Panasonic vs. Sanyo batteries
Raceboy
Re: Panasonic vs. Sanyo batteries
#31 Post by Raceboy » Wed Feb 02, 2011 2:49 pm
RistoE wrote:I have a chinese T60 battery with panasonic cells. Design capacity is 48.8 Wh but after almost 1 year use the battery full capacity has been slowly raising above the nominal capacity. Currently its shows capacity of 53.1 Wh. It is the highest I've seen so far. The battery was cheap but it was promised to be with japanese cells. I'm pretty happy.
Care to share ths source for the battery?
X61s:L7500,4GB,128GB SSD,IPS
RistoE
#32 Post by RistoE » Thu Feb 03, 2011 12:17 pm
Raceboy wrote:Care to share ths source for the battery?
For sure. Ebay: http://myworld.ebay.com/cmppower168
But seems he is inactive nowadays?
Edit: I think this is the manufacturer of the battery: http://www.cmp-laptopbattery.com/index.asp
There you can find a seller in ebay: http://myworld.ebay.co.uk/cmpbattery but notihing listed right now. Maybe because of Chinese Lunar New Year Holiday (Feb 1st, 2011 to Feb 7th).
600E (P3-850Mhz), 3*T60 (3*T7200), T400 (8600Mhz/8GB/SSD120GB), T420 (4180-CA3 with Samsung 850 mSATA 250GB)
Raceboy
#33 Post by Raceboy » Fri Feb 04, 2011 2:20 am
Muse
#34 Post by Muse » Fri Feb 04, 2011 7:59 am
lstratos wrote:Yeah all my sanyo degrades a lot faster.. i'm still using 2 panasonic battery thats over 3 years old and holds around 95-97% of the charge.. they're awesome
Last I heard, Panasonic is a M a t s u s h i t a brand (one of many), and therefore a high end product in terms of reliability.
How can you tell which you have?
My strategy is to use my batteries lightly and generally keep them refrigerated with 40-50% charge, and run on AC.
Tommy the cat
#35 Post by Tommy the cat » Wed Feb 09, 2011 5:24 pm
What's your own experience with respect to the capacity. If these indications are right, that must mean that your battery delivers the same or more working time as when you just bought it.
I ask this because it may be that the indicator is inaccurate.
Jules Tohpipi
#36 Post by Jules Tohpipi » Sun Feb 13, 2011 6:19 pm
I have a T60 with the 15 inch flexview screen (2007-FSG). Can anyone post the FRUs for the Panasonic batteries for the T60 please?
BTW, I also have a T41. Thanks to this site, I became aware of how much better the Panasonic batteries are. Bought one to replace the Sanyo and it has continued to perform flawlessly. Would very much like to buy a Panasonic for my T60 too, but am struggling to discover the correct FRU numbers.
#37 Post by dr_st » Mon Feb 14, 2011 5:04 am
6-cell:
Sanyo 42T5246
Panasonic 92P1139
Sony 92P1141
9-cell:
Sanyo 42T5245
Panasonic 92P1133
These are from the HMM. There may be newer FRUs out there.
Jules Tohpipi
#38 Post by Jules Tohpipi » Mon Feb 14, 2011 8:41 am
Thank you very much for the FRU numbers above.
RistoE
#39 Post by RistoE » Mon Feb 14, 2011 3:02 pm
Tommy the cat wrote:What's your own experience with respect to the capacity. If these indications are right, that must mean that your battery delivers the same or more working time as when you just bought it. I ask this because it may be that the indicator is inaccurate.
I'd say my battery is still as good as new. :mrgreen:
Unknown_K
#40 Post by Unknown_K » Mon Feb 14, 2011 3:08 pm
Have you ever run the battery down to 1%? Some batteries seem to be fine untill you get to 20% or so and then they shutt off (calibration is off).
Collection: 310ED, 350C, 360C, 365C, 365XD, 380D, 380XD, 380Z, 390E, 390X, 560X, 600, 600E, 701C, 750CS, 755C, 755CD, 760C, 760CD, 760ED, 760EL, 760XD, 760XL, 765L, 765D, 770, 770E, 770Z, T21, T22, T23, T30, A20P, A21P, A22M, A30, A31, A31P, T40, T42, T43P, T60, T61, R32, R40, R52
RistoE
#41 Post by RistoE » Tue Feb 15, 2011 2:52 pm
Unknown_K wrote:Have you ever run the battery down to 1%? Some batteries seem to be fine untill you get to 20% or so and then they shutt off (calibration is off).
