My IBM THINKPAD T30:
jronald
Contributing Member
Contributing Member
Re: My IBM THINKPAD T30:
#31 Post by jronald » Thu Mar 03, 2011 2:24 pm
There are also these, much faster than USB:
PATA
http://cgi.ebay.com/NEW-IBM-IDE-PATA-2n ... 3cb2c308b8
SATA
http://cgi.ebay.com/SATA-2nd-HDD-caddy- ... 335f6d9b49
I have a couple of Knock Off PATA type, when I need to move large files fast, I use these. It will take the place of your CD/DVD player
Ron
T400's and T500's
MrsOBrien08
#32 Post by MrsOBrien08 » Thu Mar 03, 2011 5:36 pm
Mine say:
Mobile Intel(R) Pentium(R)
4 - M CPU 1.60GHz
1.20 GHz, 512MB of RAM
Does that mean I need to buy the memory card?
#33 Post by RealBlackStuff » Thu Mar 03, 2011 6:04 pm
Open the lid on the bottom, nearest the front.
In there are the slots for 2 RAM modules.
If you find 2 modules, they will be 2 x 256MB.
If one, it's a 512MB module.
In either case, buy a 1GB PC2700 SODIMM, to top up your RAM to 1.25 or 1.50 GB.
Then you need to download and install the Intel Chipset software http://www-307.ibm.com/pc/support/site. ... MIGR-44310
When installed, your T30 will run at 1.6GHz (provided you have both battery and AC connected), instead of 1.2GHz.
MrsOBrien08
#34 Post by MrsOBrien08 » Thu Mar 03, 2011 6:19 pm
Thanks for the help...THIS IS THE BEST SITE I'VE EVER BEEN ON!!!! LOVE IT!!!
jronald
Contributing Member
Contributing Member
#35 Post by jronald » Thu Mar 03, 2011 7:16 pm
About the best price I have seen on memory for the last 60 days
http://www.newegg.com/Product/Product.a ... -_-Product
There is no significant difference in any of the first 3 brands, I have used/heard good things from all.
Ron
T400's and T500's
robert213
#36 Post by robert213 » Fri Mar 04, 2011 8:57 am
RealBlackStuff wrote:Open the lid on the bottom, nearest the front.
Also, if you haven't removed a RAM module before, they are spring-loaded.
Use one hand to spread open the white plastic tabs that hold the module in place and use the other hand to hold/support the module, such that it doesn't suddenly "spring up" towards you.
Tuus-built T61: T8100 2.1 GHz, SXGA+, NVS140M, Patriot 4GB PC2-6400 DDR2-800, Samsung 840 120GB; Thinkpad T30: P4M 1.8 GHz, HYNIX 512 MB PC2700S DDR, Hitachi Travelstar 7K100 100GB; SilverStone Raven RVS01; 97 Volvo 850-R, 85 Mitsubishi Starion-ES, Keilwerth SX-90R, Ensoniq TS-12, Kawai EP-608
MrsOBrien08
#37 Post by MrsOBrien08 » Fri Mar 04, 2011 9:25 am
Thanks for the instruction. I have never installed anything in a computer. This is the first computer I've owned....LOL I am so greatful for "plug & play"!!! LOL....I ordered the memory and 4 port card bus yesterday so when it comes....I'll revert to my notes from you....wish me luck!!! Once again, THANK YOU SO MUCH for ALL the help!!! You guys must be experts because you have not only an answer for everyones question but multiple answers....I couldn't have done this without this forum. :D
jronald
Contributing Member
Contributing Member
#38 Post by jronald » Fri Mar 04, 2011 9:44 am
Not really experts, I dont think any of us have "formal" training.
In my case, I was/am too poor to do anything other than learn by trail and error!
Ron
T400's and T500's
MrsOBrien08
#39 Post by MrsOBrien08 » Fri Mar 04, 2011 10:01 am
LOL...All I can say is "BRAVO"....The entire country is under financial stress, myself included, but with forums like this we can come together as a community and help each other. Your my experts!!!! :D
MrsOBrien08
#40 Post by MrsOBrien08 » Sat Mar 05, 2011 4:04 pm
I installed the 1BG PC2700 SODIMM and went to the link....but from there I'm LOST!!! I saved these instructions from the link you gave me but don't know WHERE to begin....Any HELP???!!! PLEASE!!! P.S. Still waiting for 4 port card bus to arrive as well. Should I still purchase the Apricorn Drivewire for a usb enclosure? SO CONFUSED!!!! :help:
Neil
#41 Post by Neil » Sat Mar 05, 2011 4:09 pm
Did you read the README text file on installing the Intel chipset driver? It contains all the instruction you will need.
