Updated/New IBM ThinkPad Software Installer
ranjit
#31 Post by ranjit » Sun Mar 20, 2005 9:30 am
Hi James,
Thank you for your response.
I don't understand your suggestion... Could you please elaborate?
Btw, what about the "Intel Chipset Support II", does this app have anything to do with my problem?
Ranjit
JHEM
#32 Post by JHEM » Sun Mar 20, 2005 9:32 am
Stillstuck wrote:Apologies,
I'm located in Lansing, Mi. USA
800-IBM-SERV (800-426-7378)
Make sure you have the latest Windows updates installed on your system.
"Some driver updates may not be shown in the download list unless the latest Microsoft fixpacks have been installed through Microsoft Windows Update".
Regards,
James
James at thinkpads dot com
JHEM
#33 Post by JHEM » Sun Mar 20, 2005 9:38 am
ranjit wrote:I don't understand your suggestion... Could you please elaborate?
http://www-3.ibm.com/pc/support/site.ws ... hlocataion
ranjit wrote:Btw, what about the "Intel Chipset Support II", does this app have anything to do with my problem?
I wouldn't think so. Like Stillstuck you should ensure you have the latest OS drivers and fixpacks installed.
Regards,
James
JHEM
#34 Post by JHEM » Sun Mar 20, 2005 9:46 am
Bonjour Yves,
yves wrote:I have the same problem as Stillstuck but with an A31P.
Is your machine type properly reported in the BIOS. You can also check in the Configuration Utility by clicking on System Information> Summary.
Regards,
James
yves
thinkpads.com customer
#35 Post by yves » Sun Mar 20, 2005 1:15 pm
Yes , it is . In the Summary, it is writen = System Model 2653h5g
TIA
IBM ThinkPad T61 CTO (2.4/2GB/100/Video WXGA/14.1/WebCam")
Formerly: 700C, 755CD, 760ED, 560, 570, 600X, X20, X23, X31, X40, A20P, A31P, T41P, T43, T60P, transnote, panasonic CF28 , CF29, CF19 mk2 - from Bill -http://www.penuries.com
JHEM
IAN!!!!
#36 Post by JHEM » Sun Mar 20, 2005 1:37 pm
Yves,
yves wrote:Yes , it is . In the Summary, it is writen = System Model 2653h5g
All I can suggest at this point is to call IBM support (+33-238-557-450 9AM - 6PM Monday - Friday) and explain the problem to them.
That unit should still be in warranty.
Perhaps Ian will chime in here, he's in France and speaks the lingua Franca, I'm sure he's had dealings with local support although I know that he prefers taking his Thinkpads "home" to the UK for support.
Regards,
James
Stillstuck
#37 Post by Stillstuck » Sun Mar 20, 2005 2:11 pm
Just catching up with the rest of the conversation:
I do have the latest windows updates and patches:
Running Win XP 5.6.2600 Service Pack 2 Build 2600
Running IE
System Model as identified by System info: TP-A21p_
Actual System: ThinkPad A21p 2629-RRE
512 MB Ram
Running from Docking Station with Windows Firewall enabled, although I don't see how that could affect things.
Stillstuck
#38 Post by Stillstuck » Sun Mar 20, 2005 2:14 pm
Added comment:
My A21p warrenty expired roughly 14 months ago.
JHEM
#39 Post by JHEM » Sun Mar 20, 2005 2:57 pm
Stillstuck wrote:Running from Docking Station with Windows Firewall enabled, although I don't see how that could affect things.
Undock the unit, try again and report back!
Yes, the fact that the unit is docked can most certainly have an effect.
Regards,
James
Stillstuck
#40 Post by Stillstuck » Sun Mar 20, 2005 3:42 pm
Regards,
James
Tried removing from docking station, but No Luck.
Pulled from docking station:
1.) re-tried install of "Automatic thinkpad software installer".
Same error message: "invalid machine type"
2.)Tried auto detecting machine type at IBM's web site.
