Would I need 2 VRM's for 2 processors, or does the Z Pro only need one? Pardon my newbness...
IBM Intellistation maximizing RAM
Re: IBM Intellistation maximizing RAM
Reviving this thread again...
Blackj, your IntelliStation 9228 already has one built-in VRM on the motherboard to support a single occupied socket.
On the top edge of the motherboard nearest the power supply is the edge connector mount for the second VRM.
You'll need to source and install one of those before you can add a second Xeon (dual core or quad core) to the system.
Theokretes
Earlier in the thread it was mentioned that non-ECC RAM could be used-- I am certain that FB-DIMMs have a different notch?
2x T60p, 1x T61, loads of 701Cs, 1x WorkPad Z50, 2x TransNotes other random thinkpads...
livinstyle
Hi Everyone,
i have acquired an Intellistatino Z Pro 6223, and for the life of me i cannot get windows 7, 8, or 10 installed on this machine.
I was able to install WinXP x64 perfectly fine. I only have an 80GB IDE drive and an IDE DVD-ROM drive in the machine currently.
I've tried to install win7 with SATA raid and SCSI raid, no dice on each.
ran a hardware check, everything passed w/o issue.
Here are the specs:
BIOS ver 1.7
Dual XEON 3.0Ghz
3GB PC2-3200 RAM Non-ECC (512x6)
changed every possible setting in the BIOS, still no luck. i have the HDD on ATA channel 0 and the DVD drive on Channel 1. HDD is set to master for jumper settings, and the DVD drive set to slave. If i leave it on CS, some reason it only detects the HDD, so i had to manually set the jumper on each so the computer can recognize both drives.
the only thing in the BIOS that is still enabled is SATA raid and SCSI raid, but no drives are installed. i was hoping to get win7 installed and install the drivers for them so i can have both SATA and SCSI raid setup for more drives.
Any assistance would be appreciated.
Thank you
Here are the specs:
BIOS ver 1.7
Dual XEON 3.0Ghz
Thank you
X1 Carbon (5th gen, 2017) : 8gb Ram or 16gb Ram , i5 or i7
by asterinex » Tue Apr 25, 2017 4:12 am » in ThinkPad X1/X1C - 26 Replies
- 1949 Views
Last post by w0qj
Sat Apr 29, 2017 11:22 am
R61e, T9300 CPU, 3GB RAM.... $55 + shipping
by excal32 » Tue Dec 27, 2016 12:32 am » in Marketplace - Forum Members only - 11 Replies
- 978 Views
Last post by excal32
Thu Jan 12, 2017 2:28 pm
Low voltage v Normal RAM (Mixing?)
by blink » Thu Dec 29, 2016 8:17 am » in Thinkpad - General HARDWARE/SOFTWARE questions - 3 Replies
- 1596 Views
Last post by Kasm279
Fri Dec 30, 2016 11:39 am
FS: misc parts.... lightly used classic keyboard | 4GB DDR3 RAM | lightly used T500 palmrest, bezel
by tpdude4 » Sat Dec 31, 2016 9:06 am » in Marketplace - Forum Members only - 6 Replies
- 677 Views
Last post by tpdude4
Sun Jan 15, 2017 6:45 am