MrsOBrien08
#42 Post by MrsOBrien08 » Sat Mar 05, 2011 4:26 pm
I will NOW!!! THANK YOU!!! Wish me luck....Hopefully things go well and I'll send a positive update....Thanks again....You guys bring tears to my eyes everytime I see a reply...the speedy response...the attention to detail....the technique...THANKS!!! :wink:
MrsOBrien08
#43 Post by MrsOBrien08 » Sat Mar 05, 2011 6:30 pm
Neil wrote:Did you read the README text file on installing the Intel chipset driver? It contains all the instruction you will need.
I read it, installed it and the new hardware is still not found. HELP!!!
robert213
#44 Post by robert213 » Sat Mar 05, 2011 8:39 pm
MrsOBrien08 wrote:Mine say:
4 - M CPU 1.60GHz
MrsOBrien08 wrote: I installed the 1BG PC2700 SODIMM
After going to...
[Start][Control Panel][Performance Maintenance][System][General]
Your System Properties should now say:
IBM Corporation
4 - M CPU 1.60GHz
1.20 GHz, 1.256 GB of RAM
-or-
IBM Corporation
4 - M CPU 1.60GHz
1.20 GHz, 1.0 GB of RAM
depending upon whether you left the 256MB chip in the other memory socket.
After you follow RBS instructions, it ought to say:
IBM Corporation
4 - M CPU 1.60GHz
1.60 GHz, 1.256 GB of RAM
After going to...
[Start][Control Panel][Performance Maintenance][System][HARDWARE][Device Manager]
click on "Processors"
Do you see any red question marks, or yellow exclamation points?
Mine says:
Mobile Intel(R) Pentium(R) 4 - M CPU 1.80GHz
Does yours say?
Mobile Intel(R) Pentium(R) 4 - M CPU 1.60GHz
If so, click on it, as well, followed by [Driver Details]"Hardware Ids" (in drop down box)
Mine says:
ACPI\GenuineIntel_-_x86_Family_15_Model_2
*GenuineIntel_-_x86_Family_15_Model_2
*GenuineIntel_-_x86
robert213
#45 Post by robert213 » Sat Mar 05, 2011 8:45 pm
Ignore the last part of my previous reply...
After going to...
If there are no red question marks, or yellow exclamation points, yours ought to say:
Now, click on [Driver] tab
Mine says:
Driver Provider: Microsoft
Driver Date: 4/1/2004
Driver Version: 5.1.2600.0
Then, click on [Driver Details] button
Mine says:
C:\WINDOWS\system32\DRIVERS\intelppm.sys
What does yours say?
robert213
#46 Post by robert213 » Sat Mar 05, 2011 8:57 pm
(Installing)
8. On Windows XP/2000, make sure to be logged on with administrative
privileges.
9. Close all running application programs.
10. Open an Explorer and locate the directory where the files were
extracted.
11. Double-click INFINST_ENU file.
12. Follow the instructions on the screen to reboot the computer.
13. Follow the instructions on the screen when new hardware is
detected after the reboot.
Do you remember which file folder you downloaded (or copied) the
"INFINST_ENU" file?
MrsOBrien08
#47 Post by MrsOBrien08 » Sun Mar 06, 2011 11:18 am
Mine says:
What does yours say?[/quote]
Mine also says:
C:\WINDOWS\system32\DRIVERS\intelppm.sys.....Now what do I do? Can I save my music to C: now?
As ALWAYS, THANX!!!
MrsOBrien08
#48 Post by MrsOBrien08 » Sun Mar 06, 2011 11:30 am
I did exactly what you said....I never saw the new hardware be detected BUT the properties from our previous message match...
"INFINST_ENU" file?[/quote]
robert213
#49 Post by robert213 » Sun Mar 06, 2011 7:17 pm
MrsOBrien08 wrote:Mine says:
Mine also says:
As ALWAYS, THANX!!![/quote]
It appears that you have the necessary driver for your CPU chipset. Let's recap, where your machine stands.
