T43 no more error 2010 (picture warning)
Re: T43 no more error 2010 (picture warning)
#61 Post by RealBlackStuff » Tue Mar 22, 2011 7:27 am
Bibin wrote:I had applied this to my T43p, and then applied the SATA mod. Did anyone do the mod with the stock bios? I have a theory that the 2010 error would not show up in that situation but I can not test it myself unless there is an easy way to restore my original T43p bios.
I had a problem recently, trying to update the ECP from V2.04 to V3.04 on a T42.
Every time it just 'hung' halfway through. The BIOS was already at the latest with V3.23.
I then downgraded the BIOS with an older version (V3.20) that would still be compatible with the (new) ECP 3.04.
The BIOS program warns you that you put in an older version, but does so without any problem.
Once BIOS 3.20 was installed, ECP update to 3.04 functioned perfectly, and I then updated the BIOS 'back' up to 3.23
I'm sure the above will also work on other Thinkpad models.
XFunky
#62 Post by XFunky » Fri Mar 25, 2011 11:34 am
hi guys..
wanted to ask how should i flash the bios without entering into windows but i manage to do it..
thanks allot :)
ozzymud
#63 Post by ozzymud » Sat May 14, 2011 4:11 pm
Doesn't the T43 come with Windows XP? Does it have a SLIC 2.1 BIOS by default? If not, this BIOS mod allows you to pirate Windows 7 and very strange to see something like that on this forum.
(2)701C,(1)760EL,(6)760XL,(1)760XD
(4)CD Drives (5)int floppies (3)ext floppy (4)2.1GB
(10)CF/IDE w/2 or 4GB 133x CF (1)760XL restore CD
(1)Belkin USB 2.0 32bit Cardbus (2)WPC54G(S) Wifi Cardbus
(1)Belkin F5D5020 NIC (1)Giga-Byte GN-WLM01 Wifi
(1)Backpack CD (1) Xircom REM56G-10 + misc
#64 Post by RealBlackStuff » Sat May 14, 2011 6:04 pm
Nothing to do with piracy.
T43 BIOS doesn't have SLIC tables by default, you need external mods for that.
Having SLIC tables in your BIOS does not necessarily allow you to pirate W7 either...
ozzymud
#65 Post by ozzymud » Sat May 14, 2011 7:36 pm
T43 probably only has the SLP string for XP, putting in the SLIC 2.1 (especially the DELL ones listed, does indeed allow piracy VERY easily... just install the CD/DVD that has that manufacturers oem files in it that matches the SLIC and boom... it is pre activated.
Modding a BIOS with SLP & either SLIC 2.0(Vista) or SLIC 2.1(Win 7) has becomethe DEFACTO way to "crack" windows... hang out in the very place these mods come from mydigitallife.com forums.
Just modding the bits for the hard drive/wireless checks is all that is needed, adding the SLIC table is purely for piracy.
#66 Post by ajkula66 » Sat May 14, 2011 9:01 pm
Huh...if one *really* wants to go the piracy route, a modded BIOS with SLIC tables is really NOT needed...
Let's keep the discussion within the parameters of the original issue, otherwise I could see this thread getting locked before you could say "Vista"... :roll:
FrankL
#67 Post by FrankL » Wed May 18, 2011 2:07 pm
RealBlackStuff wrote:Next time you try something like that, get a bootable CD, rather than updating from within Windows. Much saver!
I've just tried updating my bios using the iso image linked on the mdl forum burned to a CD-RW...
the BIOS programming utility got stuck at 'Erasing block FFFF0000' (after erasing and flashing many blocks successfully). Nothing happened.. it just froze!
I thought I'd bricked my T43 for sure...
so, I powered down and up again, and it seems to start Vista just fine. how do I know the flash was successful? I'm really afraid that I'm missing some less essential part of the bios !
lukee
#68 Post by lukee » Wed May 18, 2011 2:13 pm
FrankL wrote: I've just tried updating my bios using the iso image linked on the mdl forum burned to a CD-RW...
Have you started the application by right click and selected 'Run as Administrator'? If not, do so.
Current: T420
My first ThinkPad was 570
FrankL
#69 Post by FrankL » Wed May 18, 2011 2:28 pm
lukee wrote: Have you started the application by right click and selected 'Run as Administrator'? If not, do so.
I've burned the ISO file, which contains a bootable CD image, to a CDRW and booted from it. The flash utility it contained produced the error (runs in DOS). There's no 'administrator' or 'Windows' involved
lukee
#70 Post by lukee » Thu May 19, 2011 12:35 am
Hmm, it seems the modder changed format with the hacked BIOS from ROM+flash utility to ISO - I was flashing it inside Windows.
