Need a new laptop to replace my T42 - ideas?
manlymatt83
Re: Need a new laptop to replace my T42 - ideas?
#31 Post by manlymatt83 » Wed Oct 20, 2010 7:59 pm
A few more questions:
1) Those who own the T5xx series. Are you glad you didn't get the T4xx series and have the larger screen size?
2) On the higher resolutions of T500 and T510, is it possible to downsize the resolution? For instance, my old laptop allowed up to 1024x768 but for a while I ran in 800x600. I haven't quite gotten used to the small text yet :)
3) Does the eBay auction listed above for the T500 come with integrated camera?
Colonel O'Neill
#32 Post by Colonel O'Neill » Wed Oct 20, 2010 8:03 pm
By the way, the webcam on the T400/T500 sucks if you have a fluorescent light that is slightly yellow; it somehow whitebalances it to practically pure yellow. The newer ones on the X100e, T410, T510 are much, much, MUCH better.
manlymatt83
#33 Post by manlymatt83 » Wed Oct 20, 2010 8:09 pm
Colonel O'Neill wrote:By the way, the webcam on the T400/T500 sucks if you have a fluorescent light that is slightly yellow; it somehow whitebalances it to practically pure yellow. The newer ones on the X100e, T410, T510 are much, much, MUCH better.
hrmph :) this is tempting me even more to just get the T510.... but it's $1200 versus $500 for that T500 on eBay. Heck, I could get the T500 on eBay, use it until the warranty expires, and probably get a used T510 for $700 at that point :)
LegendaryKA8
#34 Post by LegendaryKA8 » Wed Oct 20, 2010 8:16 pm
I honestly don't think you can go wrong with either system. There are pros and cons to each but those can be only nitpicks. As you said, you don't really game or do CAD work so you probably won't miss the T500's better GPU. I'm assuming the T510 is equipped with integrated graphics; even with an i7 I think it'll get similar battery life to the T500.
The auction I linked to the T500 has a 9-cell battery, but the machine is used... I don't know if the battery is in good or bad condition. I can say my 9-cell T400 switched to the X4500 can get around 5.5 hours on battery, wifi on, light browsing and word processing work only. My battery has about 20% wear, so I'd estimate about 6.5-7.0 hours with my usage profile. The T500 will turn similar numbers on a 9-cell as long as the battery is good(I can't say for certain how good the battery is until I have mine).
Regardless, I think you'll do well with either machine. It's a hard decision, and for what you use a computer for I think it'll boil down to if you want a new machine or one slightly behind the curve. You might also want to wait and save up a few months until the new Intel Sandy Bridge notebooks come out, however they'll be fairly expensive new.
I haven't read any reviews on the T510, but looking at Colonel O'Neil's battery life survey thread seems to indicate the T510 can get alright life out of a 6-cell.
And, the T500 listed in the auction doesn't come with a webcam, unfortunately.
ThinkPads:T21(retired), X200(retired), T500(busted) T400(retiring), T430(upcoming)
Other: Dell Precision M6700(desk hog)
manlymatt83
#35 Post by manlymatt83 » Wed Oct 20, 2010 8:23 pm
LegendaryKA8 wrote:I honestly don't think you can go wrong with either system. There are pros and cons to each but those can be only nitpicks. As you said, you don't really game or do CAD work so you probably won't miss the T500's better GPU. I'm assuming the T510 is equipped with integrated graphics; even with an i7 I think it'll get similar battery life to the T500.
hmmmm, thanks for your info. Coming from a T42, I think it may be best to just grab one of those laptops in the auction. I don't *need* a webcam. But good battery life is indeed important to me.
A few final questions (I hope):
1) Do you know if a T42 9 cell battery will work in the T500?
2) You say the T500 has a better graphics card than the T510 - will that use more battery? I just need basic graphics. I know the laptop I was quoted for the T510 had integrated graphics. What's the difference between integrated and discrete? If getting the T510 will get me a less good graphics card, perhaps that's a good thing :)
3) What about screen? The T510 screen I was quoted was 15.6HD+ANTI-GLW/LEDBKLIGH. Will the screen on the T500 in the eBay auction be much worse? How will it compare to my T42 Active Matrix display?
