That's because the title of this thread is "T510 - Can't find oem FHD panel anywhere! ". Suggest you start a new thread.RicanPr wrote:Sorry for the repetitive question, but everyone here is alluding to the T510.
T510 - Can't find oem FHD panel anywhere! please assist
Re: T510 - Can't find oem FHD panel anywhere! please assist
Wow, words of wisdom from a mod! Was expecting more from a forum representative. But thank you for your sage adviseHarryc wrote: That's because the title of this thread is "T510 - Can't find oem FHD panel anywhere! ". Suggest you start a new thread.
makaveli559m
So than I can upgrade my 1366 x768 to and HD+ with no problems no swapping cables or invertors?
__________
Lenovo Thinkpad W520
Microsoft Windows 10 Pro 64-bit
Intel Core i7 2760QM 2.40Ghz
16 GB DDR3 RAM
Samsung 840 EVO 500GB mSATA +750 GB 7200 RPM HD Seagate Momentus XT 8GB SSD NAND
Intel HD 3000/Nvidia Quadro 2000m 2GB GDDR3
15.6 inch 1920x1080 HD LED
CD-RW/DVD-RW Lite Scribe HP Multiburner
16 GB DDR3 RAM
That is correct.makaveli559m wrote:So than I can upgrade my 1366 x768 to and HD+ with no problems no swapping cables or invertors?
makaveli559m
http://www.ebay.com/itm/New-IBM-Thinkpa ... 2540562998
Can any one confirm if this type of screen would actually work? Has anyone gotten a glossy screen? My R61i has one, after that all the other Thinkpads I have, have had matte displays, would it would be more glossy than the R61i one?
__________
16 GB DDR3 RAM
16 GB DDR3 RAM
Hi guys
sorry that I re-activate this thread but I hope somebody can help me to make the right decision.
My screen is damaged in a way that I can still work with the T510 but every time I move the screen I get red, green and blue vertical lines and in the left upper corner of the screen the colour's are really smoky (i.e. black is a bright Gray). I think on my travels some how the T510 sees some forces on this corner. Anyway, my T510 is a student version which means I don't have any tech spec. And actually I don't have the right tool to see which screen is used. My T510 has the product ID 4349W32 and the screen resolution is 1600x900. So I guess the screen is the AUO B156HW01 V2 which can be replaced by the AUO B156HW01 V4, am I right ?
Has anyone experience with the AUO B156HW01 V4 and Linux? Does the screen works with the nvidia driver (the T510 has the NVS 3100M graphic card) ?
Rob
Rob
I Have a FRU 42t0765 that I have never used. Bought it to upgrade another system. Contact me by pm if interested
I bought the screen from the same seller on eBay, no complaint at all, what a vivid screen!ibsprocket wrote:Update -
I bought an FHD screen on ebay:
http://bit.ly/me5piM
Seller was great! Sent it Fedex Express from Taiwan. Arrived in 6 days, and that included a weekend. Stamped AUO on metal frame, sticker on back confirms part number.
Installation was a breeze. Took about 10 minutes. Screen looks amazing. Awesome upgrade for the money!
Yes you can.
Forum member CanadianDude has made this mod and is very pleased.
Brad
Brad
Long Island New York
CanadianDude
As Brad said, I successfully swapped my 1600x900 panel with a FHD panel and there were no issues at all. I have a T520 with the Nvidia 4200 graphics. FHD is much better I must say.
So this is the screen I want right?
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0898865644
DALE, wrong one your link is a glossy screen.
I am trying to pick the right ebay seller too. The two listings that were confirmed by people buying from this thread have ended. There is some other ones. Sometimes the back sticker on the pictures says "no warranty" or "limited warranty" or "AU optronics" (no mention of warranty for AU optronics). You'd think that "AU optronics" is the right one but the two you guys approved were "limited warranty" based on the links you provided but then you said it was stamped on the metal. Screenintaipei did not even have the FRU number on the sticker. So if you bought and are satisfied could you look at your LCD sticker and tell me :
FRU code or no FRU code at all ?
does it says "no warranty" or "limited warranty" or "AU optronics" ?
the manufacturing date on top. For ex : 11/22
provide the link to the seller. thx
After all I bought this one http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... TM:US:1123 - it was already in June. I agreed with the seller to send me the FRU original (04w1544; AUO B156HW01 V.4, 95% NTSC) panel and he did.