Current: T420
zerg
#71 Post by zerg » Sun May 29, 2011 3:56 am
I spent a lot of time to solve 2010 error, but only this solution with modificated bios works. Thanks a lot. :wink:
davidspalding
#72 Post by davidspalding » Tue Jun 21, 2011 12:33 am
I followed the instructions on this guy's blog, but I was unable to run the MFUI15 utility on the FWHD56 disc. I downloaded the FWHD50 disc, and the utility workd fine. Now my HTS721010G9AT00 is reported by XP's device manager as "0G9AT00___MCZIA5CA." This was a long time coming (no bleeding edge hacking req'd), and I'm glad to be able to use my biggest, fastest HDD (bought way back 5 years ago) as the system drive. Keeping the old one (and backups) around for a while juuuust in case.
2668-75U T43, 2GB RAM, 2nd hand NMB kybd, Dock II, spare Mini-Dock, and spare Port Replicators. Wacom BT tablet. Ultrabay 2nd HDD.
2672-KBU X32, 1.5GB RAM, 7200 rpm TravelStar HDD.
Minimx38
#73 Post by Minimx38 » Thu Jun 23, 2011 4:54 am
I got a message that there is no cpu match, what i did wrong ? :(
safe1
#74 Post by safe1 » Sat Jul 09, 2011 8:50 am
Hi guys,
the download links there http://forums.mydigitallife.info/thread ... post344779 don't work...
I try to get the "T43p-1YET65WW_SLIC2.1_no_1802_no_2010.iso" .
(...i have a T43 2668-4DU)
Any help?
matejjordan
#75 Post by matejjordan » Sun Jul 24, 2011 3:11 pm
Hi!
Links are down, so I would also be very happy if someone could share file. I bought usb wireless key instead wireless network card few years ago,...but now I can see solution is here!
I need:
- ThinkPad R52 (1858, 1859, 1860, 1861, 1862, 1863, 1958 Machine types only)
- ThinkPad T43 (1871, 1872, 1873, 1874, 1875, 1876 Machine types only)
Version: 1.29
Release Date: 2007/06/05
SLIC2.1 Lenovo TP7U
T43_R52-70ET69WW_SLIC2.1_no_1802_no_2010.iso
matej.jordan(at)gmail.com
Thank you very much!
Matej Jordan
lukee
#76 Post by lukee » Mon Jul 25, 2011 1:13 am
Hi Matej, try to contact TTaV134 member here or on the MDL forums to reupload the ISOs. I can provide permanent hosting for all these ISOs if neccessary.
Current: T420
Vonfeffer
#77 Post by Vonfeffer » Tue Jul 26, 2011 2:24 pm
Please re-enable the download links, I really would like to get rid of that anoyng 2010 error, not for the error itself (I really don't care about the error message) but for the boot time it steals!!!!. My machine is a R52 1847. :help:
Best Regards
VonFeffer
You can´t change the past but you can create a better future if you change the present.
IBM
T41 2373-311 - 2GB Ram, 2Ghz
T43 2668-J29 - 2GB Ram, 2Ghz
T420 4178-ABP - 8GB Ram, i5 2520m
W510 - 16GB Ram, i7 720QM, SSD
Amigaman
#78 Post by Amigaman » Wed Aug 24, 2011 8:24 pm
<Edit>
Never mind, found them..
T61p: 15.4" WSXGA+, T7500, 8GB, FX570M, 500GB 7K750, BT, A/B/G/N, FP, Turbo Cache.
X41: 14" XGA, PM 1.6, 1.5GB, 60GB SSD, BT, A/B/G, FP.
Previously: R32, T42, T43
Navid
#79 Post by Navid » Fri Aug 26, 2011 10:36 am
I've a T43 2668-F5G and a T43P 2668-PEG I've tried the bios fix on, both running Windows 7 Ultimate 32-bit.
Both bioses appeared to go on without issue, and both appeared to have the 2010 issue resolved. Though with varying degrees of success.
It seems to have effected the ability to hotswap disks in the Ultrabay for both the T43 and T43P... I can roll back to the 1.29 official bios and pull the ultrabay in and out and have Windows 7 eject and pick up drives without issue... When I try the modified bios any ultrabay drives are successfully ejected, but not recognised when put back in (I found a [workaround] entering Disk Management and choosing 'Action > Rescan Disks' does have Windows 7 re-recognise the drives).
Following the Bios update on the T43 Windows functions without apparent issue, however on the T43P the Event Viewer System Log began to be flooded with error messages, and the T43P was struggling to launch anything. Rolling the Bios back to the official version fixed the problem (and the hard disk beeps during bootup resumed... sigh).
Not sure if it's related but the T43 now has event viewer message 'Warnings' that can probably be ignored related to 'The embedded controller (EC) returned data when none was requested. The BIOS might be trying to access the EC without synchronizing the operating system'
I've decided I will leave the modified BIOS on the T43, but live with the warning on the T43P running the official BIOS. Weirdly the T43P does not have the two beeps as part of the hard disk 2010 warning (it never has) but I suspect this may be that the speaker for the beeps has malfunctioned, though audio on the laptop is fine through the speakers otherwise?
RWDPLZ
#80 Post by RWDPLZ » Wed Aug 31, 2011 10:16 am
Anyone have a current link for T43p type 2668-N15?