This battery does not shut off before it is empty. However I usually do something when there is just 5 minutes or so left. I have also 2 very cheap chinese T30 battery and I've seen that these age quite rapidly. I also have old 600E which charges full with orginal battery but actually there is power for just 5-10 minutes. My work laptop is also T60 and orginal battery I had was quite bad, it drained empty as you described but not at 20% but something like 50%. So I've seen a few batteries.
Garth
#42 Post by Garth » Sat Feb 26, 2011 9:49 am
I bought my T60p just a couple of months ago as an ex-business laptop in very good condition. It has a Panasonic 9-cell battery FRU 42T4620 branded Lenovo which was manufactured in 2009 and has currently done some 231 cycles. It still has a full charge capacity of 74.37 Wh and lasts for ages: 4-5 hours on average. It's currently showing 3hrs 54mins battery life left as I write this and it has already been in use for about 90 minutes since last charged. I have it set to the Power Scheme "maximum battery life" but wind up the screen brightness when needed, and the hard disc is actively used. The hard disc is a WD Scorpio Black 7200 rpm (also recommended).
If or when this packs up I will definitely replace it with another Panasonic. In fact I think the T60p is an excellent laptop, and this comes from a Thinkpad user of around 6 years.
(1) T420 i7, 8 Gb RAM, 128 Gb SSD, 500 Gb HD in Ultrabay, 1600x900, Win 10 Pro 64-bit
(2) T60p 2.16 GHz, 4 Gb RAM, 256 Gb SSD, 500 Gb HD in Ultrabay, 14" 1400x1050, Win 7 32-bit/XP dualboot
(3) T22 900mHz, 512 Mb RAM, 320 Gb HD, Win XP
(4) 600E 400mHz, 512 Mb RAM, 12 Gb HD, Win XP
#43 Post by dr_st » Sat Feb 26, 2011 12:06 pm
Garth wrote:If or when this packs up I will definitely replace it with another Panasonic.
Assuming you can find one. There is no guarantee Lenovo will continue to buy old batteries from Panasonic (try sourcing a new T4x Panasonic battery now, for example).
scillyisles
#44 Post by scillyisles » Mon Feb 28, 2011 10:26 am
dr_st wrote:Assuming you can find one. There is no guarantee Lenovo will continue to buy old batteries from Panasonic (try sourcing a new T4x Panasonic battery now, for example).
I am just going through this whole process - as my signature line shows I have quite a few Thinkpads in use. In addition I recently got a new W510 4319.
I have quite a few batteries and all the rubbish ones are Sanyo (and one Sony) the Panasonic ones seem to keep going. e.g. the one I am currently using in my T61p is a Panasonic which at 3 years old still keeps 77.90Wh of its 84.2Wh design capacity.
I have therefore been tracking down new Panasonic batteries and in my case have managed to find Panasonic batteries for my T42p and T61p from IBM Part Sales UK. (They also seem to be available from IBM Germany too) You need to order by the specific FRN Part number which is different for Panasonic batteries.
2373-Q1U T42p 2.1Ghz P4M 2GB RAM, ATI Firegl , 320Gb,15" LCD,Win 7 Ult
6457-BQG T61p 2.6GHz C2 Duo 4GB RAM, 320GB 15.4in LCD,FX 570M, Win 7 Ult
2758 W700 QX9300 2.53GHz 4GB ram, 200GBx2 BDWriter, 1GB FX3700m,17" Win 7 Pro
4319-4NG W510 i7820QM,8GB,320gb,15.6 FHD,FX880M,Win 7 Pro
#45 Post by dr_st » Mon Feb 28, 2011 11:01 am
Interesting. :)
Which FRUs did you order to get Panasonic T4x/T6x batteries? Which FRUs are shown in the power manager? What is the manufacturing date of each?
scillyisles
#46 Post by scillyisles » Mon Feb 28, 2011 11:14 am
The FRU for the T61p 9 cell Panasonic battery is 92P1133 which shows up as available on the IBM web parts system on 4 week delivery. It does not give the manufacture date but would obviously be covered by the 12 month IBM warranty.
