Short status, bezel arrived some days ago and now it's installed. My X60 looks like almost new now!
I also have an Atheros wireless card AR5XB6 around that I bought for one of my T6s, will it be cooler than the Intel PRO 3945ABG installed in my X60? Is it worth swapping it?
Became an X60 owner! Yuhuuuu!!! *PICS*
Tasurinchi
Re: Became an X60 owner! Yuhuuuu!!! *PICS*
sir_synthsalot
My guess is that the foam is there for shock protection.tcone wrote:I assume the foam is for better airflow in the X61/s with second fan. You can leave it on the bezel.
I'M DONE WITH THINKPADS, JUST DONE!!!
It will not be cooler. However, if you have "range" problems with the Intel 3945, as some people do, then you should know that the Atheros card (or any card, including any of Intel's other cards!) will behave much better in that regard than the 3945.Tasurinchi wrote:I also have an Atheros wireless card AR5XB6 around that I bought for one of my T6s, will it be cooler than the Intel PRO 3945ABG installed in my X60? Is it worth swapping it?
Tasurinchi
Thanks EOMtp, I don't have range problems, the router is not sitting far away and I get an excellent signal from every corner of my house. I will probably swap the Atheros with the IBM card sitting on my T60.
- 3 Replies
- 1312 Views
Tue Feb 21, 2017 12:50 pm
- 1943 Views
Last post by Puppy
Sun Jan 22, 2017 5:48 am
- 13 Replies
- 1819 Views
Last post by cadillacmike68
Sun Feb 19, 2017 9:45 pm
- 5 Replies
- 1002 Views
Mon Feb 13, 2017 7:27 am