Thanks! :)
LegendaryKA8
#36 Post by LegendaryKA8 » Wed Oct 20, 2010 8:38 pm
manlymatt83 wrote: A few final questions (I hope):
Thanks! :)
And, not a problem!
1: T4x batteries won't work in the T500. The T500 can take batteries from these ThinkPads: T60, T60p(14", 15" and 15.4" wide), T61(14" standard, 15.4" wide; the T61 14.1" wide isn't compatible), T61p, and W500. Those have 6 and 9-cell variants.
2: The T500 has an ATI HD3650, which is more powerful than either the discrete and integrated cards on the T510. However, the T500 is a switchable system. If you don't need the power, you can switch to the integrated card already onboard(in Vista/Win7 you can get to it from a menu in the Power Manager). and therefore save battery life. Most T510's are not switchable; the feature only came out a couple of weeks ago. You can buy one new from Lenovo if you wanted to.
3: Both the T500 and T510 have regular TN screens. I'd think the T510's LED screen's going to be brighter, but screens on ThinkPads are the luck of the draw either way. I upgraded my T400's screen to an LG LED display not long ago and like it, mainly because the colors are more accurate. The T500 will have the larger resolution, 1680x1050 versus 1600x900 on the T510. In comparison to your T42, it depends on what you have in that one. If you have a 1024x768 screen, it won't be much different. If your T42 is a 1400x1050 or 1600x1200, you have a Flexview display. Those are regarded to be the best panels ever placed in a ThinkPad, and anything else is going to look inferior.
Edit: Please note that the T500 in the auction I linked you to will have WinXP preloaded. The switchable graphics don't work on the fly in XP. You can either go shut the system down and change the BIOS settings every time you want to switch if you want to keep XP, or you can upgrade to Vista or Win7. I'm pretty sure that the T500 will have a Vista license key on it, making an upgrade to Vista free if you want to go that route. When I get mine I'll be doing a fresh install of Win7, anyway.
Colonel O'Neill
#37 Post by Colonel O'Neill » Wed Oct 20, 2010 8:47 pm
I'd say run XP or 7. Skip the whole Vista stuff. :P
As for Flexview... as long as you're not editing photos on a professional level, you don't really need it. Granted, the large viewing angles are nice, but my TN is fine for casual gaming or video watching.
LegendaryKA8 wrote:I haven't read any reviews on the T510, but looking at Colonel O'Neil's battery life survey thread seems to indicate the T510 can get alright life out of a 6-cell.
Slightly off-topic, but that particular T510 machine is doing terribly battery-life wise, hence my motivation to start the thread.
manlymatt83
#38 Post by manlymatt83 » Wed Oct 20, 2010 8:50 pm
LegendaryKA8 wrote:
And, not a problem!
Thanks for your comments. I'm beginning to think I should just stick with my T42 and keep replacing parts as they die, or perhaps get a T6x :) *sigh*
Alright, so if I get the T500 on that eBay auction, I can just disable the higher powered graphics card and won't have any worries, right? I actually will install Ubuntu on it - don't know if Ubuntu supports the switchable graphics. So the discrete graphics are external (better) right? And integrated is the more generic kind?
My T42 screen is 1024x768 active matrix, so nothing special. I do like it a lot :)
manlymatt83
#39 Post by manlymatt83 » Wed Oct 20, 2010 8:53 pm
Colonel O'Neill wrote:I'd say run XP or 7. Skip the whole Vista stuff. :P
So you seem to be well respected here - what would you do: stick with the T42, get a T500 from eBay for $480, or get the new T510 from Lenovo for a heavily discounted $1100?
