Best WPA2 Wireless Card for the X31?
ParatoOptimal
Re: Best WPA2 Wireless Card for the X31?
#31 Post by ParatoOptimal » Thu Feb 17, 2011 3:43 pm
Thank you for the education.
770E (relic not in use
3000 N100 T2080 1.73GHz
R61 773-1GU
T41 2373 7FU Pentium-M 1.6GHz Banias
X31 2672 XXM Pentium-M 1.3GHz
X60s 1702-68U L2400 1.66GHz Core Duo
Compaq Portable (suitcase size, gone)
Mac Portable (first laptop in world, Stored
Mac Laptop (Stored
Toshiba Tecra (Stored
ParatoOptimal
#32 Post by ParatoOptimal » Mon Feb 28, 2011 2:45 am
So, has anyone tried an 802.11n card in an X31.
If so, which one and how to you provide antennae support/
R61 773-1GU
Mac Laptop (Stored
jronald
Contributing Member
Contributing Member
#33 Post by jronald » Mon Feb 28, 2011 12:15 pm
It does not like it, will require the 1802 hack
As far as the antenna goes:
http://cgi.ebay.com/apple-Wireless-Ante ... 5d29dea3e3
Or locate and install the factory Blue-tooth antenna
Ton
T400's and T500's
misfit
#34 Post by misfit » Wed Mar 09, 2011 3:32 pm
I know that this likely isn't much help but I used the mPCI wifi and also the modem / bluetooth cards out of a 'donor' T43 with my X31 project. (I got the mint condition 1871-1LM T43 really cheaply as it has a lose southbridge. A nice collection of parts at the right price. :D )
I made my own bluetooth antenna using a length of wire with connector from my collection of lesser (non-TP) laptop parts and just ran it under the X31 palmrest. It works well. The wireless card is an Intel Pro 2200BG according to Device Manager and bluetooth is 'IBM integrated Bluetooth IV'. I didn't note the S/Ns / FRU numbers, I just fitted the cards, crossed my fingers and hoped that they worked. They both do, no BIOS-hack needed, and both work with Fn-F5.
I had to remove the cover from the bluetooth LED on the inverter as my X31 didn't have bluetooth to begin with. Hope that's of use to someone reading the thread. :)
Shaun.
T60 2007-72U [T7400, UXGA FV]
T43p 2668-H2M [FV]
T43 2668-84M [FV]
R52 1847-A18
T42p 2373-KXM [FV]
T42 2374-M97 [SXGA+]
R51 1829-E5C [FV]
R40 2723-BAM [SXGA+]
R40 2723-26M
X32 x 2 2672-CM5/W58
X31's x 8 Four working.
X30 2672-4HM
X24 2662-FMT
Etc.
StarGehzer
#35 Post by StarGehzer » Sun Mar 13, 2011 11:09 pm
ParatoOptimal wrote:What's the best WPA2 Wireless Card for the X31?
Thank you
Harryc wrote:Intel Pro Wireless 2200 b/g
http://www.intel.com/network/connectivi ... mobile.htm
I'm needing a new card & found this thread, but now I'm confused. (my wife says I'm always confused)
Isn't that Intel Pro Wireless 2200 b/g a miniPCI-e? and doesn't the X31 use a miniPCI?
I'm finding my 2100 3B won't connect if I have any security on my wireless. I'm looking for a drop in replacement that will work, and hopefully give me better speeds.
I'm new to this so sorry if I'm mistaken.
Harryc
#36 Post by Harryc » Mon Mar 14, 2011 3:57 am
Intel Pro Wireless 2200 b/g is an mPCI card.