There are 3 factors that determine the performance of your machine...
1) CPU processing speed
2) Memory capacity
3) Harddrive capacity and speed.
Let's start with the first two:
After going to...
Your Windows XP System Properties previously said:
IBM Corporation
4 - M CPU 1.60GHz
This means that you have an Intel Pentium 4M processor designed to run at 1.60 GHz.
This means that you have Main Memory capacity of .5 GB.
RBS noted that your processor was running at 1.20 GHz, instead of 1.60 GHz. He suggested that you may not have the correct WIN XP hardware device driver. Hence, he suggested downloading the correct device driver from Intel's website.
RON noted that your memory was below 1.0 GB. He suggested that you need to remove one of your 512MB memory chips and replace it with a 1GB memory chip. This process does not require any Win XP software updates.
What do your Windows System Properties say now?
MrsOBrien08
#50 Post by MrsOBrien08 » Sun Mar 06, 2011 9:29 pm
IBM Corporation
4 - M CPU 1.60GHz
1.20 GHz, 1.0 GB of RAM is what my settings say now.....am I good to go now? Should I still buy the Apricorn Drivewire? I'm still waiting for the 4 port cardbus to be delivered....
#51 Post by RealBlackStuff » Sun Mar 06, 2011 10:10 pm
Is there a working battery in that T30?
On AC alone you won't get full speed...
MrsOBrien08
#52 Post by MrsOBrien08 » Sun Mar 06, 2011 11:06 pm
I believe the battery needs to be replaced...when the powercord is unplugged and the battery runs low a pop up box comes up that says to replace the battery. I'll buy one from Ebay....Thanks!!!
robert213
#53 Post by robert213 » Mon Mar 07, 2011 12:13 pm
MrsOBrien08 wrote:I believe the battery needs to be replaced...when the powercord is unplugged and the battery runs low a pop up box comes up that says to replace the battery. I'll buy one from Ebay....Thanks!!!
Is your battery indicator light "yellow"? It is supposed to be green.
Please, someone who has better knowledge than me, verify that this is true...
I believe that it is better to run your machine with NO battery than to run your machine with a very weak battery -- as the power invertor will damage itself from forever attempting to charge a dead battery.
My battery says
Field Replacement Number: 02K7072
OEM Number: 02K7034
Make sure your replacement is 10.8 Volts
IBM Corporation
4 - M CPU 1.60GHz
The next question to ask yourself...
How do you wish to store your music, videos, and other data files?
Some folks prefer...
1) SanDisk Cruzer and Verbatim USB Flash Drives
They are available in 2GB, 4GB, 8GB, 16GB and even 32GB. They are very convenient to use. However, some folks believe that they are expensive -- $20 for 8GB and $40 for 16GB. Also, since they are pre-formatted using FAT32 (Win 98 File System), they are not able to hold video files larger than 4GB. It is somewhat inconvenient to reformat a flash drive with NTFS (Win XP File System) everytime you buy a new flash drive.
2) Purchase a used PATA/IDE HD and place in UltraBay
When IBM originally designed these machine, they created the UltraBay to enable users to "swap-out" DVD/CD drive and replace with 1.44" floppy or a secondary PATA/IDE HDD. If you don't mind leaving your DVD/CD drive in your desk drawer, this is a good choice. UltraBay is faster than USB 2.0. However PATA/IDE HD (because they are no longer made) are more expensive than SATA.
3) Purchase a new SATA HD and place in UltraBay
There are clever Chinese companies that realize IBM Ultrabay HDD adapter only supported PATA/IDE HD. They now make aftermarket SATA versions.
4) Purchase a new SATA HD and use Apricorn Drivewire adapter
While the Apricorn product can interface with 3 types of HDD -- Desktop, Laptop PATA/IDE and laptop SATA, it has two disadvantages. 1) Many parts (inconvenient to take to local library or coffee shop) 2) Requires A/C power/
5) Purchase a new SATA HD and use USB enclosure
This is what I use. See my previous post on Silverstone's Raven. I like it because it is very easy to swap out one SATA HD and place in another. Most folks, simply purchase a cheaper enclosure and seldom change the HD. This option requires an USB 2.0 CardBus.