THINKPAD T510 - 1 YEAR DEPOT
$1,104.15
SBB INCR I7-620M 2.66GHZ,4MBL3
$0.00
VBB GENUWIN7PROFES.64
$0.00
SBB G.WIN.7PROF64US ENGLISH
$0.00
SBB 15.6HD+ANTI-GLW/LEDBKLIGH
$0.00
VBB 4GBPC3-10600DDR3 1333SODMM
$0.00
SBB KEYBOARDUS ENGLISH
$0.00
SBB CAMERA(2.0 MP)
$0.00
SBB 500GB HDISK DRIVE7200RPM
$0.00
SBB MULT.RECORD.OPTDRIVE12.7MM
$0.00
VBB EXPCARSL+5IN1CARREAD
$0.00
SBB 6CELLLI-ION BATTERY
$0.00
SBB COUNTRY PACK NORTH AMERICA
$0.00
SBB INTELCENTRINOWIRELESSN1000
$0.00
SBB INT WRLSSWDAREANTWRK UPGR
$0.00
SBB LANGUAGEPACK US ENGLISH
$0.00
Colonel O'Neill
#40 Post by Colonel O'Neill » Wed Oct 20, 2010 8:59 pm
If I was moving from a T42, I'd probably jump straight to the T510 if my wallet allowed me. It's a very nice machine; I've handled my friends' T510 and it was a beauty. It's more future-proof than a T500, but I'd prefer having the HD3650 over the NVS3100. The T500 for $480 is a really great deal; just replace the drive with a 640GB Scorpio Blue and it'll be ready to go. Maybe another 2GB of stick of RAM. So I'd probably grab the T500.
Actually, I can't find which screen it is.
If it's the 1280x800 I'd definitely go for the T510.
As for a T510 discount, my friend ordered a T510 configured thusly (it's one of the T510's in my battery life survey)
i5-540M
NVS3100M (before Optimus)
Win 7 Pro (32-bit)
2x2GB DIMM RAM
9-cell battery
500GB 7200RPM HDD
Intel 6300 AGN
HD+ screen
For about $1200 after the 13% tax we have up here in Canadia. If you wait for a big discount, you'll save more. Also sometimes a discount will have an unstated price break at $1500, $1600, or $2000. Try configuring things to just be slightly over those values to test this theory. (Once I added an FHD panel to a T510 to only see a $10 increase in the final pre-tax price.)
EDIT: Oh yeah, he got a sleeve in that price too.
LegendaryKA8
#41 Post by LegendaryKA8 » Wed Oct 20, 2010 9:13 pm
The T500 I listed has the 1680x1050 screen. Shocking, considering the price. I've heard they're kinda hard to find.
Colonel O'Neill
#42 Post by Colonel O'Neill » Wed Oct 20, 2010 9:28 pm
Agreed. I'm all for that T500.
#43 Post by pianowizard » Wed Oct 20, 2010 10:26 pm
manlymatt83 wrote:2) On the higher resolutions of T500 and T510, is it possible to downsize the resolution? For instance, my old laptop allowed up to 1024x768 but for a while I ran in 800x600. I haven't quite gotten used to the small text yet
What you typed above is crucial. Things look HUGE on a 15.0" 800x600 screen. And if you find text too small at 1024x768, then I urge you to avoid high-res laptops. Previously, I thought that you might have been used to 1400x1050 Flexview, and so I was concerned that you would find HD+ (1600x900) too short. But since you are fine with 800x600 and prefer everything looking huge, and also don't mind TN screens, I should recommend you to get a 15.0" T60 with 1024x768. Others can correct me if I am wrong, but I believe that on all 16:10 Thinkpads, the lowest 16:10 resolution setting is 1280x800, whereas on all 16:9 Thinkpads, the lowest 16:9 setting is 1366x768. Even at these resolutions, things look much smaller than they do on your T42 at 1024x768. If you drop the res setting below these, you will only get 4:3 resolutions (i.e. 1024x768 and 800x600), which would look TERRIBLE because the screen would be stretched horizontally to fill the display. Sorry, but it sounds to me like you have no choice but stick with old 4:3 laptops, unless you train yourself to tolerate small text and images.
killer wrote:It took me under a minute to adjust from 4:3 to 16:9. In summary, I don't understand the fuss. Change is good if you adapt to it. Stand in its way and it will demolish you.
It depends on what previous resolutions you were used to, and what resolutions you are migrating to. Someone used to 1600x1200 would probably feel very crippled by 1600x900, whereas going from 1400x1050 to 1920x1080 would actually feel like an improvement. Again, I was initially under the impression that the OP's T42 had 1400x1050, and had that been correct, the 1600x900 T510 that the OP was considering would have been kind of hard to adjust to, becquse of the reduction in vertical real estate.
In general, we saw a reduction in vertical space when the industry moved from 16:10 to 16:9. The lowest 16:10 laptop res was 1280x800, and now it is 1366x768. The mid-range 16:10 resolutions used to be 1400x900 and 1680x1050, and now it is 1600x900. The highest 16:10 laptop res was 1920x1200, and now it's limited to 1920x1080. That's why so many of us have a tough time adjusting.
