T60/T61 FlexView FrankenPad Questions
ajuztam
Re: T60/T61 FlexView FrankenPad Questions
#31 Post by ajuztam » Tue May 03, 2011 10:11 am
Hi. Will 14.1" mobo non 4:3 work for this swap or its only 4:3 t61 mobo that fits?
T42 14" SXGA+ / T43 15" UXGA (IDTech) / T60P 15" UXGA (BOE Hydis) / T61 14.1" WXGA+ /
Johan
Moderator1
Moderator1
#32 Post by Johan » Tue May 03, 2011 2:06 pm
ajuztam wrote:Will 14.1" mobo non 4:3 work for this swap or its only 4:3 t61 mobo that fits?
A widescreen T6x motherboard will not fit into a 4:3 (non-widescreen) T6x/p chassis. If you want to build a FlexView ThinkPad with a T61 motherboard in a T60/p base, you will need a 4:3 T61 motherboard.
You will find more information about this issue in e.g the thread Parts for the ultimate 15” T60 UXGA FlexView w/T61(p) mobo?
Johan
brchan
#33 Post by brchan » Wed Jan 20, 2016 8:30 am
ajuztam wrote:Hi. Will 14.1" mobo non 4:3 work for this swap or its only 4:3 t61 mobo that fits?
Not without extensive cutting of the magnesium frame. You also lose the ultrabay, but some people have done it so they could have the FX570m with 512mb ram instead of 256 on the 4:3 boards. I still would not recommend this since it make the chassis weak.
#34 Post by ajkula66 » Wed Jan 20, 2016 10:18 am
brchan wrote: You also lose the ultrabay, but some people have done it so they could have the FX570m with 512mb ram instead of 256 on the 4:3 boards.
It's actually 256MB VRAM vs. 128MB VRAM.
If the machine will remain stationary at all times, it *might* be worth looking into. Here's one such - heavily customized in other respects as well - system for sale: http://forum.thinkpads.com/viewtopic.php?f=11&t=119700
#35 Post by RealBlackStuff » Wed Jan 20, 2016 10:44 am
@brchan:
next time, please look at the DATE of the post(s) you want to answer to. You replied to a post from Tue May 03, 2011 11:11 am
brchan
#36 Post by brchan » Wed Jan 20, 2016 10:57 am
My mistake. For some reason, the topic appeared in the 'new posts' section.
