rather than the 965 of the T61...
T60p 15" UXGA
X61t 1.8Ghz SXGA+ AIFF
ThinkPadophile
I'd also like to see this for the T60 line. The 945 chipset supports SATA-II.
T60p UXGA Flexview T7200 3 GB RAM 128GB Samsung SSD Windows 7 Ultimate 64-bit
jketzetera
Only the desktop chipset supports it and not the notebook chipset.
ok... is this the final word on it then?jketzetera wrote:Only the desktop chipset supports it and not the notebook chipset.
T60p 15" UXGA
I see there's an earlier thread here on the forum that's still active:
http://forum.thinkpads.com/viewtopic.php?f=27&t=84953
To reiterate my question there (in case a mod doesn't merge these): Considering this contains the whitelist hack, isn't this preferable to one of Zender's modded BIOS files?
- T61 - 6465CTO - T9500 - 15.4" LG WSXGA+ - 8GB OCZ- 120GB EVO 850 SSD - X3100 - Win 8.1 Pro 64-bit
Zender's BIOS mods are only for bypassing the whitelists, nothing else.
Several of Zender's BIOSes are outdated by now, due to newer IBM/Lenovo BIOS versions, and Zender no longer being active.
Middleton's BIOS does the same, but has added support for SATA-II and can also bypass the thermal sensing check at POST.
I have successfully applied M's BIOS to my daughter's T61 (8897-03U).
The whitelists bypassed (by both Zender and Middleton) concern the errors for WLAN/WWAN/WiFi:
1802 Unauthorized network card is plugged in. Power off and remove the Mini PCI network card.
1804 Unauthorized WAN card is plugged in. Power off and remove the WAN card.
1805 Unauthorized Wireless USB card is plugged in—Power off and remove the Wireless USB card.
Hi, so which bios do you recommend? I've just recently bought a mint X61T and it would be nice to unlock the sata II in the event i should find an affordable SSD.
T60p 15" UXGA
For the X61t: Middleton's BIOS.
Read my previous post again! A Zender BIOS is ONLY good for whitelist bypasses.
So it does work for the tablet version too, great. Thanks!
T60p 15" UXGA
Middleton BIOS: http://forum.notebookreview.com/lenovo- ... ost6501443
Kamika007z
Yes it supports the tablet, that's what the t in x61t stands for.
Also, middleton's BIOS is now recommended over Zender's BIOS.
Finally, I had asked middleton to update the BIOSes to Lenovo's latest revision 2.29 and he was gracious enough to do so, but the table on pg 8 hasn't been updated yet. You can find it on page 56 if I am not mistaken (its somewhere around those pages I forget exactly where).
Hope this helps!
Hope this helps!
T61p [8891-CTO]: Intel X9000 (2.8GHz) CPU, 8GB RAM, 128GB OCZ Vertex 2 SSD, 14.1in 1400x1050 (4:3) Modified Symmetrical LCD cover & bezel, nVidia FX 570M, DVDRW, Intel 6300 WiFi, BT, FR, Windows 7, SLIC2.1, Unlocked SATA II middleton BIOS, WLAN Whitelist Modified. Mint Condition.
sure does, great info! thanks!
T60p 15" UXGA
Is there a Middleton BIOS which does not alter the thermal sensing monitor alerts, but enables only the SATA II functionality.
Have a T61 with a motherboard which supports Penryn natively, not sure if applying this BIOS would disable that even on a board which is supported ?
Why don't you ask Middleton?
RealBlackStuff already asked him, waiting for a response on the other forum. Was trying to see if someone here has already come across it or in a similar boat.
I take it the x61 sxga+ bios is only for those of us brave enough to change the screen?
On a different note - I updated to lenovo's latest bios on Friday and have noticed the fan being considerably more quiet.
X61 7674
Intel 320 80GB
4GB RAM
Middleton Bios
Win 7 x64 Ultimate
RMClock
TPFanControl
X6 Ultrabase
Ultrabase HD Caddy
Ultrabase DVDRAM
Intel 320 80GB
4GB RAM
Middleton Bios
Win 7 x64 Ultimate
RMClock
TPFanControl
X6 Ultrabase
Ultrabase HD Caddy
Ultrabase DVDRAM
I used modded bios to X61. SLIC 2.1 now works. Regarding the SATA speed difference is not noticed in the file copying 700MB from partition D: to E: on WinXP x64. File copies of the same speed on the old and new BIOS. Truthfully I think it is even slower.
I run test hdparm -tT after new BIOS flash but have different results depending on the operating system:
HDPARM TOOL FOR WINDOWS
Please check SATA Generation version with Intel Matrix Storage Console on ThinkPad's which have old BIOS. After upgrade BIOS Intel Console display SATA Generation 2:
old BIOS, SATA I - copy movie 699MB from D to E - 45 sec
new BIOS, SATA II - copy movie 699MB from D to E - 48 secCode: Select all
hdparm for Windows x64
/dev/hda:
Timing cached reads: 430 MB in 2.00 seconds = 215.00 MB/sec
Timing buffered disk reads: 258 MB in 3.02 seconds = 85.54 MB/sec
hdparm for Debian 6.0.5 x86
/dev/sda:
Timing cached reads: 3156 MB in 1.99 seconds = 1582.96 MB/sec
Timing buffered disk reads: 250 MB in 3.01 seconds = 83.15 MB/secPlease check SATA Generation version with Intel Matrix Storage Console on ThinkPad's which have old BIOS. After upgrade BIOS Intel Console display SATA Generation 2:
Please tell where to find the modified BIOS. thanks.
Intel ME exploit patch for xx30 systems is being rolled out
by n4ru » Mon May 22, 2017 10:19 am » in ThinkPad T430/T530 and later Series - 0 Replies
- 128 Views
Last post by n4ru
- 2 Replies
- 906 Views
Last post by J Walker
Tue Mar 21, 2017 10:18 am
At which series level did this t series start coming with W7 Restore Discs?
by fefrie » Fri Apr 21, 2017 10:35 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 696 Views
Last post by w0qj
Sat Apr 22, 2017 5:18 am
*SOLD* T420s ... [but more goodies coming soon! read on for details]
by tpdude4 » Sun Jun 25, 2017 6:10 am » in Marketplace - Forum Members only - 1 Replies
- 125 Views
Last post by tpdude4
Tue Jun 27, 2017 10:09 pm