I previously mentioned that I hadn't gotten used to my 27" monitor, and that's for a different reason: I just find its shape a bit odd-looking. I love its super-high res of 2560x1440, but even after having it for close to two months, I am still not used to seeing such a wide but not very tall monitor on my desk. My 30" 16:10 monitor looks more natural.
manlymatt83
#44 Post by manlymatt83 » Wed Oct 20, 2010 10:37 pm
Colonel O'Neill wrote:Agreed. I'm all for that T500.
Thanks for your longer reply. This shorter reply was easier to quote, but it had valuable information, so I appreciate it...
So money aside (Computers are my livelihood, as I have my own computer consulting business and it's where I make 100% of my income, so my laptop just needs to work and needs to be efficient), what would be the best bet to replace my T23 --- that T500 on eBay, or a brand new T510 from Lenovo, if you had to take all of your thoughts into account?
The T510 that was quoted to me for the $1100 has the i7, for what it's worth.
manlymatt83
#45 Post by manlymatt83 » Wed Oct 20, 2010 10:40 pm
pianowizard wrote: What you typed above is crucial. Things look HUGE on a 15.0" 800x600 screen. And if you find text too small at 1024x768, then I urge you to avoid high-res laptops. Previously, I thought that you might have been used to 1400x1050 Flexview, and so I was concerned that you would find HD+ (1600x900) too short. But since you are fine with 800x600 and prefer everything looking huge, and also don't mind TN screens, I should recommend you to get a 15.0" T60 with 1024x768. Others can correct me if I am wrong, but I believe that on all 16:10 Thinkpads, the lowest 16:10 resolution setting is 1280x800, whereas on all 16:9 Thinkpads, the lowest 16:9 setting is 1366x768. Even at these resolutions, things look much smaller than they do on your T42 at 1024x768. If you drop the res setting below these, you will only get 4:3 resolutions (i.e. 1024x768 and 800x600), which would look TERRIBLE because the screen would be stretched horizontally to fill the display. Sorry, but it sounds to me like you have no choice but stick with old 4:3 laptops, unless you train yourself to tolerate small text and images.
Thanks for your reply. I actually hate 800x600. I'm used to 1024x768 on my T42. Could I go a tad higher? Sure.... sometimes I feel like I don't get enough screen space on my 1024x768 and text on websites wraps a bit.... so I bet I would be willing to try something a TAD smaller, but not too crazy. But yeah, I'm definitely used to 1024x768, not 800x600... that's way too big for me.
Does that change your comments? I feel like a T60 at 1024x768 would be a lateral move for me considering my T42 is set to 1024x768 now...
LegendaryKA8
#46 Post by LegendaryKA8 » Wed Oct 20, 2010 10:57 pm
This is a valid point. If you're unused to a higher-res display that T500's going to be a challenge to use. If you have bad eyesight, you might not want to go for that one. I'd suggest finding one that has a 1280x800 display and Intel only graphics, but the one I linked you to is such a great deal that it's going to be hard to even find those lower-specced ones at that price.
If lower-res is your worry and you're willing to drop some extra cash you might be able to get away with configuring a base T510 and getting a brand new machine. I just briefly specced one(no discount codes, etc) for $1174: 1366x768 display, i5 560M CPU, integrated graphics, 4GB RAM, fingerprint reader, webcam, and Bluetooth with Win7 Pro x64.
Either way I'd jump back and think about for a little bit and make sure you know exactly what you're looking for in a new notebook. While that T500 I linked to is a great deal and pretty much perfect for what I'll be using it for(which is why I bought one), if you're going to have trouble with the high-res screen you're probably not going to like it.
#47 Post by pianowizard » Wed Oct 20, 2010 10:57 pm
manlymatt83 wrote:so I bet I would be willing to try something a TAD smaller, but not too crazy...
Then get a 15.4" 1280x800 laptop -- look for a T500 with this resolution. Things would look even smaller on a 15.6" 1366x768 laptop, such as the T510.
In addition, 1280x800 is both wider and taller than your T42, in terms of real estate (rather than physical dimensions), whereas 1366x768 gives you no height advantage.