Still get "Information for '-' was not found".
andyli
#41 Post by andyli » Sun Mar 20, 2005 6:36 pm
For my T42p, the installer worked great.
However, for some reason, the versions on the installer are OLDER than those available through Windows Update. That really confused me (and caused me to have to reinstall a few things twice). Now, I am ignoring updates from Microsoft that is IBM-related and using the Installer for IBM-related software.
plasdom
#42 Post by plasdom » Sun Mar 20, 2005 9:07 pm
Works great here. I wiped my t42 clean and reinstalled the OS (wiped the hidden partition too). This helped restore all the drivers that I needed to make things work like they did when I got it from the factory
ranjit
#43 Post by ranjit » Sun Mar 20, 2005 9:22 pm
Hi James,
Thank you for your message.
Yes, I do have the latest OS drivers and fixpacks installed in my system.
Like you said, I moved the folders where the drivers are located on my HD (in my case, it was the folder named "IBM", and the folder named "PkgMgr" in C:/Program Files/Thinkpad for the "Software Installer") under search locations. In the retrieved list, I found under "Available Versions" the latest versions of the drivers and updates, and under "Installed Versions" I found a "<--" for most of the packages. What does this mark mean? Does it mean that I do have the version indicated in the available version list?
Strangely, for the "Software Installer", I found version 2.32.0492 in [u]available version [/u]and 3.01.0503 in installed version. Surely, the available version should also have been 3.01.0503. Right?
Please advice.
Cheers and best regards,
Ranjit
mattfromomaha
Moderator1
Moderator1
#44 Post by mattfromomaha » Sun Mar 20, 2005 10:16 pm
I installed it yesterday and it seems to work great on my T-30.
pat
#45 Post by pat » Mon Mar 21, 2005 9:35 am
I'm having a problem using this on my 2378FVU. it seems to freeze when it's installing some drivers. I let it go the whole night and woke up this morning to it and it was still installing the same driver!
The driver in question is the power management driver.
I also unchecked it and installed the next driver in line and I got the same deal.
What gives?
Stillstuck
#46 Post by Stillstuck » Mon Mar 21, 2005 7:46 pm
Does anyone know a way to restore the internal system ID, (Machine Type/Model, & Serial Number)?
I think the root cause of my problems trying to install the "Automatic thinkpad software installer", (ie. error message "invalid machine type"), is that my machine no longer has any internal ID data.
When I try the 3 System ID Tools I've found on IBM's web site I get blank or near blank responses.
1.) "Detect my System" Feature at the IBM web page
http://www-307.ibm.com/pc/support/site. ... y=2373-xtx
Yields the response: "Information for '-' was not found".
2.) "System Details" on the IBM web page
http://www-307.ibm.com/pc/support/site. ... uestion.vm
System Details
Machine Type/Model: - (dash)
Serial #: -blank- (null field)
3.)View, save and compare snapshots of more detailed system information (drill down feature of #2)
Computer Model: -blank- (null field)
Serial Number: -blank- (null field)
On the other hand:
Microsoft System Info gives:
System Model TP-A21p_
Any insight on how these internal ID's and serial numbers could be restore would be appreciated.
Thanks,
Stuck
JHEM
#47 Post by JHEM » Mon Mar 21, 2005 8:33 pm
Stillstuck,
Email me from a valid account.
Regards,
James
Uncletoad
#48 Post by Uncletoad » Mon Mar 21, 2005 11:41 pm
Boy am I glad they designed this. Makes updates super easy. Excellent utility.
Salutations from the Land of Cows
Phil Maneri
T42p 2373KXU 15” UXGA
T42 2373K9U 14.1 XGA x2
T42 2373B21 14.1 XGA
Looking for a T42p 2373Q1U UXGA
yves
My A31P is detected with both the 2 links
#49 Post by yves » Tue Mar 22, 2005 1:55 am
But I still get invalid machine type !!