If I remember correctly on the back sticker was the FRU 04w1544 and AUO B156HW01 V.4 - most likely the panel Lenovo is using and I am very satisfied with it. I installed it and haven't had any problems since.
Sorry I am not sure about the other details (manufacturing date..) and I am not going to open my LCD.
Rather disconcerting.. You said the seller agreed to send you the FRU original. His ebay picture of the LCD back sticker clearly does not have any FRU number printed at the location where it's supposed to be. Also you said you remember the back sticker had AUO B156HW01 V.4. I can make out AUO B156HW01 from the back sticker of his picture but "V.4" is missing, it's clearly blank at that spot.DALE wrote:After all I bought this one http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... TM:US:1123 - it was already in June. I agreed with the seller to send me the FRU original (04w1544; AUO B156HW01 V.4, 95% NTSC) panel and he did.
As if that wasn't enough, in his description he says "Screen Finish: Glossy or Matte at random".
I've worked inside chinese companies and I know how chaotic and underhanded they are. I think he might have shipped you a refurbished pulled panel because this is certainly not the stock that he is selling is on that listing.
This removes any confidence from making a buy. I'd prefer to take the luck factor out of a >$120 decision.
Well, when I wrote that I had to agree with him to send the original panel -it meant that they have more kinds, originals and some other panels (e.g. original cannot be glossy...) - if you check who bought the 1 piece - it is me..
If mine was refurbised.. I cannot tell - I didn't notice any signs that it was used - seemed like brand new to me.
Yeah, well.. it is totally your decision - you just asked for my experience...
Dale Thanks for your answer. I am trying to lower my risk of getting a cheap replacement. I am not sure I can replicate your luck with that seller.DALE wrote:Well, when I wrote that I had to agree with him to send the original panel -it meant that they have more kinds, originals and some other panels (e.g. original cannot be glossy...) - if you check who bought the 1 piece - it is me..
Well.. it probably was quite a luck...
I'm worried that for $120-130 you will have to undergo this risk
- try to write those sellers, maybe their responses will convince you (or convince you to buy original from Lenovo
Wait a minute how do you know the FRU original is 04w1544 while people higher in the thread are saying FRU 42T0765 ?
I don't remember exactly now, but definitely from the hardware maintenance manual: http://download.lenovo.com/ibmdl/pub/pc ... 078_07.pdf - maybe other sources also.
The FRU 42T0765 is specified for the T/W510 series and the FRU 04W1544 is specified for the T/W520 series.
The FRU 04W1544 is a AU Optronics B 156H01 V4.
I don't have the specifics on the 42T0765. The next time I see one I will look at the label.
The fitment and operation in either series is the same. This panel also will likely fit SL and Edge models.
I have a personal preference for the 42T0765 which I think has a slightly warmer quality.
I have sold several to forum members. PM if interested.
Brad
Brad
mujahid7ia
Since this thread still comes up very high in the Google results for those looking to replace TP T510 screens, I thought I would add this link where one could purchase the exact part: http://www.laptopscreen.com/English/scr ... 6HW01~V.4/ - I ordered one and will update this thread when I receive it.
On eBay, there is only one seller (as of today) that seems to be guaranteeing an exact part - but even then, it's hard to trust that since he does not allow buyers to ask questions regarding the item!
R31, R50e, R60, T500, T510, T430s
Check these screens out, if they are compatible: http://www.pei-network.com/15-6-screens/
They are well-priced, and I have bought from this company before (excellent communication and service).
How can I find out if I can run Win10 or Win 7 on this T60?
by Muse » Sat Jan 07, 2017 10:29 am » in ThinkPad T6x Series - 15 Replies
- 2243 Views
Last post by sebileis2017
Thu Mar 09, 2017 11:24 am
What's the brightest LCD panel I can get for T440p?
by crystal castle » Thu Apr 20, 2017 8:28 am » in ThinkPad T430/T530 and later Series - 3 Replies
- 300 Views
Thu Apr 20, 2017 12:19 pm
SOLD: Lenovo Thinkpad T440, 256gb SSD, 12GB, i5 4300U, 2.5ghz, FHD 1920x1080
by nizmoz » Sat Dec 31, 2016 7:27 pm » in Marketplace - Forum Members only - 4 Replies
- 690 Views
Last post by nizmoz
Fri Jan 13, 2017 6:17 pm
- 3434 Views
Last post by jaspen-meyer
Fri Apr 14, 2017 9:34 am
