You're wrenching facts.Utwig wrote:The wide 14" is slightly wider and shorter than 4:3 15" and now you get either 1440x900 or 1366x768 (maybe 1600x900) instead of 1600x1200.
Instead of 1600x1200 (quite high resolution on these days, afaik the only screen with the higher resolution was rare 2048x1536) you're getting 1920x1080.
1366x768 vs. 1600x1200 has nothing to do with an aspect ratio. 1366x768 is the lowest 15" laptop resolution, and 1600x1200 was nearly the highest (the highest if we won't count 2048x1536). And if we will compare apples to apples: what was the lowest 15" laptop resolution back in 4:3 days? 1024*768? I don't know about your opinion, but IMHO 1366x768 is better than 1024x768.
15" 4:3 T60p: 2.71kg without the battery, 329x268mm.The wide 15" is half a kilo heavier and 5cm wider than 4:3 so it's not same volume / form factor.
15.6" 16:9 T510: 2.72kg with a 9-cell battery, 372x245mm.
Both W510/T510 and T60p came with 65W/90W powerbrick, depending on the internals (AFAIK you'll get 90W for a discrete/hybrid GPU model and 65W for an integrated GPU model). However, according to the links above, T60p powerbricks weight is 340gm and 490gm respectively, while W510/T510 weight is 260gm and 360gm respectively.Also the W series has the heavy powerbrick which further increases travel weight compared to 15" T__p
And what was 10" resolution in 4:3 days? I've never heard of any 4:3 10" device with resolution higher than 1024x768.This wouldn't be that much of a problem as long as you get reasonable density in portable form factor but now only high density displays are 10" 1366x769
By the way, there are 13" 1920*1080 (Sony Z-series). Is this high enough?14" 1600x900 (if they make one)