Due to these two reasons, I am 100% certain a 1280x800 T500 would be your best bet. You could get a 1680x1050 T500 and drop the res to 1280x800, but things would look fuzzy that way.
manlymatt83
#48 Post by manlymatt83 » Wed Oct 20, 2010 11:05 pm
can anyone take a screenshot of what a desktop with firefox open or something would look like on a T500 or T510?
For what it's worth, I don't have bad eye sight. It's 20/20. I'm just not used to smaller text. Not saying I couldn't/shouldn't get used to it, as my laptop is eventually going to die.
LegendaryKA8
#49 Post by LegendaryKA8 » Wed Oct 20, 2010 11:12 pm
(Warning, following link is to pic at UXGA(1600x1200) resolution! Huge picture warning!)
http://thinkbbs.zol.com.cn/35/32108_347587.html
It's a Chinese forum, but the thread title is that T500's model number. That's a 1280x800 screen.
manlymatt83
#50 Post by manlymatt83 » Wed Oct 20, 2010 11:24 pm
LegendaryKA8 wrote:(Warning, following link is to pic at UXGA(1600x1200) resolution! Huge picture warning!)
See, that doesn't look too bad. Frankly, it looks almost like my 1024x768. If I get the T510 HD+, I believe that's something ginormous, right? I really don't think it'd be too bad.
LegendaryKA8
#51 Post by LegendaryKA8 » Wed Oct 20, 2010 11:32 pm
I wasn't able to find a comparable pic of the T510 at the base resolution. The T510 would be a little wider than that and squished a bit at the bottom.
I did find an otherwise loaded T500 with the 1280x800 screen at this eBay auction: http://cgi.ebay.com/2055B55-Lenovo-Thin ... 3361dfad19
It's pretty well loaded, and the 'scratch and dent' seems to only be a worn-out COA label on the bottom of the notebook. It even has the switchable graphics, but it's about $600. The seller is actually an electronics retailer local to me and they've never done me wrong before. I was considering a T500 about a year and a half ago and they even let me take one out of a box to compare it to the T60p I had at the time. It's not as good a deal as the other auction I linked you to, but it seems pretty fair.
manlymatt83
#52 Post by manlymatt83 » Thu Oct 21, 2010 12:25 am
Thanks.
Someone has suggested I just buy the T510 and increase text size in my operating system, which should help a lot?
LegendaryKA8
#53 Post by LegendaryKA8 » Thu Oct 21, 2010 12:27 am
Yes. Increasing the font DPI would help text readability across the board.
#54 Post by pianowizard » Thu Oct 21, 2010 8:00 am
manlymatt83 wrote:Someone has suggested I just buy the T510 and increase text size in my operating system, which should help a lot?
That's one way but a better way is to increase the DPI setting under "Display Properties" --> "Settings" --> "General" --> "DPI Setting".
However, my philosophy is that the main reason I buy high-resolution displays is to get more real estate, to see more information on the screen. Increasing the DPI setting defeats the main purpose of high-res screens. Further, high-res screens cost more, may consume more power (resulting in shorter battery duration), and usually weigh more. So, if you get a high-res laptop but then increase the DPI setting, you not only won't benefit from its real estate advantage, but you will also get all the disadvantages. Thus, if I want to see large text and images, I just go for a low-res screen. But that's just me.
underclocker
moderator
moderator
#55 Post by underclocker » Thu Oct 21, 2010 8:45 am
I don't think I'm adding much that hasn't been said already, but...
The T500 at $500 is a complete gift, if you care about value. You will be quite happy with a T500. The 15.4" and WSXGA+ resolution are a great/perfect match. It's very comfortable in general, but most apps can be adjusted. For instance, with IE8, I set my 15.4"/WSXGA+ machines to 125% (in IE8).
I have both a T500 and a T61 that are 15.4"/WSXGA+. I also had a T60 and a T60p 15.4"/WSXGA+. I also have a Z61p 15.4" WUXGA (1920 x 1200)! I use the T61 most often. It runs very quiet and it is very fast. It started as an Intel X3100 integrated graphics 15.4" WXGA, but I swapped in a WSXGA+ LCD (only the panel was needed, the cable and inverter remained the same). Again, this is a fast and quiet combination that I'm not sure was offered (or maybe by CTO). You can assemble one yourself for about $400.
As mentioned above, many of the WSXGA+ LCDs are quote good. Mine certainly are and I also have a T60 15" UXGA FlexView for reference.