The FRU for the T42P one is more difficult to determine as the HW Maintenance manual is less explicit. The one I have ordered is 92P1069 which is listed on the HW Maintenance Manual as a 9 cell Panasonic battery again available in 4 weeks. As per the T61p battery, the IBM parts site does not give a manufacture date.
IBM have today confirmed the order so I will let you know the manufacture date once they arrive.
Another side benefit of ordering from IBM seems to be that they are 30 - 40% cheaper than from Lenovo.
Garth
#47 Post by Garth » Tue Mar 01, 2011 5:11 am
As I stated in an earlier post, the 9-cell Panasonic fitted to my T60p is FRU 42T4620. Also marked ASM P/N 92P1134. Manufactured for Lenovo - Cell made in Japan, pack assembled in China. 10.8V 7.8AH 85WH.
Jules Tohpipi
#48 Post by Jules Tohpipi » Thu Mar 03, 2011 4:01 pm
Thanks to the help and advice on this thread, I've just bought and received the Panasonic 9-cell battery from eBay (92P1133). It was listed as being off a faulty ThinkPad, and hence untested and sold as seen. So it was a bit of a gamble.
After installing, my T60 reported it as being 3 years old with around 90% of its capacity remaining. Over the past week it has performed amazingly well giving me loooooooong operating times.
The twist to the story is that I got it for £16. Happy days!
J888www
#49 Post by J888www » Sun Mar 06, 2011 10:52 am
Watch Grand Seiko : Gas Lighter Dupont : Pen Mont Blanc : Car Ferrari (but can't afford ATM) ........................... : Batteries Panasonic : .............(please do not request me to elaborate, it would take far toooooo long).
Simply out...... it'is just me.
I also collect LED Flashlights and I only use AW LiIon Batteries (Panasonic).
Often outspoken, please forgive any cause for offense.
Thank you all for reading.
T60p 2008HA8:T7600: Samsung840EVO 250GB:4GB RAM:Wins8.1 Pro+MC.
T60p 2007WUK:T7600: Samsung840EVO 250GB:4GB RAM:Wins7 Ult.
X1 Carbon:Core i7-3667U: 240GB SSD SATA III: 8GB RAM: Wins8.1 Pro
scillyisles
#50 Post by scillyisles » Fri Apr 01, 2011 9:16 am
Well the batteries from IBM finally arrived - the T61p battery is a Panasonic battery 92P1134 (42T4620 ) :D and the battery for the T42p is a Sanyo 42T4608 :( . Prices were significantly cheaper than from Lenovo.
#51 Post by dr_st » Fri Apr 01, 2011 2:10 pm
scillyisles wrote:and the battery for the T42p is a Sanyo 42T4608 :(
That's the exact FRU I've been given when I ordered my T4x battery from IBM last year. Seems to reinforce my earlier guess that the only T4x batteries still actively made are by Sanyo. :(
madflava54
#52 Post by madflava54 » Fri Apr 01, 2011 9:41 pm
scillyisles wrote:Well the batteries from IBM finally arrived - the T61p battery is a Panasonic battery 92P1134 (42T4620 ) :D and the battery for the T42p is a Sanyo 42T4608 :( . Prices were significantly cheaper than from Lenovo.
Did you order from the Outlet? I'm shocked the ran out. I was saving up slowly to dish out $50 and they went from like 291 in quantity to 0 in a matter of days :(
T61p 14'' SXGA+//T9300//3gb of ram//nVidia Quadro FX 570M 128mb//ocz vertex II 60gb
ssd_thinkpad
#53 Post by ssd_thinkpad » Sat Apr 02, 2011 4:45 am
madflava54 wrote:Did you order from the Outlet? I'm shocked the ran out. I was saving up slowly to dish out $50 and they went from like 291 in quantity to 0 in a matter of days :(
Yes, some companies might have bought a hundred as a spare.
scillyisles
#54 Post by scillyisles » Mon Apr 04, 2011 4:19 am
I ordered them from IBM UK parts - you can check the parts situation on-line on their parts system. The T61p 9 cell is listed with the suffix PNS which means made by Panasonic but the T42p one is just listed as normal without the PNS suffix. I guess this means Sanyo :( . Interestingly, the Sanyon battery is showing a capacity well over the design capacity but the Pansonic one is showing a capacity more or less spot on the design capacity. From experience, the Sanyo will probably be long gone whilst the Panasonic will go on.