770ED *sold*
A21m 2628-ERU *OK*
A22p 2629-PFU *OK*
A30p 2653-65U *sold*
A31 2653-CU3 *sold*
A31 2652-M6U *sold*
A31p 2653-R8U *needs new screen*
X24 2662-MWU *OK*
X41t 1866-5GU *OK*
T43p 2668-N15 *OK*
T61 6465-CTO *workhorse*
#81 Post by RealBlackStuff » Wed Aug 31, 2011 10:57 am
ThinkPad T43p (2668-N15)
Based on 2668-P1U: P M 750(1.86GHz), 2GB RAM, 100GB 7200rpm HD, 14.1in 1400x1050 LCD, 128MB ATI FireGL V3200, CDRW/DVD, Intel 802.11bg wireless, Bluetooth/Modem, 1Gb Ethernet, UltraNav, Secure chip, 9c Li-Ion batt, WinXP Pro
Drivers etc: http://support.lenovo.com/en_US/researc ... MIGR-58597
skam
#82 Post by skam » Sat Oct 15, 2011 8:57 pm
T43p 2668-H1U
T43p 2668-H2U
seattlepainter
#83 Post by seattlepainter » Thu Nov 17, 2011 10:23 pm
I recently purchased a T43p IBM Thinkpad that had the annoying "2010 Error" message. I tried a number of things, including purchasing another Western Digital harddrive, but to no avail. I finally got the courage to download the utility application (T43-SLIC2.1_7U) and I installed it. Worked like a charm and no more "2010 Error" message. I can't be happier with the result and I would like to encourage anyone with the same problem to use this utility application.
ujav
#84 Post by ujav » Wed Dec 07, 2011 8:04 pm
Just noticed this thread, annoying error after the years finally has gone :bow: Thank you!
T30(14" XGA, 12V car powered, still alive), A31p(UXGA IPS, secondary HDD and battery, some PC Card add-ons, alive), R50p(UXGA IPS, dead after massive tea spitting), T43(IPS SXGA+, GPU desolder), T43p(UXGA IPS, dock, almost maxed out), T60(SXGA+ IPS) + second T60 IPS+dock and some mods
flacer
#85 Post by flacer » Thu Jan 26, 2012 3:58 pm
Hi everyone I have a lenovo x60 tablet (model 6363AE9) and just recently installed a modded bios that did not have the wireless whitelist removed (7JET30WW/1.15, 11/20/08). I need the whitelist removed in order to use my new broadcom crystal hd bcm70015 in the second pci slot instead of the sierra wireless mc5720 mini pci card. I went to a whitelst removal form, they said i need the hardware ids for both, but i cannot find them, so this is my last hope! :bow:
#86 Post by RealBlackStuff » Thu Jan 26, 2012 5:14 pm
flacer wrote:Hi everyone I have a lenovo x60 tablet (model 6363AE9) and just recently installed a modded bios that did not have the wireless whitelist removed (7JET30WW/1.15, 11/20/08). I need the whitelist removed in order to use my new broadcom crystal hd bcm70015 in the second pci slot instead of the sierra wireless mc5720 mini pci card. I went to a whitelst removal form, they said i need the hardware ids for both, but i cannot find them, so this is my last hope! :bow:
- Wrong forum
- Unrelated thread
- Double posting
Please stick to one thread in the X6x forum!
sbbamafan
#87 Post by sbbamafan » Sat Mar 03, 2012 11:47 am
I know this is an old post BUT I just got a T43 with a bad drive. I thought it would be an easy upgrade until I found out about the 2010 error. I am somewhat computer literate (or so I thought), but not nearly as much as you people. Can someone please post step by step instructions relating to:
What drive (brand/type) I can use (like to have 250 GB if possible)
Where and how to download the bios mod
How to load it onto the T43
I would think that I need to buy and install the new drive, download the new bios to another PC and transfer through jump drive, but that is about all I know. FWIW - I have never made any type modification to a bios.
Thanks for your help. Sorry for being stupid!!
psimmond
#88 Post by psimmond » Thu Nov 08, 2012 1:50 am
I currently have BIOS 1.29 and EC 1.06 in my R52 and other than the annoying beeps everything seems to work well.
I downloaded R52-T43-76UJ29US_SLIC2.1_M09_no_1802_no_2010_by_TTAV134.zip but before I mess with it I have a question: Does this BIOS do anything to improve performance or does it just enable the computer to boot normally?
lukee
#89 Post by lukee » Thu Nov 08, 2012 2:20 am
Modded BIOS bypasses the HDD check routine so the 2x beep and delay is removed.
Current: T420
psimmond
#90 Post by psimmond » Thu Nov 08, 2012 2:33 am
lukee wrote:Modded BIOS bypasses the HDD check routine so the 2x beep and delay is removed.
1. Would it harm my computer in any way if I keep the current bios and live with the beeps and delay?
2. If I decide to flash, is it as simple as unzipping, clicking WinPhlash.exe, and then following on-screen directions?