DavidNZ
#50 Post by DavidNZ » Tue Mar 22, 2005 2:42 am
It's a nice piece of software, to be sure, but I wish there was a way to permanently refuse a particular driver option. For example, it's telling me that it is 'mandatory' that I download and install "Intel Chipset Support III", but when I find out more info about it from the IBM ftp site, I read:
"If you use the Product Recovery function shipped with your ThinkPad to restore the Windows preload environment, you do not need this package. This package is required when you install Windows Operating Systems without the Product Recovery function."
Ok great, so it's not really for me. So, I wish the software installer would give me the option to say something like "I'll never need this. Thanks anyway." Same with Access Connections 3.7, come to think of it (I'm happy with 3.30, thanks)! ;)
X40 (2371-6EM) w/ 768 RAM
XPP SP2
DLINK DI-614+
jsalb
#51 Post by jsalb » Tue Mar 22, 2005 4:05 am
There unquestionably is a bug in the new installer. My A31p (2653-H5U) has SP2 and all subsequent MS hotfixes installed; it's up to date (In any case, I suspect that's irrelevant).
Also, none of the other proposed solutions in this thread have solved the problem: namely, that the installer will not pick up the newer versions of certain of the utilities and drivers.
I've carefully tested different path configurations for the IBM driver directory, with no change. I don't doubt that the installer is performing as expected on many machines. But there is a persistent bug that seems to be machine-specific.
yves
#52 Post by yves » Tue Mar 22, 2005 2:25 pm
I have a 2653 and the installer does not work at all
No SP1 or SP2
JHEM
#53 Post by JHEM » Wed Mar 23, 2005 8:42 pm
yves wrote:I have a 2653 and the installer does not work at all
No SP1 or SP2
What OS and release are you running Yves?
Regards,
James
JHEM
Updater Works on Transnote!
#54 Post by JHEM » Wed Mar 23, 2005 8:47 pm
Even though the Transnote isn't listed as one of the units the new updater works on, I downloaded and installed it anyway just for a lark.
First time I attempted to run the app it froze and I had to three finger salute it to get it to shut down.
Then I had an all too infrequent brainstorm and rebooted the machine. Works perfectly now and is presently installing all of the updates it downloaded.
Running W2K SP4.
Next up: 600X!
Regards,
James
yves
#55 Post by yves » Wed Mar 23, 2005 11:27 pm
I am using Window XP without SP1 or SP2.
Just the pre loaded XP US version (from Bill Morrow)
JHEM
#56 Post by JHEM » Thu Mar 24, 2005 12:36 am
Yves,
yves wrote:I am using Window XP without SP1 or SP2.
As previously noted, the updater stipulates that you must have the latest Service Packs for your OS installed in order for the Updater to work properly.
I would strongly urge you to run the Windows update utility Start> All Programs> Windows Update.
If you continue to have problems after you update to SP2 I would again suggest you contact IBM support in Paris at the number I previously posted.
Regards,
James
n3il
#57 Post by n3il » Thu Mar 24, 2005 5:19 am
JHEM wrote: I would again suggest you contact IBM support in Paris
Paris?!!!!! :lol:
Neil
R50p 1832-23G; 2GB RAM
yves
#58 Post by yves » Thu Mar 24, 2005 6:38 am
Yes I am in Paris, the betrayer's city
thank you very much
I am doing immediately Windows update utility Start> All Programs> Windows Update.
n3il
#59 Post by n3il » Thu Mar 24, 2005 6:40 am
I was not meaning offence - just that the IBM support for France is not in Paris... :lol:
Neil
yves
#60 Post by yves » Thu Mar 24, 2005 8:26 am
Yes I was writting that because I received a strange email from a guy "Bruce Markowitz" <scosgt@worldnet.att.net
I asked him to purchase a ThinkPad
Here is his reply
"Say hello to the Eiffel tower. I don't ship overseas, and I would never do
business with the cowardly French. Bye"