Bottom line, you will love the 15.4"/WSXGA+ config and it would be crazy to spend double on a T510 vs. a T500, IMHO. I would buy the T500 and pop in an SSD before I did that.
Colonel O'Neill
#56 Post by Colonel O'Neill » Thu Oct 21, 2010 9:33 am
Popping in a good SSD will run a fair bit (two hundredish) and bring the price significantly closer to a new T510. I can find a used 640GB Scorpio Blue on Craigslist in my area for about $90. (Definitely don't want to go with used SSD's.) Locally, an 80GB X25-M seems to run around $200 before a 13% tax. Dunno what it's like in the states, though.
Judging from your inclination to run Ubuntu, I figure you're fairly "systems-y" (inventing words as I go :P ). I tend to reinstall my OS once in a while for trivial reasons (once I reinstalled about 9 times in a week; I can get 5h30 on a 80% charge with a freshly drivered install, but that goes down to 3 after dumping apps on it.), and thus would probably experience too much performance and lifespan degradation on an SSD.
zhenya
#57 Post by zhenya » Thu Oct 21, 2010 11:23 am
manlymatt83 wrote:Thanks.
Yes, that is what I would suggest. I would buy the highest resolution screen you can get in your form factor. It will be sharper, which will reduce eye strain, and Windows 7 is finally good at scaling fonts and other GUI elements in a smooth, usable way. With a higher resolution screen, you get to choose how you want to use your screen real-estate. You can make things larger or smaller as necessary. If you have a low resolution screen, you have much less flexibility. I can't imagine running a business 8 hours a day on a 1280x800 screen.
The only other thing I would suggest is to consider allocating money towards a SSD rather than a faster processor or fancy graphics card. A SSD will make a far bigger difference in how fast your computer is for most usage than anything else you can do.
manlymatt83
#58 Post by manlymatt83 » Thu Oct 21, 2010 5:01 pm
Lots of useful replies - it sounds like no one here would recommend a T400 or T410 correct? It sounds like if this is my primary machine, and I'm going to upgrade, either the T500 or the T510 would be the best bet.
I'm still thinking. I have a T42 now and love it, but I agree the 1024x768 resolution limits me a lot. EVERYTHING must be in full screen, and I can't have any windows next to each other, which I agree gets a bit annoying after a while.
So much to think about: many of you are suggesting I get the T510 and others are saying stick with the T500. Who knows.
zhenya
#59 Post by zhenya » Thu Oct 21, 2010 5:13 pm
A couple of other questions that may or may not be of any help -- you say that you use this machine in your apartment because you don't have room for a desktop. Does it ever leave your apartment? ie. do you ever use the laptop function or are you just using it as a small pc? I ask because you can buy VERY small pc's these days for less money than a laptop, and add a nice display in not much more space than a laptop takes up.
Assuming you do want a laptop, what about adding an external screen? Once you have worked with two screens, it is hard to ever go back. The ability to work in one program and look at another one at the same time is invaluable for productivity.
Assuming that you have already considered everything I've suggested here, I would suggest that whatever machine you get have the FHD or WUXGA resolution. At 1920 pixels wide, you can reasonably place two documents side-by-side on one monitor. (Windows 7 makes this easy - drag a window to one side or the other and it automatically snaps to 1/2 of the screen width).
Good luck!
manlymatt83
#60 Post by manlymatt83 » Thu Oct 21, 2010 5:18 pm
zhenya wrote:A couple of other questions that may or may not be of any help -- you say that you use this machine in your apartment because you don't have room for a desktop. Does it ever leave your apartment? ie. do you ever use the laptop function or are you just using it as a small pc? I ask because you can buy VERY small pc's these days for less money than a laptop, and add a nice display in not much more space than a laptop takes up.
Good luck!
Thanks for your reply!
I won't be using Windows 7, but I assume Ubuntu has/will have similar support. I use this as my primary machine, and 99% as a laptop. I'm never on a table, as I travel quite often - most of the time I'm in a restaurant, or perhaps a starbucks, on the train, on an airplane, and maybe 20% of the time, at a desk ... but the desk isn't mine so I won't have access to a monitor or anything like that.
So to answer your question, it needs to work well standalone, no matter where I use it, and also needs to be a true laptop.
