A31 cpu upgrade
a31pguy
- Moderator1
Yes - any of these will work. Later Steppings are preferred over earlier steppings. Improvements in wafer materials, forge processes, and microcode bug fixes are indicated by later steps in CPU series.
Lower thermals are preferable to higher thermals in a mobile configuration - but should not be of utmost concern since the Pentium 4-M is designed to withstand a much higher core temperature.
I have the P4-m 2.4 Ghz "SL6VC" model in my a31p. Microcode updates to the CPU are handled by the BIOS but you can also check manually for any updates by using a utility from intel.
I also installed the Intel Application Accelerator 2.2.2 which takes advantage of the i845MP chipset and Pentium 4-M CPU bandwidth. I highly recommend this in combination with a 5400 rpm or higher speed drive.
Mike O'Hanlon
Thanks A31pGuy...
It just remains for me to find one of those processors at (or get one to) the bottom of Africa!
Incidentally, do your comments about the Intel Application Accelerator and the i845MP chipset apply equally to the A31 as well as the A31p?
(I've had a 5400 rpm HD for a year or two... now considering 7200 rpm)
Thanks again...
Thanks again...
Mike O'Hanlon [A31]
Cape Town, South Africa
Mike O'Hanlon
Thanks for the tip on the intel application accelerator a31pguy - did you happen to benchmark to get an idea of the improvement the replacement ATA drivers provided? I have a 7200 rpm disk and I'd like to try this tonight. Thanks!
Thinkpad T420 | Core i-5 2520M | 16gb RAM | 120gb Intel 520 SSD + 750gb 7200 RPM | 6300 N | Ubuntu 12.04 x64
Desktop: AMD FX-8350 (8 cores) | 32gb ECC RAM | 240gb Intel 530 SSD + 1tb 7200 RPM | Ubuntu 14.04 x64 | HP ZR24w
Previous Thinkpads: A21m, R40, X61, T410
a31pguy
- Moderator1
It was pretty hard to quantify in terms of raw performance numbers. It seems the Intel Application Accelerator is a hybrid of a cache pre-fetch driver and a Ultra ATA 100 driver. I could only find a 1-3 Mb increase in the raw numbers - but the real benefit seems to be in the caching pre-fetch portion. Outlook loads in less than a second on my system whereas before it would take up to 5 seconds. The acceleration part works for XP/2000 native apps - so any old DOS app may be no improvement. But HL2 is faster!!
Here are some PC Wizard 2005 hdd benchmarks after the upgrade (on a 5400 rpm drive with an 8 Mb cache buffer):
Sequential Write : 21.37 MB/s
Sequential Read : 27.62 MB/s
Buffered Write : 61.90 MB/s
Buffered Read : 73.91 MB/s
But this drive is 35% fragmented so it may not be the best benchmark.
But it also doesn't show the whole picture. The IAA seems to work well with the drive's cache and keep some apps ready to go. Scott Mueller's Upgrading and Repairing Computers recommends large cache sizes to improve overall performance. This seems in-line with that notion.
Mike O'Hanlon
Hey a31pguy...
From your sig I see you've got an Intel 2200BG. Did you need to change the antenna or was the card plug-and-play? I've got a 2.4ghz N5U also and I think the original wireless mini-pci card is munged. For the price I see for these cards, I'm willing to buy one just to try it, but don't want to mess with the antenna.
Thanks for any info you may provide!
great! thanks for the info! oops... one more question... i did some searching and it appears that the 2200bg is not a combo wlan/modem card like the stock card. have you given up dial-up modem capability?a31pguy wrote:Nope - straight up plug and play. No changes except Intel network drivers and updating IBM Access Connections to the latest.
thanks again!
Cpu upgrade what cpu to search
by radiator » Sun May 21, 2017 12:45 am » in ThinkPad T400/410/420 and T500/510/520 Series - 2 Replies
- 557 Views
Last post by my03
Sat May 27, 2017 6:22 pm
T520 cpu upgrade and fan
by Deschanel » Sun Jan 01, 2017 4:36 pm » in ThinkPad T400/410/420 and T500/510/520 Series - 10 Replies
- 1390 Views
Sat Jan 07, 2017 2:43 pm
T420 Upgrade Options for CPU/Memory
by Farro » Tue Jan 24, 2017 4:19 am » in ThinkPad T400/410/420 and T500/510/520 Series - 8 Replies
- 1883 Views
Last post by jaspen-meyer
Tue Feb 28, 2017 8:32 am
- 7 Replies
- 1564 Views
Last post by Omineca
Thu Apr 13, 2017 10:16 am