MrsOBrien08
#54 Post by MrsOBrien08 » Mon Mar 07, 2011 3:53 pm
Can you tell me which one is cheapest and easiest to use? As I said in my other reply, I am currently waiting for the 4 port cardbus to be delivered. I want to store all my music downloads, video downloads, and pictures on one device. I want easy access to the files at all times via my laptop. I will not be traveling outside my home with the laptop so mobility is not a problem. :?
robert213
#55 Post by robert213 » Mon Mar 07, 2011 4:25 pm
MrsOBrien08 wrote:Can you tell me which one is cheapest and easiest to use?
It depends upon which type of hard drive you wish to use. It is a matter of personal preference. Visualize yourself using one of the five options I listed in my previous message. Which one appeals to you?
You could always use the internal HDD inside of your machine..
[Start][Accessories][Windows Explorer]
click on "My Computer"
Under Hard Disk Drives:
(C:) Local Disk under columns Total Size and Free Space
However, I don't like storing my data files on the same HDD as my Windows XP System Files. I prefer to keep a copy of my data files on a seperate external HDD.
I guess that the questions to ask are...
Do you have an old used HD lying around from an old desktop? Do you plan on upgrading your original factory 4200 rpm HD with a faster 5400/7200 rpm HD? Do you have $90 in your budget to purchase an external 500 GB harddrive? Do you wish to keep your DVD/CD drive (to play DVD's or listen to music) inside of your machine?
Ron suggested a couple of USB HDD enclosures..
http://www.geeks.com/details.asp?invtid ... AU&cat=HDD
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0072150240
Do you have a Fry's Electronics store in your neighborhood?
http://www.frys.com/category/Outpost/El ... nclosures/
I like shopping at NewEgg...
http://www.newegg.com/Product/ProductLi ... &x=13&y=34
Don't buy anything utill you tell us...
1) What type of (desktop, PATA, or SATA) HD that you plan to use.
2) Whether it is an inconvenience to have your Ultrabay DVD/CD drive in your desk drawer.
jronald
Contributing Member
Contributing Member
#56 Post by jronald » Mon Mar 07, 2011 5:30 pm
I did not check the prices on the below items, but use them FAR more often than I do the DVD-RW or CDR-RW.
PATA
SATA
These are the same as I listed above.
If the Ultra-Bay battery is not in the machine, the Ultra-Bay HDD is.
YMMV
Ron
T400's and T500's
MrsOBrien08
#57 Post by MrsOBrien08 » Mon Mar 07, 2011 5:56 pm
Ok guys....all of the answers I got back are great.....I need this answer back in COMPUTERS4DUMMIES terms...I want to use #5 of the previous message...Do I need to take the computer apart for any of this?
#58 Post by RealBlackStuff » Mon Mar 07, 2011 6:25 pm
No, all of it is external.
Get this 2.5" SATA enclosure on eBay for $4.40 incl. shipping from USA (not Hong Kong)
http://cgi.ebay.com/USB-2-0-2-5-SATA-Se ... 0394182112
For a 2.5" SATA hard disk, tell us your required HD size and perhaps budget.
jronald
Contributing Member
Contributing Member
#59 Post by jronald » Mon Mar 07, 2011 6:50 pm
Looks identical to the one I suggested @ Geeks, but the price is better!
As RBS said: How much storage do you need?
A movie will take about 1 gig of storage
A CD will take about .5 gig (1/2 gig)
These are rough numbers, but you can get the idea
Ron
T400's and T500's
#60 Post by RealBlackStuff » Tue Mar 08, 2011 7:56 am
Mrs O, here's your chance!
Today is Fat Tuesday/Mardi Gras, whatever you call it.
Newegg has a very special offer: Western Digital Elements SE 1TB USB 2.0 Portable 2.5" Hard Drive.
That's ONE TERABYTE in a USB case, and all that for only $89.99 and free shipping!
http://promotions.newegg.com/neemail/ma ... -WDHDD#Per
Or scroll down a bit and get TWO TERABYTE for the same money (mind you that's a 3.5" hard disk! Heavy!)
HITACHI XL Desk 2TB USB 2.0 External Hard Drive HXSDNB20001BBB (0S02485) for $89.99
